[AG-TECH] Windows Capture Cards
John I Quebedeaux Jr
johnq at lsu.edu
Mon May 16 16:38:59 CDT 2005
Darin,
Sorry for the late response - Ospreys (100's and 230's) and yes, on
only Windows machine node. Although, the question is academic I would
think - whether they are single node or multi-node with Windows
unless you were just looking to see if folks are doing it. I have
both mixed OS and just Windows for some nodes. In fact, I've
combined ALL of my nodes (4) into one big node (just to do it) to
test out how well it worked and to demonstrate that a "node" is a
relative term... so, i've run an Windows/RedHat/OS X node before as a
result.
But the answer to the question is single and multi-machine nodes -
I've been using Osprey cards with Windows XP SP2. Just have to fall
back to legacy drivers: http://www.viewcast.com/driverdownload2.asp#
i believe is where they are now.
Hope that helps more!
-John Q.
John I. Quebedeaux, Jr.
Louisiana State University
Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339
Johnston Hall
e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu
& http://cct.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On May 13, 2005, at 12:15 PM, mimiller at ncsa.uiuc.edu wrote:
> Darin,
> Yeah, most of our windows only nodes are single machine nodes.
> Having multiple cards has not been a problem for those machines.
> for a multiple node setup, all you need to do is make sure that the
> AGServiceManager is running on the remote machines and connect to
> them with the Node Manager.
> Did I hit on the right thing or are there other questions in your
> mind?
> MYK
> At 11:14 AM 5/13/2005, Darin Oman wrote:
>> Thanks, Mike. That does help. I got a couple different responses
>> saying basically the same thing. However, nobody has mentioned if
>> they're using a multi-windows-machine node. I'm digging through
>> the archives now, so far with no luck finding any info on windows-
>> only multi-machine nodes. Do you have any insight?
>> Darin
>> On May 13, 2005, at 10:06 AM, mimiller at ncsa.uiuc.edu wrote:
>>> Darin,
>>> We use Osprey cards in all our nodes. Be careful of those that
>>> have audio on-board, they can sometimes get switched around and
>>> then RAT is looking at the wrong jack... We use the 100 and 200
>>> cards with some older drivers that are more stable.
>>> Hope this helps
>>> MYK
>>> At 10:38 AM 5/13/2005, you wrote:
>>>> Unfortunately, what I really need is something that will capture
>>>> using s-video. The Winnov cards use BNC. Has anybody had success
>>>> in setting up multiple capture cards on an XP machine? If so,
>>>> which cards did you use?
>>>> Thanks again,
>>>> Darin
>>>> On May 13, 2005, at 8:05 AM, Cindy Sievers wrote:
>>>>> I am using the winnov videum 4400 quad card and thanks to Tom
>>>>> it is working nicely....
>>>>> At 04:12 PM 5/12/2005, Darin Oman wrote:
>>>>>> I know there are some people out there using a Windows box as
>>>>>> their video capture machine. What capture cards are people
>>>>>> having good luck with for capturing multiple video sources (s-
>>>>>> video)?
>>>>>> Thanks,
>>>>>> Darin
>>>>> Cindy Sievers Los Alamos National Laboratory
>>>>> sievers at lanl.gov Group CCS-1 MS B287
>>>>> tel:505.665.6602 Advanced Computing
>>>>> fax:505.665.4939 Los Alamos, NM 87544
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050516/2b4bace9/attachment.htm>
