[AG-TECH] AG security and multicast ?
Thomas D. Uram
turam at mcs.anl.gov
Wed May 11 08:34:36 CDT 2005
Derek:
I've generated documentation from the toolkit code, and posted it in the developer
documentation pages:
http://www.mcs.anl.gov/fl/research/accessgrid/documentation/developer.html
Any of the AG components that are exposed via SOAP are represented by an interface wrapper
('IW') class; for example, the venue server's SOAP interface is accessible via
AccessGrid.VenueServer.VenueServerIW . If you find that documentation for an IW class is
somewhat lacking, you can look at the IW's symmetric counterpart, the interface or 'I'
class (e.g. AccessGrid.VenueServer.VenueServerI); the 'I' classes are in some cases better
documented.
I'd encourage people to take a look and, by all means, "write tools/add-ons and be happy".
We'll be adding to the developer documentation pages soon, to facilitate external
development.
Tom
On 04/13/05 09:48, Derek Piper wrote:
> Hi,
> Since the 'brainstorming' appears to have died down a lot.. What
> about a published API for interacting with the venue server? Then we can
> all go write our tools/add-ons and be happy. Good ones can be
> incorporated into the main AG software, i.e. pass codes etc.
> Derek
> Ivan R. Judson wrote:
>> The beauty of Adam's suggestion is that it's exactly what the AG team has
>> been trying to get enough time to build. This is the kind of work we'd
>> like
>> to see -- but I don't believe the NCSA scheduler has been released yet
>> for
>> others to hack on it. The work I believe is a small amount using the
>> existing interfaces that are available.
>> If this can't be done in short order, I support Brian's point that for
>> most
>> users a passcode/password -- similar to what is used by conference
>> calls or
>> web meeting software, should be sufficient _to gain access_ to the
>> venue (to
>> get past the bouncer), but it's really of *no* use if the communication
>> within the venue isn't secure -- then as Jennifer points out, you're only
>> relying on obscurity.
>> Who wants to hack on the scheduling software (either NCSA's or a new
>> one)?
>> That's where the interesting "automation" is. It won't solve all the
>> ad-hoc
>> stuff, but it'd go a long way towards solving a lot of the mundane
>> problems...
>> --Ivan
>>> -----Original Message-----
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>> Behalf Of Adam Taylor
>>> Sent: Monday, April 11, 2005 11:01 AM
>>> To: ag-tech at mcs.anl.gov
>>> Subject: RE: [AG-TECH] AG security and multicast ?
>>> My two cents...
>>> To bad there wasn't a way that when you go to confirm you reservation
>>> in the AG Scheduler you must enter the DN of the site you will be at
>>> to confirm your reservation. Then, 5 min or so before the meeting
>>> starts, a background process (something that can talk to the venue
>>> server and scheduler) reads in the DNs from the scheduler for that
>>> room and time and sets the ACL for that room for that given scheduled
>>> time block. When that meeting is over, the background process
>>> removes that ACL for that room and creates another one for the next
>>> meeting in that room. If there is more then 30 min or so between
>>> meetings then the background process just removes the ACL for that
>>> period of time. Just make sure all rooms are encrypted (different
>>> key per meeting or something like that) and that should make it
>>> pretty secure.
>>> At least in my head it does :-)
>>> Adam Taylor
>>> Computing Center
>>> University of Louisiana at Monroe
