[AG-TECH] Running AG from CVS doesn't work
Eric Olson
eolson at mcs.anl.gov
Mon May 2 17:13:48 CDT 2005
Hi Michael,
The HEAD branch of cvs is always under development and is not guaranteed
to work at any one time. It is undergoing considerable changes at the
moment.
Depending on what you're working on, you can always check out the code
from the 2.3 branch with -r r_2_3_final, or check out the trunk (HEAD)
from a previous date until the trunk stabilizes.
Eric
On Mon, 2 May 2005, Michael Braitmaier wrote:
> I tried to start AG from CVS today, following the procedure through
> CvsSetup.py as well as env-init.bat
> Furthermore I downloaded ZSI-1.6. and installed it by first building the
> windows-installer from the source package.
> pyXML has been installed as well.
> I got an error when executing the VenueClient.py:
> from AccessGrid.interfaces.AccessGrid_Types import www_accessgrid_org_v3_0 a
> s AGTypes
> ImportError: No module named interfaces.AccessGrid_Types
> I assumed it to be caused by not having the required type definitions which
> possibly are made out of the wsdl files.
> So I executed the generate.bat file in the AccessGrid/wsdl directory, which
> didn't work in the first place as it couldn't find wsdl2py and wsdldispatch
> I found similar programs in the ZSI site-package directory called
> wsdl2python.py and dispatcher.py and assumed them to be the right programs
> to generate the stubs.
> Still I get the error as described above when executing the VenueClient.
> So now I am a bit clueless. What could be the reason for this?
> Any help would be greatly appreciated.
> Michael
> Dipl.-Inf. Michael Braitmaier
> HLRS - Visualization / Video Conferencing
> University of Stuttgart
> Germany
> Website: http://www.hlrs.de/organization/vis/people/braitmaier/
