[AG-TECH] shared presentation fails to load presentation
Michael Miller
mimiller at ncsa.uiuc.edu
Mon May 2 15:51:52 CDT 2005
We've had trouble with ppts created on Macs. It seems there's a problem
opening files on windows if a template was applied on the Mac side. In
some cases, pics would not show up because they are compressed in a format
unavailable to the Windows side. The solution was to redo the slides on
the Windows side. I know, I know...
Hope this helps.
Michael
At 03:02 PM 4/28/2005, Michael Blodgett wrote:
>I have been working around this for awhile, fresh install of win2k,
>ag2.3. I can open a shared presentation, the control window pops up along
>with powerpoint app, it downloads the ppt file but then I get a popup
>window that it couldn't load the presentation. I found a similar report
>on the ag-tech mailing list last November but there were no replies. I
>included the shared presentation log message below. This problem look
>familar to anyone?
>Mike Blodgett
>UW-Madison,CS
>04/21/05 11:35:21 1452 Toolkit toolkit.py:90 DEBUG Initializing AG
>Toolkit version 2.3
>04/21/05 11:35:21 1452 Toolkit toolkit.py:132 INFO Logfile Name:
>SharedPresentation.log
>04/21/05 11:35:21 1452 Toolkit config.py:196 DEBUG Using
>GLOBUS_HOSTNAME=ag-display.cs.wisc.edu as set in the environment
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:257
>DEBUG Opened repository C:\WINNT\Profiles\ag-op\Application
>Data\AccessGrid\Config\certRepo
>04/21/05 11:35:21 1452 Toolkit toolkit.py:395 DEBUG Got repo.
>04/21/05 11:35:21 1452 Toolkit toolkit.py:397 DEBUG looking in system
>ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
>04/21/05 11:35:21 1452 Toolkit toolkit.py:401 DEBUG Getting cert:
>1c3f2ca8.0
>04/21/05 11:35:21 1452 Toolkit toolkit.py:406 WARNING Not importing
>cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
>45cc9e80.0
>cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
>d1b603c3.0
>cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
>f18fa857.0
>cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
>04/21/05 11:35:21 1452 Toolkit toolkit.py:410 DEBUG Init'ing globus.
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:734
>DEBUG Configuring standard environment
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:802
>DEBUG Using default identity /O=Access
>Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.wisc.edu/CN=Michael Blodgett
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:873
>DEBUG Initializing environment with proxy cert for /O=Access
>dgett
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:907
>DEBUG Looking for identity (unused) None
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:892
>DEBUG Configuring for user proxy issued from /O=Access
>04/21/05 11:35:21 1452 CertificateManager certificatemanager.py:895
>DEBUG Proxy C:\WINNT\Profiles\ag-op\LOCALS~1\Temp\proxy will expire
>04/21/05 18:26:51
>04/21/05 11:35:21 1452 Toolkit toolkit.py:414 DEBUG Done with globus.
>04/21/05 11:35:24 1452 EventClient eventclient.py:158 DEBUG Have
>callback handle _90725e02_p_callbackStruct
>04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:727
>DEBUG Registering for events.
>04/21/05 11:35:24 1452 SharedPresentation sharedpresentation.py:735
>DEBUG Creating controller.
>04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:810
>DEBUG Got Event: local load venue None
>04/21/05 11:35:26 1876 SharedPresentation sharedpresentation.py:1432
>DEBUG Method LocalLoadVenue called
>04/21/05 11:35:27 1876 SharedPresentation sharedpresentation.py:1441
>DEBUG Got presentation:
>https://ivs.mcs.anl.gov:9006/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt
>04/21/05 11:35:30 1876 DataStore datastore.py:1643 DEBUG Host
>ivs.mcs.anl.gov:9006, path
>04/21/05 11:35:30 1876 DataStore datastore.py:1645 DEBUG Connect to
>04/21/05 11:35:30 1876 DataStore datastore.py:1648 DEBUG Downloading
>into C:\WINNT\Profiles\ag-op\LOCALS
>~1\Temp\presentation.ppt
>04/21/05 11:35:30 1876 DataStore datastore.py:1655 DEBUG before
>connect reqest path
>/00000100a9f4edf1008c00dd000a005aad0/2005_0421_GCM.ppt, headers {}
>04/21/05 11:35:31 1876 DataStore datastore.py:1657 DEBUG after connect
>reqest
>04/21/05 11:35:31 1876 DataStore datastore.py:1659 DEBUG request sent
>to <pyGlobus.io.GSIHTTPConnection instance at 0x04E9EB20>
>04/21/05 11:35:31 1876 DataStore datastore.py:1663 DEBUG response is
><httplib.HTTPResponse instance at 0x021EA468>
>04/21/05 11:35:31 1876 DataStore datastore.py:1664 DEBUG Request got
>status 200
>04/21/05 11:35:31 1876 DataStore datastore.py:1677 DEBUG Got hdr 3336704
>04/21/05 11:35:31 1876 DataStore datastore.py:1678 DEBUG ['Server:
>BaseHTTP/0.3 Python/2.3.4\r\n', 'Date: Thu, 21 Apr 2005 16:33:01 GMT\r\n',
>'Content-type: application/octet-stream\r\n',
>'Content-Length: 3336704\r\n']
>04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1484
>ERROR Can not load file
>5
>Traceback (most recent call last):
> File "SharedPresentation.py", line 1481, in LocalLoadVenue
> self.viewer.LoadPresentation(tmpFile)
> File "SharedPresentation.py", line 156, in LoadPresentation
> self.presentation = self.ppt.Presentations.Open(file)
> File
> "C:\Python23\Lib\site-packages\win32com\gen_py\91493440-5A91-11CF-8700-00AA0060263Bx0x2x7.py",
> line 3749, in Open
> ret = self._oleobj_.InvokeTypes(2005, LCID, 1, (13, 0), ((8, 1), (3,
> 49), (3, 49), (3, 49)),FileName, ReadOnly, Untitled, WithWindow)
>com_error: (-2147352567, 'Exception occurred.', (0, None, None, None, 0,
>-2147467259), None)
>04/21/05 11:35:31 1876 SharedPresentation sharedpresentation.py:1502
>ERROR SharedPresentation.LocalLoadVenue: Can not load presentation
>04/21/05 11:35:43 1452 SharedPresentation sharedpresentation.py:762
>DEBUG Shutting down...
>04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:810
>DEBUG Got Event: local quit None
>04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1216
>DEBUG Method Quit called
>04/21/05 11:35:43 1876 SharedPresentation sharedpresentation.py:1234
>ERROR Exception destroying controller. This happens when using the x
>button in the top right corner. Not critical.
> File "SharedPresentation.py", line 1232, in Quit
> self.controller.frame.Destroy()
> File "C:\Python23\Lib\site-packages\wx\core.py", line 9344, in __getattr__
> raise PyDeadObjectError(self.attrStr % self._name)
>PyDeadObjectError: The C++ part of the SharedPresentationFrame object has
>been deleted, attribute access no longer allowed.
>04/21/05 11:35:44 1452 EventClient eventclient.py:303 DEBUG Cancel
>pending callbacks
>04/21/05 11:35:44 1948 EventClient eventclient.py:177 DEBUG Read
>Callback called arg=None handle=_08ef5c02_p_globus_io_handle_t result=(-1,
>2, 'an I/O operation was cancelled') n=0
>04/21/05 11:35:44 1948 EventClient eventclient.py:180 DEBUG
>readCallback gets failure in result: -1 2
>04/21/05 11:35:44 1452 EventClient eventclient.py:309 DEBUG Free
>callback _90725e02_p_callbackStruct
>04/21/05 11:35:44 1452 EventClient eventclient.py:315 DEBUG
>EventClient.Stop: closing socket
>04/21/05 11:35:44 1452 EventClient eventclient.py:323 DEBUG
>EventClient.Stop: closing queue
