[AG-TECH] Portable AG node
    John I Quebedeaux Jr
    johnq at lsu.edu
    Thu Mar 31 18:36:02 CST 2005
Natalia,
I need to get you a picture of how the cables are placed on ours (maybe
I'll take the top off and show you that way) - but basically, I have a
set of cable ends from the phoenix connectors on the XAP400 that just
run to the back in a flexible conduit with XLR connectors where the
cables (which are coiled up on hooks on the sides when in "storage/move
mode" and simply plugged into the connectors on the back when in use.
This lets me mix and match for distances, etc.
Note: a lot of 2" wide velcro was used in keeping things in place  -
monitors, gentner (helps cushion during travel as well), other devices
- even the powerbricks from the monitors, etc). Walmart, fabric section
- black or white is where you find lots of the stuff... =)
I'm setting up the system over the weekend for a conference, i'll get
some detailed picture for  you on that. My preference would have been
to put a patch panel somewhere on the cart but just never got around to
it - i.e. it works, it's quick, we've been so busy I haven't done more
to it! But it could be cleaned up.
Someone was telling me that the audio folks have some nifty cards for
rackmounting equipment that are mobile... i have to look into that...
they did say it was $$$$ though...
-John Q.
John I. Quebedeaux, Jr.
Louisiana State University
Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339 Johnston
Hall
e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu &
http://cct.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On Mar 31, 2005, at 9:11 AM, Natalia Costas Lago wrote:
> Thank you very much John for such a detailed description. There are
> some points that are interesting for ours.
> Our mobile node will be used... everywhere. Actually we are thinking
> in a 3 projectors setup. Buy 3 portable screens.... The main goal is
> to reduce the size of the rack (that means to reduce every item we can
> think of), and try to work out some solutions for an easy .. "plug and
> play". The cables issue is a big one.
> We need.. room node quality equipment.. that we can move around easily.
>  From: John I Quebedeaux Jr
> To: Natalia Costas Lago
> Cc: ag-tech
> Sent: Wednesday, March 30, 2005 10:12 PM
> Subject: Re: [AG-TECH] Portable AG node
> Natalia,
> I hate to say it this way... but it depends. That's one of the things
> about the AG is that it IS so flexible for the environment you are
> putting it into. Will you use the portable in a small room, large
> room, auditorium, etc? everywhere?
> I'm currently upgrading our portable node and putting as much
> flexibility and power into as small a box i can get was one of my
> dilemmas. I'm still looking at motherboard slot configurations, etc.
> I'm going to be trying out one of those quad-capture cards...
> However: this is what my current portable node looks like below (LSU's
> portable node is affectionately named "Wilbur the PIG")
> two 15" LCD monitors
> one dual head AGP Matrox card (I forget which)
> one quad head PCI Nvidia card (I forget which)
> two Canon VC-C4 cameras
> one Sony EVI-D100 camera
> 3 tripods
> wireless keyboard and mouse
> one trackerpod quickcam (WDM) for operator
> three osprey 100 capture cards
> on board audio/network (100mbit on this one)
> CPU is a dual 2.2 xeon running XP(SP2)
> XAP400
> one wireless lapel mic
> i borrow crown mics from my full node as needed for inputs 2-4
> pair of genelec 1029A speakers
> surgeprotector/filter
> 50' to 100' of just about every cable - well shielded s-video cables
> btw.
> my upgrade will speed up the CPU/motherboard, replace the video card
> with a single quad card, put in a single capture card, have audio and
> firewire and gigabit. I'm going to add a 2nd wireless mic (for
> audience on a stand) and a couple of table mics I can attach. I'll
> upgrade the cart - pneumatic tires probably or build a split "cart"
> where the top and bottom are removable for easier travel in vehicles.
> I've taken Wilbur all over the state. Fortunately, this design fits in
> the back "well" of my van (where the back seat folds up into). Note,
> the tripods do fold up small enough to fit inside the cart. EVERYTHING
> fits on the cart.
> The bottom half of this card holds ALL the cameras, cables, etc. The
> top half holds the CPU, echo canceler, wireless receiver, monitors,
> and speakers (velcro holds them in place during the long rolls across
> campus). There is even a plastic cover (see picture with umbrella in
> the corner?) that keeps it dry in the event of a sudden down pour
> (which has happened... it's Louisiana, thunderstorms happen). =)
> The reason for the mismatch on the cameras is that i ended up with a
> spare camera from another project... and two cameras is NOT enough.
> I'll even say 3 isn't, but 3 is okay.
> The cart is a rubbermaid cart... we removed the drawer section in the
> top half, put a plywood board in for more support (that CPU is heavy),
> and cut one small hole for the cables into the bottom half where we
> have a powerstrip/surge protector.
> Hope this gives you some ideas. Basically though, this has allowed
> most of the flexibility I needed - I have a spare projector but it's
> not that bright and i have to rely on the installed projectors in
> rooms I go to, but 1 projector isn't enough (no one seems to
> understand that until they see our full node in action). They keep
> wanting to squeeze everything into one screen. Argh. Terrible.
> -John Q.
> <image.tiff>
> Roll 2 - 1397
> <image.tiff>
> Roll 2 - 1396
> <image.tiff>
> Roll 2 - 1390
> Hall
> & http://cct.lsu.edu
> On Mar 30, 2005, at 11:06 AM, Natalia Costas Lago wrote:
> Hi everybody!
> We are in a new stage of AG deployment, our new challenge is to
> develop a mobile AG node. It's a room one, but we need to move the
> equipment wherever is needed.
> And, we are in a hurry, as we need to purchase and have it working
> properly for an important event soon.
> I've seen this isnt a brand new idea, there is a pic of one "portable
> ag node" on the Internet2 website, and there are more sites that have
> one. The problem is that i couldnt find precise details about the
> hardware we should purchase. Or the better configuration (cable
> length, wireless video, maybe rack PCs?), there are so many choices!!.
> We greatly appreciate any suggestion, configuration and/or advices
> provided.
> Has anyone out there worked on a similar configuration?
> Thankx in advance,
> Kind regards,
> Natalia.
> Natalia Costas Lago
> email: natalia at cesga.es
> Centro de Supercomputacion de Galicia (CESGA)
> Avenida de Vigo, s/n Campus Sur
>  15706 Santiago de Compostela - SPAIN
> Tel:   +34  981 56 98 10
>  Fax:  +34  981 59 46 16
> http://www.cesga.es/
Name: not available
Type: text/enriched
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050331/d8ed0abc/attachment.bin>
