[AG-TECH] OS X rat
David McNabb
mcnabb at umd.edu
Wed Mar 16 12:32:46 CST 2005
Hi Folks,
I am having great luck using an "iMic", a USB device that accepts
either line-level or mic-level mic input (mini stereo plug) as well as
sends out audio to, say, the headset. Right now I'm on in the test room
using the iMic to feed the mic part of my Altec Lansing AHS 302 into
USB but I've plugged the headphones cable into the G5 front-panel
headset port. It seem to be working, but I have not had many people
on to test this. Between my two nodes here (G5/OSX and Dell Precision
650/XP) it seem to be fine.
The Griffin iMic USB Audio Interface (T3041LL/A in the Apple Store)
costs about $35 and is a must-have or analogue audio work on a Mac.
--David
David McNabb
Project Lead, UMAGI
UM Access Grid Initiative
Office of Information Technology
University of Maryland
College Park, MD, USA
mcnabb at umd.edu
---- Original message ----
>Date: Wed, 16 Mar 2005 11:19:12 -0600 (CST)
>From: Eric Olson <eolson at mcs.anl.gov>
>Subject: Re: [AG-TECH] OS X rat
>To: Jeremy Mann <jeremy at biochem.uthscsa.edu>
>Cc: ag-tech at mcs.anl.gov
>Hi Jeremy,
>Rat audio device selection on the mac is a little different from the
>other platforms.
>You shouldn't need to set the audio device from within rat -- I don't
>believe the code uses that setting (yet?). Still, on my machine (G5
>tower) the device in rat does say "default sound device" instead of "no
>audio device", so if you change that you could try hitting the Quit
>button in rat to save the settings.
>The main place you should set your default audio device (for input and
>output) is in the general osx "System Preferences" -> Sound.
>As far as microphone hardware, here's what I've found so far. First,
>Apple's details on the G4's line-in are scarce if not nonexistant, and it
>seems to be different than the G3 and G5 (I could be wrong here). Also,
>an adapter may not work since apple's plug designs are often non-standard.
>You could ask apple support more about that, but I would first try one of
>the usb microphones that have recently been reported working on this
>mailing list. The ones mentioned so far are the Plantronics DA-50,
>DSP-100, and DSP-400. I would expect more if not all plantronics
>microphones to work, but we're not sure of that yet.
>Eric
>On Tue, 15 Mar 2005, Jeremy Mann wrote:
>> I've installed the latest release of AG for OS X. Everything works great,
>> except RAT. When I select "Default Sound Device" from Options -> Category
>> -> Audio, it doesn't change and save the setting. Next time I open Options
>> -> Category -> Audio, its back to "No Audio Device".
>> How can I fix this?
>> Also, what kind of audio connector is needed for the microphone or line
>> level out (whichever it is) on my dual G4 tower? Its smaller than the 1/8"
>> inch jack I'm used to.
>> Thanks again.
>> Jeremy Mann
>> University of Texas Health Science Center
>> Bioinformatics Core Facility
>> http://www.bioinformatics.uthscsa.edu
>> Phone: (210) 567-2672
