[AG-TECH] linux video capture
John Hodrien
johnh at comp.leeds.ac.uk
Thu Mar 17 03:32:27 CST 2005
On Wed, 16 Mar 2005, Robert Olson wrote:
> What you might be seeing is this:
> On linux, vic captures via v4l at 352x288. On a BT848-flavored card (I think
> the Ospreys fall in this class as well as the Hauppauge cards), capturing at
> more than 240 lines causes teh capture to happen from both fields, as NTSC
> video is two fields of 240 lines each. Hence, you get interlacing effects.
> As I recall with vic on windows, it captures at 320x240, so the data comes
> from a single field and hence has no interface artifacts.
Isn't that just the difference between 1/4 PAL and 1/4 NTSC. We capture at
1/4 PAL on a BT848 with no interlacing problems. If you can flick your
cameras into PAL mode, and capture at that res, all should be fine I think.
jh
