[AG-TECH] FC3 on Video machine not recognize video capture cards
Natalia Costas Lago
natalia at cesga.es
Tue Mar 15 12:14:55 CST 2005
Hi Supreeya,
Just an easy question, is the bttv module loaded (or the module ur cards
use)??
----- Original Message -----
From: "Supreeya Miller" <supreeya.miller at usm.edu>
To: "'Douglas Kosovic'" <douglask at itee.uq.edu.au>
Cc: "'ACCESS community'" <ag-tech at mcs.anl.gov>
Sent: Tuesday, March 15, 2005 6:35 PM
Subject: RE: [AG-TECH] FC3 on Video machine not recognize video capture
cards
> Douglas,
> The attach file is the output of the command /etc/lspci.
> Looking at the file, the video capture controllers don't seem right.
> Let me say in detail how I got this problem:
> The Display machine has lost the use of one of the two
> processors. The processor died by itself. I have been operating on one
> processor for so long. It came to the point that the Display became
> sticky, where I couldn't not move or do anything. The Task Manager
> indicated that the CPU uses was at 100%. Then I thought of switching
> between the Display and Video machines since the Video machine had 2
> processors. I then took the 4 video capture cards out of the Video
> machine and put them in the Display machine. At this point the Video
> machine was working just fine. I had been using it since 2001.
> Just my luck that the Video machine saw the Windows XP cd ,but
> it would not install. I got the DOS looking screen saying that the
> "Setup is configuring your hardware", then the screen went blank
> forever. Then I used a DOS floppy disk and used the command "fdisk
> /mbr". So that the machine would not recognize Linux anymore. I still
> could not install Windows.
> I gave up and put the video capture cards back in the Video
> machine. Since I lost Linux because of the fdisk command. I
> reinstalled FC3 then AG2.3. I ran the setup for a new node and found
> out that the machine does not see the cards. I ran a "vic" command. It
> said "trying /dev/video0...open: no such file or directory" for all
> video0, video1, video2, and video3.
> I look at the .AccessGrid directory and see no LocalService
> directory.
> Anything that you see wrong here?
> Supreeya Miller
> Visualization Researcher and Access Grid coordinator
> Center of Higher Learning
> Building 1103, Visualization Lab
> Stennis Space Center, MS 39529
> Phone: 228-688-2190
> Fax: 228-688-7454
> Box: 10002
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Douglas Kosovic
> Sent: Monday, March 14, 2005 4:30 PM
> To: Supreeya Miller
> Cc: ACCESS community
> Subject: Re: [AG-TECH] FC3 on Video machine not recognize video capture
> cards
> Hi Supreeya,
>> I installed FC3 and AG2.3 on a Video capture machine, which has 4
> winnt
>> video capture cards. The machine does not see the cards. Any advice
> on
>> what to do, please?
> If you do a '/sbin/lspci' on the command line, what is the output? In
> particular the lines with "Multimedia video controller". Perhaps there
> is no
> Video4Linux driver available for those capture cards.
> Doug
