[AG-TECH] Problem with mic, rat and gentoo
Ashley Wright
a2.wright at qut.edu.au
Mon Mar 14 22:23:32 CST 2005
Hi Jason,
This was the first thing I tried, I prefer the talk to start muted,
however the setting made no difference.
This is a strange problem. I have had a look in the AudioService script
(inside AudioService.zip) but cant find anything I would think would
make a difference.
Ashley
Jason Bell wrote:
>Hi Ashley
>Have you tried editing the audio service settings through the "manage my
>node" configuration tool????
>You have the ability to change the input and output levels as well as
>turning talk on and off.
>These setting may help as well.
>Cheers,
>Jason.
>Jason Bell, B.I.T.
>B. Info. Tech. (Honours) Student
>Network Engineer
>Information Technology Division
>Central Queensland University
>High Performance Computing Support Officer
>Research Assistant to the Nonlinear Intelligent Systems Research Group
>Faculty of Informatics & Communication
>E-mail : j.bell at cqu.edu.au
>Phone : 07 4930 9229
>Patience is a virtue.
>But if I wanted Patience,
>I would have become a Doctor.
>-----Original Message-----
>From: Ashley Wright [mailto:a2.wright at qut.edu.au]
>Sent: Tuesday, 15 March 2005 12:55
>To: Jason Bell; 'ag-tech at mcs.anl.gov'
>Subject: Re: [AG-TECH] Problem with mic, rat and gentoo
>Hi Jason,
>This looks good, I have found the file and the setting "*audioInputMute:
>1" However if I set this to 0, next time the Venue Client opens the RAT
>it is set make to 1.
>Also interesting, if I open RAT with the command "rat
>xxx.xxx.xxx.xxx/xxx" the mic setting is left unchanged (this is good),
>however if it is opened with the Venue Client then I still get the
>feedback. This is making me think the venue client is doing something I
>do not want it to do.
>Any more ideas?
>Ashley
>Jason Bell wrote:
>>Hi Ashley
>>There is a RatDefaults file in the home directory (Well there is for
>>fedora anyway), you might want to changes some of the settings in that
>>file so that when "rat" starts up, none of your settings are changed.
>>Hope this helps.
>>Cheers,
>>Jason.
>>Jason Bell, B.I.T.
>>Network Engineer
>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>Behalf Of Ashley Wright
>>Sent: Tuesday, 15 March 2005 11:59
>>To: ag-tech at mcs.anl.gov
>>Hi,
>>Normally in the mixer (gnome volume control), we have the mic input
>>muted, with the record ticked. This works. Our problem is that when rat
>>is started it un-mutes the sound, so that the sound plays though the
>>speakers. Ticking the mute box fixes this again.
>>My problem is that every time rat is opened, or settings are changed,
>>the mic feedbacks though the speakers, and I have to tick the mute box
>>again.
>>We are running a sound blaster live. We are using OSS because ALSA
>gives
>>a distorted sound.
>>This does not happen on our Fedora Access Grids, only our gentoo Access
>>Grid.
>>Anybody have any other ideas?
>>Ashley
>>Gavin W. Burris aka 86 wrote:
>>>Sounds like you have to adjust your mixer to not play capture back
>>>through. If you are not using ALSA, then I would highly recommend it.
>>>My notes, including mixer screen-grabs, here:
>>>http://viz.aset.psu.edu/ga5in/AccessGridNodeOperation.html#audio
>>>Ashley Wright wrote (on Mon, 14 Mar 2005 at 09:09):
>>>>Hi,
>>>>We have set up a single computer accessgrid using Gentoo Linux. We
>>have
>>>>used the official AG2.3 toolkit.
>>>>My problem is that every time a new rat is opened (changing venue
>etc)
>>>>or a setting is changed, rat unmutes the microphone and the mic plays
>>>>directly into the speakers. This causes feedback though the mic and
>>>>speakers. I then need to remute the mic in the gnome volume control
>to
>>>>get rid of the feedback.
>>>>Does anybody have any ideas of what could be causing this, and a
>>>>suggested fix.
>>>>Thanks,
>>>>Ashley
>>>>Ashley Wright
>>>>3864 9264
>>>>HPC and Research Support Group
>>>>Queensland University of Technology (QUT)
Ashley Wright
3864 9264
