[AG-TECH] Problem with mic, rat and gentoo
Ashley Wright
a2.wright at qut.edu.au
Mon Mar 14 20:55:15 CST 2005
Hi Jason,
This looks good, I have found the file and the setting "*audioInputMute:
1" However if I set this to 0, next time the Venue Client opens the RAT
it is set make to 1.
Also interesting, if I open RAT with the command "rat
xxx.xxx.xxx.xxx/xxx" the mic setting is left unchanged (this is good),
however if it is opened with the Venue Client then I still get the
feedback. This is making me think the venue client is doing something I
do not want it to do.
Any more ideas?
Ashley
Jason Bell wrote:
>Hi Ashley
>There is a RatDefaults file in the home directory (Well there is for
>fedora anyway), you might want to changes some of the settings in that
>file so that when "rat" starts up, none of your settings are changed.
>Hope this helps.
>Cheers,
>Jason.
>Jason Bell, B.I.T.
>B. Info. Tech. (Honours) Student
>Network Engineer
>Information Technology Division
>Central Queensland University
>High Performance Computing Support Officer
>Research Assistant to the Nonlinear Intelligent Systems Research Group
>Faculty of Informatics & Communication
>E-mail : j.bell at cqu.edu.au
>Phone : 07 4930 9229
>Patience is a virtue.
>But if I wanted Patience,
>I would have become a Doctor.
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>Behalf Of Ashley Wright
>Sent: Tuesday, 15 March 2005 11:59
>To: ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] Problem with mic, rat and gentoo
>Hi,
>Normally in the mixer (gnome volume control), we have the mic input
>muted, with the record ticked. This works. Our problem is that when rat
>is started it un-mutes the sound, so that the sound plays though the
>speakers. Ticking the mute box fixes this again.
>My problem is that every time rat is opened, or settings are changed,
>the mic feedbacks though the speakers, and I have to tick the mute box
>again.
>We are running a sound blaster live. We are using OSS because ALSA gives
>a distorted sound.
>This does not happen on our Fedora Access Grids, only our gentoo Access
>Grid.
>Anybody have any other ideas?
>Ashley
>Gavin W. Burris aka 86 wrote:
>>Sounds like you have to adjust your mixer to not play capture back
>>through. If you are not using ALSA, then I would highly recommend it.
>>My notes, including mixer screen-grabs, here:
>>http://viz.aset.psu.edu/ga5in/AccessGridNodeOperation.html#audio
>>Ashley Wright wrote (on Mon, 14 Mar 2005 at 09:09):
>>>Hi,
>>>We have set up a single computer accessgrid using Gentoo Linux. We
>have
>>>used the official AG2.3 toolkit.
>>>My problem is that every time a new rat is opened (changing venue etc)
>>>or a setting is changed, rat unmutes the microphone and the mic plays
>>>directly into the speakers. This causes feedback though the mic and
>>>speakers. I then need to remute the mic in the gnome volume control to
>>>get rid of the feedback.
>>>Does anybody have any ideas of what could be causing this, and a
>>>suggested fix.
>>>Thanks,
>>>Ashley
>>>Ashley Wright
>>>3864 9264
>>>HPC and Research Support Group
>>>Queensland University of Technology (QUT)
Ashley Wright
3864 9264
