[AG-TECH] Problem with mic, rat and gentoo
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 14 22:44:12 CST 2005
This is a characteristic of AC97 based cards. Rat handles some of them by hardcoding;
others can be handled by setting the OSS_IS_AC97 environment variable.
export OSS_IS_AC97=1 (for sh)
setenv OSS_IS_AC97 1 (for csh)
Hopefully this fixes the problem.
Tom
Ashley Wright wrote:
> Hi Jason,
> This was the first thing I tried, I prefer the talk to start muted,
> however the setting made no difference.
> This is a strange problem. I have had a look in the AudioService script
> (inside AudioService.zip) but cant find anything I would think would
> make a difference.
> Ashley
> Jason Bell wrote:
>> Hi Ashley
>> Have you tried editing the audio service settings through the "manage my
>> node" configuration tool????
>> You have the ability to change the input and output levels as well as
>> turning talk on and off.
>> These setting may help as well.
>> Cheers,
>> Jason.
>> Jason Bell, B.I.T.
>> B. Info. Tech. (Honours) Student
>> Network Engineer
>> Information Technology Division
>> Central Queensland University
>> High Performance Computing Support Officer
>> Research Assistant to the Nonlinear Intelligent Systems Research Group
>> Faculty of Informatics & Communication
>> E-mail : j.bell at cqu.edu.au
>> Phone : 07 4930 9229
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
>> -----Original Message-----
>> From: Ashley Wright [mailto:a2.wright at qut.edu.au] Sent: Tuesday, 15
>> March 2005 12:55
>> To: Jason Bell; 'ag-tech at mcs.anl.gov'
>> Subject: Re: [AG-TECH] Problem with mic, rat and gentoo
>> Hi Jason,
>> This looks good, I have found the file and the setting "*audioInputMute:
>> 1" However if I set this to 0, next time the Venue Client opens the
>> RAT it is set make to 1.
>> Also interesting, if I open RAT with the command "rat
>> xxx.xxx.xxx.xxx/xxx" the mic setting is left unchanged (this is good),
>> however if it is opened with the Venue Client then I still get the
>> feedback. This is making me think the venue client is doing something
>> I do not want it to do.
>> Any more ideas?
>> Ashley
>> Jason Bell wrote:
>>> Hi Ashley
>>> There is a RatDefaults file in the home directory (Well there is for
>>> fedora anyway), you might want to changes some of the settings in that
>>> file so that when "rat" starts up, none of your settings are changed.
>>> Hope this helps.
>>> Cheers,
>>> Jason.
>>> Jason Bell, B.I.T.
>>> Network Engineer
>>> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>> Behalf Of Ashley Wright
>>> Sent: Tuesday, 15 March 2005 11:59
>>> To: ag-tech at mcs.anl.gov
>>> Hi,
>>> Normally in the mixer (gnome volume control), we have the mic input
>>> muted, with the record ticked. This works. Our problem is that when rat
>>> is started it un-mutes the sound, so that the sound plays though the
>>> speakers. Ticking the mute box fixes this again.
>>> My problem is that every time rat is opened, or settings are changed,
>>> the mic feedbacks though the speakers, and I have to tick the mute
>>> box again.
>>> We are running a sound blaster live. We are using OSS because ALSA
>> gives
>>> a distorted sound.
>>> This does not happen on our Fedora Access Grids, only our gentoo Access
>>> Grid.
>>> Anybody have any other ideas?
>>> Ashley
>>> Gavin W. Burris aka 86 wrote:
>>>> Sounds like you have to adjust your mixer to not play capture back
>>>> through. If you are not using ALSA, then I would highly recommend it.
>>>> My notes, including mixer screen-grabs, here:
>>>> http://viz.aset.psu.edu/ga5in/AccessGridNodeOperation.html#audio
>>>> Ashley Wright wrote (on Mon, 14 Mar 2005 at 09:09):
>>>>> Hi,
>>>>> We have set up a single computer accessgrid using Gentoo Linux. We
>>> have
>>>>> used the official AG2.3 toolkit.
>>>>> My problem is that every time a new rat is opened (changing venue
>> etc)
>>>>> or a setting is changed, rat unmutes the microphone and the mic plays
>>>>> directly into the speakers. This causes feedback though the mic and
>>>>> speakers. I then need to remute the mic in the gnome volume control
>> to
>>>>> get rid of the feedback.
>>>>> Does anybody have any ideas of what could be causing this, and a
>>>>> suggested fix.
>>>>> Thanks,
>>>>> Ashley
>>>>> Ashley Wright
>>>>> 3864 9264
>>>>> HPC and Research Support Group
>>>>> Queensland University of Technology (QUT)
