[AG-TECH] Node stuck on startup
Michael daley
Mike.W.Daley at cs.cardiff.ac.uk
Thu Mar 10 08:55:30 CST 2005
It has only occurred in the last few weeks as I recall. But on a regular
basis.
I have not looked at the logs.
I'll do that and see if I can spot anything.
So far this week all has been well.
Mike
Thomas D. Uram wrote:
> Mike:
> Is there any indication of a problem in a part of the logfile that you
> didn't include? If you don't see anything obvious, you can send the
> log and I'll take a look.
> Can you reproduce the problem reliably?
> Tom
> Michael Miller wrote:
>> Michael,
>> Yes, I've seen that behavior as well, but in this case, shutting down
>> all the python processes didn't fix things.
>> Any other ideas?
>> MYK
>> At 03:03 AM 3/8/2005, Michael daley wrote:
>>> We have been seeing a similar problem. Having done a bit of snooping
>>> around. It looks as if the Venue Client does not always shut down
>>> cleanly. On my display machine (Which starts all the other
>>> machines). If you look at the processes running. You fine that
>>> Python may still be running several processes after the Client has
>>> been closed. If you kill these processes the Node restarts OK. I
>>> have been meaning to post this to see if others have seen the same
>>> problem.
>>> Mike
>>> Cardiff Node Op
>>>> We had a problem with a node getting stuck when starting up. I
>>>> narrowed it down to the AGServiceManager on the video machine.
>>>> Restarting the AGServiceManager.py solved the problem. Is this in
>>>> bugzilla? Anyone know what's happening here that would cause the
>>>> node to get stuck?
>>>> Michael Miller
>>>> NCSA
>>>> 03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 INFO
>>>> AddService: VideoProducerService v 2.500000 u VideoProducerService.zip
>>>> resourceToAssign: /dev/video0
>>>> Retaining version 2.500000
>>>> Extracting service package to
>>>> /home/agnode/.AccessGrid/local_services/VideoProducerService
>>>> Running Service; options: /usr/bin/python2
>>>> ['/home/agnode/.AccessGrid/local_services/VideoProducerService/VideoProducerService.py',
>>>> 64126]
>>>> DEBUG Waiting for service to start: VideoProducerService
>>>> https://rel-ag-video.ncsa.uiuc.edu:64126/Service
>>>> 03/03/05 14:23:32 -189228112 ServiceManager __init__.py:988 INFO
>>>> Service VideoProducerService successfully started
>>>> Setting service configuration
>>>> Assigning resource to service: /dev/video0
>>>> 03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.AddService
>>>> resourceToAssign: /dev/video1
>>>> 49279]
>>>> https://rel-ag-video.ncsa.uiuc.edu:49279/Service
>>>> 03/03/05 14:23:35 -189228112 ServiceManager __init__.py:988 INFO
>>>> Assigning resource to service: /dev/video1
>>>> 03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 INFO
>>>> resourceToAssign: /dev/video2
>>>> 64268]
>>>> https://rel-ag-video.ncsa.uiuc.edu:64268/Service
>>>> 03/03/05 14:23:38 -189228112 ServiceManager __init__.py:988 INFO
>>>> Assigning resource to service: /dev/video2
>>>> 03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 INFO
>>>> resourceToAssign: /dev/video3
>>>> 59359]
>>>> https://rel-ag-video.ncsa.uiuc.edu:59359/Service
>>>> 03/03/05 14:23:41 -189228112 ServiceManager __init__.py:988 INFO
>>>> Assigning resource to service: /dev/video3
>>>> 03/03/05 14:23:46 -189228112 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.GetServices
>>>> 03/03/05 14:23:52 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:23:56 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:24:08 -189228112 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.StopServices
>>>> 03/03/05 14:24:15 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:24:18 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:24:24 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:25:21 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/03/05 14:25:27 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:42:44 -178680912 Hosting __init__.py:988 ERROR
>>>> Exception in SOAP server main loop
>>>> Traceback (most recent call last):
>>>> File
>>>> "/usr/lib/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
>>>> line 63, in Run
>>>> self._server.handle_request()
>>>> File
>>>> "/usr/src/build/394694-i386/install/usr/lib/python2.3/SocketServer.py",
>>>> line 217, in handle_request
>>>> request, client_address = self.get_request()
>>>> File "/usr/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line
>>>> 140, in get_request
>>>> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
>>>> File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 850,
>>>> in get_request
>>>> raise ex.args
>>>> an end-of-file was reached
>>>> 03/04/05 15:45:28 -189228112 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.RemoveServices
>>>> 03/04/05 15:45:29 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:30 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:32 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:33 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 INFO
>>>> 50259]
>>>> https://rel-ag-video.ncsa.uiuc.edu:50259/Service
>>>> 03/04/05 15:45:36 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 INFO
>>>> 59508]
>>>> https://rel-ag-video.ncsa.uiuc.edu:59508/Service
>>>> 03/04/05 15:45:40 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 INFO
>>>> 51060]
>>>> https://rel-ag-video.ncsa.uiuc.edu:51060/Service
>>>> 03/04/05 15:45:43 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 INFO
>>>> 57285]
>>>> https://rel-ag-video.ncsa.uiuc.edu:57285/Service
>>>> 03/04/05 15:45:47 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:45:58 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:46:00 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:46:05 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 15:46:11 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 16:09:49 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/04/05 16:09:56 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:56:31 -178680912 Hosting __init__.py:988 ERROR
>>>> File
>>>> line 63, in Run
>>>> File
>>>> 140, in get_request
>>>> in get_request
>>>> raise ex.args
>>>> 03/07/05 11:59:26 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:27 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:28 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:30 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 INFO
>>>> 61900]
>>>> https://rel-ag-video.ncsa.uiuc.edu:61900/Service
>>>> 03/07/05 11:59:34 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:35 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 INFO
>>>> 61787]
>>>> https://rel-ag-video.ncsa.uiuc.edu:61787/Service
>>>> 03/07/05 11:59:37 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:38 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 INFO
>>>> 51231]
>>>> https://rel-ag-video.ncsa.uiuc.edu:51231/Service
>>>> 03/07/05 11:59:40 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:41 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 INFO
>>>> 61579]
>>>> https://rel-ag-video.ncsa.uiuc.edu:61579/Service
>>>> 03/07/05 11:59:43 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 11:59:44 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:00:01 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:00:07 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:00:12 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:00:53 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:01:22 -189228112 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:06:16 -233669712 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:06:17 -233669712 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:06:19 -233669712 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:10:42 -244364368 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:11:24 -254985296 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:21:11 -265606224 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:30:51 -276227152 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:34:40 -286848080 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:37:30 -297469008 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:38:35 -308089936 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:39:41 -318710864 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:40:25 -329331792 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:42:49 -339952720 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:51:40 -350573648 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO
>>>> Caught signal, going down.
>>>> Signal: 1 Frame: <frame object at 0x845dc1c>
>>>> 03/07/05 12:53:11 -150088192 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.Shutdown
>>>> Remove services
>>>> 03/07/05 12:54:23 -150641152 ProxyGen __init__.py:988 DEBUG
>>>> Using GT24 proxy code
>>>> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 DEBUG
>>>> Initializing AG Toolkit version 2.3
>>>> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 INFO
>>>> Logfile Name: ServiceManager.log
>>>> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO
>>>> Service init: have profile None
>>>> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 DEBUG
>>>> System hostname of rel-ag-video.ncsa.uiuc.edu is valid
>>>> 03/07/05 12:54:24 -150641152 CertificateManager __init__.py:988
>>>> DEBUG Opened repository /home/agnode/.AccessGrid/Config/certRepo
>>>> Initialized cert mgmt.
>>>> Loaded profile and configured with it.
>>>> DEBUG Configuring standard environment
>>>> DEBUG Using default identity /O=Access
>>>> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.ncsa.uiuc.edu
>>>> DEBUG Initializing environment with unencrypted cert /O=Access
>>>> DEBUG done, success=1
>>>> Initialized Globus.
>>>> Service Initialization Complete.
>>>> 03/07/05 12:54:24 -150641152 ServiceManager __init__.py:988 INFO
>>>> Using services dir: /home/agnode/.AccessGrid/local_services
>>>> __DiscoverResources
>>>> 03/07/05 12:54:24 -150641152 Platform __init__.py:988 INFO V4L
>>>> /dev/video2 description: BT878 video (Osprey 100/150 (87
>>>> /dev/video2 has ports: ['Composite0', 'Composite1', 'Composite2',
>>>> 'S-Video']
>>>> /dev/video3 description: BT878 video (Osprey 100/150 (87
>>>> /dev/video3 has ports: ['Composite0', 'Composite1', 'Composite2',
>>>> 'S-Video']
>>>> /dev/video1 description: BT878 video (Osprey 100/150 (87
>>>> /dev/video1 has ports: ['Composite0', 'Composite1', 'Composite2',
>>>> 'S-Video']
>>>> /dev/video0 description: BT878 video (Osprey 100/150 (87
>>>> /dev/video0 has ports: ['Composite0', 'Composite1', 'Composite2',
>>>> 'S-Video']
>>>> Starting Service Manager URL:
>>>> https://rel-ag-video.ncsa.uiuc.edu:11000/ServiceManager
>>>> 03/07/05 12:55:17 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:55:23 -189781072 ServiceManager __init__.py:988 INFO
>>>> AGServiceManager.GetResources
>>>> __DiscoverResources
>>>> 03/07/05 12:55:23 -189781072 Platform __init__.py:988 INFO V4L
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 INFO
>>>> 62100]
>>>> https://rel-ag-video.ncsa.uiuc.edu:62100/Service
>>>> 03/07/05 12:55:26 -189781072 Toolkit __init__.py:988 DEBUG
>>>> 03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 INFO
>>>> DEBUG Not setting service configuration; none given
>>>> 03/07/05 12:55:29 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:55:37 -189781072 ServiceManager __init__.py:988 INFO
>>>> __DiscoverResources
>>>> 03/07/05 12:55:37 -189781072 Platform __init__.py:988 INFO V4L
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 INFO
>>>> 62452]
>>>> https://rel-ag-video.ncsa.uiuc.edu:62452/Service
>>>> 03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:55:44 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:55:54 -189781072 ServiceManager __init__.py:988 INFO
>>>> __DiscoverResources
>>>> 03/07/05 12:55:54 -189781072 Platform __init__.py:988 INFO V4L
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 INFO
>>>> 63206]
>>>> https://rel-ag-video.ncsa.uiuc.edu:63206/Service
>>>> 03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:56:01 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:56:09 -189781072 ServiceManager __init__.py:988 INFO
>>>> __DiscoverResources
>>>> 03/07/05 12:56:09 -189781072 Platform __init__.py:988 INFO V4L
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 'S-Video']
>>>> 03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 INFO
>>>> 57859]
>>>> https://rel-ag-video.ncsa.uiuc.edu:57859/Service
>>>> 03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:56:21 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:56:38 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:57:02 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:57:12 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:57:16 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:58:24 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:58:30 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:58:35 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:58:43 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:59:17 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:59:24 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:59:28 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 12:59:34 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:00:03 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:00:10 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:01 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:02 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:04 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:05 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 INFO
>>>> 55780]
>>>> https://rel-ag-video.ncsa.uiuc.edu:55780/Service
>>>> 03/07/05 13:01:08 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:09 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 INFO
>>>> 52102]
>>>> https://rel-ag-video.ncsa.uiuc.edu:52102/Service
>>>> 03/07/05 13:01:11 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:12 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 INFO
>>>> 51524]
>>>> https://rel-ag-video.ncsa.uiuc.edu:51524/Service
>>>> 03/07/05 13:01:14 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:15 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 INFO
>>>> 53834]
>>>> https://rel-ag-video.ncsa.uiuc.edu:53834/Service
>>>> 03/07/05 13:01:17 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:18 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:31 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:38 -189781072 ServiceManager __init__.py:988 INFO
>>>> 03/07/05 13:01:41 -189781072 ServiceManager __init__.py:988 INFO
>>>> Thanx,
>>>> Michael Miller
>>>> System Engineer
>>>> Video Technology Services
>>>> Persistent Infrastructure Directorate
>>>> National Center for Supercomputing Applications
>>>> University of Illinois - UC
>>>> 217-649-0747
>>>> "If you're clear in your vision and trust the people in your team
>>>> with clear objectives, they will invariably do their best to
>>>> achieve everything desired, and usually deliver everything you
>>>> could have hoped for and even more." -Paul Debevec
>> Thanx,
>> Michael Miller
>> System Engineer
>> 217-649-0747
>> with clear objectives, they will invariably do their best to achieve
>> everything desired, and usually deliver everything you could have
