[AG-TECH] Node stuck on startup
Thomas D. Uram
turam at mcs.anl.gov
Thu Mar 10 08:16:38 CST 2005
Mike:
Is there any indication of a problem in a part of the logfile that you didn't include? If
you don't see anything obvious, you can send the log and I'll take a look.
Can you reproduce the problem reliably?
Tom
Michael Miller wrote:
> Michael,
> Yes, I've seen that behavior as well, but in this case, shutting down
> all the python processes didn't fix things.
> Any other ideas?
> MYK
> At 03:03 AM 3/8/2005, Michael daley wrote:
>> We have been seeing a similar problem. Having done a bit of snooping
>> around. It looks as if the Venue Client does not always shut down
>> cleanly. On my display machine (Which starts all the other machines).
>> If you look at the processes running. You fine that Python may still
>> be running several processes after the Client has been closed. If you
>> kill these processes the Node restarts OK. I have been meaning to post
>> this to see if others have seen the same problem.
>> Mike
>> Cardiff Node Op
>>> We had a problem with a node getting stuck when starting up. I
>>> narrowed it down to the AGServiceManager on the video machine.
>>> Restarting the AGServiceManager.py solved the problem. Is this in
>>> bugzilla? Anyone know what's happening here that would cause the
>>> node to get stuck?
>>> Michael Miller
>>> NCSA
>>> 03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 INFO
>>> AddService: VideoProducerService v 2.500000 u VideoProducerService.zip
>>> resourceToAssign: /dev/video0
>>> Retaining version 2.500000
>>> Extracting service package to
>>> /home/agnode/.AccessGrid/local_services/VideoProducerService
>>> Running Service; options: /usr/bin/python2
>>> ['/home/agnode/.AccessGrid/local_services/VideoProducerService/VideoProducerService.py',
>>> 64126]
>>> 03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 DEBUG
>>> Waiting for service to start: VideoProducerService
>>> https://rel-ag-video.ncsa.uiuc.edu:64126/Service
>>> 03/03/05 14:23:32 -189228112 ServiceManager __init__.py:988 INFO
>>> Service VideoProducerService successfully started
>>> Setting service configuration
>>> Assigning resource to service: /dev/video0
>>> 03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.AddService
>>> resourceToAssign: /dev/video1
>>> 49279]
>>> 03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:49279/Service
>>> 03/03/05 14:23:35 -189228112 ServiceManager __init__.py:988 INFO
>>> Assigning resource to service: /dev/video1
>>> 03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 INFO
>>> resourceToAssign: /dev/video2
>>> 64268]
>>> 03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:64268/Service
>>> 03/03/05 14:23:38 -189228112 ServiceManager __init__.py:988 INFO
>>> Assigning resource to service: /dev/video2
>>> 03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 INFO
>>> resourceToAssign: /dev/video3
>>> 59359]
>>> 03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:59359/Service
>>> 03/03/05 14:23:41 -189228112 ServiceManager __init__.py:988 INFO
>>> Assigning resource to service: /dev/video3
>>> 03/03/05 14:23:46 -189228112 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.GetServices
>>> 03/03/05 14:23:52 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:23:56 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:24:08 -189228112 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.StopServices
>>> 03/03/05 14:24:15 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:24:18 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:24:24 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:25:21 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/03/05 14:25:27 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:42:44 -178680912 Hosting __init__.py:988 ERROR
>>> Exception in SOAP server main loop
>>> Traceback (most recent call last):
>>> File
>>> "/usr/lib/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
>>> line 63, in Run
>>> self._server.handle_request()
>>> File
>>> "/usr/src/build/394694-i386/install/usr/lib/python2.3/SocketServer.py",
>>> line 217, in handle_request
>>> request, client_address = self.get_request()
>>> File "/usr/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line
>>> 140, in get_request
>>> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
>>> File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 850,
>>> in get_request
>>> raise ex.args
>>> an end-of-file was reached
>>> 03/04/05 15:45:28 -189228112 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.RemoveServices
>>> 03/04/05 15:45:29 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:30 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:32 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:33 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 INFO
>>> 50259]
>>> 03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:50259/Service
>>> 03/04/05 15:45:36 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 INFO
>>> 59508]
>>> 03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:59508/Service
>>> 03/04/05 15:45:40 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 INFO
>>> 51060]
>>> 03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:51060/Service
>>> 03/04/05 15:45:43 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 INFO
>>> 57285]
>>> 03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:57285/Service
>>> 03/04/05 15:45:47 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:45:58 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:46:00 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:46:05 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 15:46:11 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 16:09:49 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/04/05 16:09:56 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:56:31 -178680912 Hosting __init__.py:988 ERROR
>>> File
>>> line 63, in Run
>>> File
>>> 140, in get_request
>>> in get_request
>>> raise ex.args
>>> 03/07/05 11:59:26 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:27 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:28 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:30 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 INFO
>>> 61900]
>>> 03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:61900/Service
>>> 03/07/05 11:59:34 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:35 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 INFO
>>> 61787]
>>> 03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:61787/Service
>>> 03/07/05 11:59:37 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:38 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 INFO
>>> 51231]
>>> 03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:51231/Service
>>> 03/07/05 11:59:40 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:41 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 INFO
>>> 61579]
>>> 03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:61579/Service
>>> 03/07/05 11:59:43 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 11:59:44 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:00:01 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:00:07 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:00:12 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:00:53 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:01:22 -189228112 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:06:16 -233669712 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:06:17 -233669712 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:06:19 -233669712 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:10:42 -244364368 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:11:24 -254985296 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:21:11 -265606224 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:30:51 -276227152 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:34:40 -286848080 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:37:30 -297469008 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:38:35 -308089936 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:39:41 -318710864 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:40:25 -329331792 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:42:49 -339952720 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:51:40 -350573648 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Caught
>>> signal, going down.
>>> Signal: 1 Frame: <frame object at 0x845dc1c>
>>> 03/07/05 12:53:11 -150088192 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.Shutdown
>>> Remove services
>>> 03/07/05 12:54:23 -150641152 ProxyGen __init__.py:988 DEBUG Using
>>> GT24 proxy code
>>> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 DEBUG
>>> Initializing AG Toolkit version 2.3
>>> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 INFO
>>> Logfile Name: ServiceManager.log
>>> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO
>>> Service init: have profile None
>>> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 DEBUG System
>>> hostname of rel-ag-video.ncsa.uiuc.edu is valid
>>> 03/07/05 12:54:24 -150641152 CertificateManager __init__.py:988
>>> DEBUG Opened repository /home/agnode/.AccessGrid/Config/certRepo
>>> Initialized cert mgmt.
>>> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Loaded
>>> profile and configured with it.
>>> DEBUG Configuring standard environment
>>> DEBUG Using default identity /O=Access
>>> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.ncsa.uiuc.edu
>>> DEBUG Initializing environment with unencrypted cert /O=Access
>>> DEBUG done, success=1
>>> Initialized Globus.
>>> Service Initialization Complete.
>>> 03/07/05 12:54:24 -150641152 ServiceManager __init__.py:988 INFO
>>> Using services dir: /home/agnode/.AccessGrid/local_services
>>> __DiscoverResources
>>> 03/07/05 12:54:24 -150641152 Platform __init__.py:988 INFO V4L
>>> /dev/video2 description: BT878 video (Osprey 100/150 (87
>>> /dev/video2 has ports: ['Composite0', 'Composite1', 'Composite2',
>>> 'S-Video']
>>> /dev/video3 description: BT878 video (Osprey 100/150 (87
>>> /dev/video3 has ports: ['Composite0', 'Composite1', 'Composite2',
>>> 'S-Video']
>>> /dev/video1 description: BT878 video (Osprey 100/150 (87
>>> /dev/video1 has ports: ['Composite0', 'Composite1', 'Composite2',
>>> 'S-Video']
>>> /dev/video0 description: BT878 video (Osprey 100/150 (87
>>> /dev/video0 has ports: ['Composite0', 'Composite1', 'Composite2',
>>> 'S-Video']
>>> Starting Service Manager URL:
>>> https://rel-ag-video.ncsa.uiuc.edu:11000/ServiceManager
>>> 03/07/05 12:55:17 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:23 -189781072 ServiceManager __init__.py:988 INFO
>>> AGServiceManager.GetResources
>>> __DiscoverResources
>>> 03/07/05 12:55:23 -189781072 Platform __init__.py:988 INFO V4L
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 INFO
>>> 62100]
>>> 03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:62100/Service
>>> 03/07/05 12:55:26 -189781072 Toolkit __init__.py:988 DEBUG
>>> 03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 DEBUG
>>> Not setting service configuration; none given
>>> 03/07/05 12:55:29 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:37 -189781072 ServiceManager __init__.py:988 INFO
>>> __DiscoverResources
>>> 03/07/05 12:55:37 -189781072 Platform __init__.py:988 INFO V4L
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 INFO
>>> 62452]
>>> 03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:62452/Service
>>> 03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 DEBUG
>>> 03/07/05 12:55:44 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:54 -189781072 ServiceManager __init__.py:988 INFO
>>> __DiscoverResources
>>> 03/07/05 12:55:54 -189781072 Platform __init__.py:988 INFO V4L
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 INFO
>>> 63206]
>>> 03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:63206/Service
>>> 03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 DEBUG
>>> 03/07/05 12:56:01 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:56:09 -189781072 ServiceManager __init__.py:988 INFO
>>> __DiscoverResources
>>> 03/07/05 12:56:09 -189781072 Platform __init__.py:988 INFO V4L
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 'S-Video']
>>> 03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 INFO
>>> 57859]
>>> 03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:57859/Service
>>> 03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 DEBUG
>>> 03/07/05 12:56:21 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:56:38 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:57:02 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:57:12 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:57:16 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:58:24 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:58:30 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:58:35 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:58:43 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:59:17 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:59:24 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:59:28 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 12:59:34 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:00:03 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:00:10 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:01 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:02 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:04 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:05 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 INFO
>>> 55780]
>>> 03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:55780/Service
>>> 03/07/05 13:01:08 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:09 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 INFO
>>> 52102]
>>> 03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:52102/Service
>>> 03/07/05 13:01:11 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:12 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 INFO
>>> 51524]
>>> 03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:51524/Service
>>> 03/07/05 13:01:14 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:15 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 INFO
>>> 53834]
>>> 03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 DEBUG
>>> https://rel-ag-video.ncsa.uiuc.edu:53834/Service
>>> 03/07/05 13:01:17 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:18 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:31 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:38 -189781072 ServiceManager __init__.py:988 INFO
>>> 03/07/05 13:01:41 -189781072 ServiceManager __init__.py:988 INFO
>>> Thanx,
>>> Michael Miller
>>> System Engineer
>>> Video Technology Services
>>> Persistent Infrastructure Directorate
>>> National Center for Supercomputing Applications
>>> University of Illinois - UC
>>> 217-649-0747
>>> "If you're clear in your vision and trust the people in your team
>>> with clear objectives, they will invariably do their best to achieve
>>> everything desired, and usually deliver everything you could have
>>> hoped for and even more." -Paul Debevec
> Thanx,
> Michael Miller
> System Engineer
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> everything desired, and usually deliver everything you could have hoped
