[AG-TECH] Node stuck on startup
Michael Miller
myk at ncsa.uiuc.edu
Thu Mar 10 07:59:21 CST 2005
Michael,
Yes, I've seen that behavior as well, but in this case, shutting down all
the python processes didn't fix things.
Any other ideas?
MYK
At 03:03 AM 3/8/2005, Michael daley wrote:
>We have been seeing a similar problem. Having done a bit of snooping
>around. It looks as if the Venue Client does not always shut down cleanly.
>On my display machine (Which starts all the other machines). If you look
>at the processes running. You fine that Python may still be running
>several processes after the Client has been closed. If you kill these
>processes the Node restarts OK. I have been meaning to post this to see if
>others have seen the same problem.
>Mike
>Cardiff Node Op
>Michael Miller wrote:
>>We had a problem with a node getting stuck when starting up. I narrowed
>>it down to the AGServiceManager on the video machine.
>>Restarting the AGServiceManager.py solved the problem. Is this in
>>bugzilla? Anyone know what's happening here that would cause the node to
>>get stuck?
>>Michael Miller
>>NCSA
>>03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 INFO
>>AddService: VideoProducerService v 2.500000 u VideoProducerService.zip
>>resourceToAssign: /dev/video0
>>Retaining version 2.500000
>>Extracting service package to
>>/home/agnode/.AccessGrid/local_services/VideoProducerService
>>Running Service; options: /usr/bin/python2
>>['/home/agnode/.AccessGrid/local_services/VideoProducerService/VideoProducerService.py',
>>64126]
>>03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 DEBUG
>>Waiting for service to start: VideoProducerService
>>https://rel-ag-video.ncsa.uiuc.edu:64126/Service
>>03/03/05 14:23:32 -189228112 ServiceManager __init__.py:988 INFO
>>Service VideoProducerService successfully started
>>Setting service configuration
>>Assigning resource to service: /dev/video0
>>03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 INFO
>>AGServiceManager.AddService
>>resourceToAssign: /dev/video1
>>49279]
>>03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:49279/Service
>>03/03/05 14:23:35 -189228112 ServiceManager __init__.py:988 INFO
>>Assigning resource to service: /dev/video1
>>03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 INFO
>>resourceToAssign: /dev/video2
>>64268]
>>03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:64268/Service
>>03/03/05 14:23:38 -189228112 ServiceManager __init__.py:988 INFO
>>Assigning resource to service: /dev/video2
>>03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 INFO
>>resourceToAssign: /dev/video3
>>59359]
>>03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:59359/Service
>>03/03/05 14:23:41 -189228112 ServiceManager __init__.py:988 INFO
>>Assigning resource to service: /dev/video3
>>03/03/05 14:23:46 -189228112 ServiceManager __init__.py:988 INFO
>>AGServiceManager.GetServices
>>03/03/05 14:23:52 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:23:56 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:24:08 -189228112 ServiceManager __init__.py:988 INFO
>>AGServiceManager.StopServices
>>03/03/05 14:24:15 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:24:18 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:24:24 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:25:21 -189228112 ServiceManager __init__.py:988 INFO
>>03/03/05 14:25:27 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:42:44 -178680912 Hosting __init__.py:988 ERROR Exception
>>in SOAP server main loop
>>Traceback (most recent call last):
>> File
>> "/usr/lib/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
>> line 63, in Run
>> self._server.handle_request()
>> File
>> "/usr/src/build/394694-i386/install/usr/lib/python2.3/SocketServer.py",
>> line 217, in handle_request
>> request, client_address = self.get_request()
>> File "/usr/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line 140,
>> in get_request
>> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
>> File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 850, in
>> get_request
>> raise ex.args
>>an end-of-file was reached
>>03/04/05 15:45:28 -189228112 ServiceManager __init__.py:988 INFO
>>AGServiceManager.RemoveServices
>>03/04/05 15:45:29 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:30 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:32 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:33 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 INFO
>>50259]
>>03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:50259/Service
>>03/04/05 15:45:36 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 INFO
>>59508]
>>03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:59508/Service
>>03/04/05 15:45:40 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 INFO
>>51060]
>>03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:51060/Service
>>03/04/05 15:45:43 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 INFO
>>57285]
>>03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:57285/Service
>>03/04/05 15:45:47 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:45:58 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:46:00 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:46:05 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 15:46:11 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 16:09:49 -189228112 ServiceManager __init__.py:988 INFO
>>03/04/05 16:09:56 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:56:31 -178680912 Hosting __init__.py:988 ERROR Exception
>> File
>> line 63, in Run
>> File
>> in get_request
>> get_request
>> raise ex.args
>>03/07/05 11:59:26 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:27 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:28 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:30 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 INFO
>>61900]
>>03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:61900/Service
>>03/07/05 11:59:34 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:35 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 INFO
>>61787]
>>03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:61787/Service
>>03/07/05 11:59:37 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:38 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 INFO
>>51231]
>>03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:51231/Service
>>03/07/05 11:59:40 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:41 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 INFO
>>61579]
>>03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:61579/Service
>>03/07/05 11:59:43 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 11:59:44 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:00:01 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:00:07 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:00:12 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:00:53 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:01:22 -189228112 ServiceManager __init__.py:988 INFO
>>03/07/05 12:06:16 -233669712 ServiceManager __init__.py:988 INFO
>>03/07/05 12:06:17 -233669712 ServiceManager __init__.py:988 INFO
>>03/07/05 12:06:19 -233669712 ServiceManager __init__.py:988 INFO
>>03/07/05 12:10:42 -244364368 ServiceManager __init__.py:988 INFO
>>03/07/05 12:11:24 -254985296 ServiceManager __init__.py:988 INFO
>>03/07/05 12:21:11 -265606224 ServiceManager __init__.py:988 INFO
>>03/07/05 12:30:51 -276227152 ServiceManager __init__.py:988 INFO
>>03/07/05 12:34:40 -286848080 ServiceManager __init__.py:988 INFO
>>03/07/05 12:37:30 -297469008 ServiceManager __init__.py:988 INFO
>>03/07/05 12:38:35 -308089936 ServiceManager __init__.py:988 INFO
>>03/07/05 12:39:41 -318710864 ServiceManager __init__.py:988 INFO
>>03/07/05 12:40:25 -329331792 ServiceManager __init__.py:988 INFO
>>03/07/05 12:42:49 -339952720 ServiceManager __init__.py:988 INFO
>>03/07/05 12:51:40 -350573648 ServiceManager __init__.py:988 INFO
>>03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Caught
>>signal, going down.
>>03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Signal: 1
>>Frame: <frame object at 0x845dc1c>
>>03/07/05 12:53:11 -150088192 ServiceManager __init__.py:988 INFO
>>AGServiceManager.Shutdown
>>Remove services
>>03/07/05 12:54:23 -150641152 ProxyGen __init__.py:988 DEBUG Using
>>GT24 proxy code
>>03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 DEBUG
>>Initializing AG Toolkit version 2.3
>>03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 INFO Logfile
>>03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Service
>>init: have profile None
>>03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 DEBUG System
>>hostname of rel-ag-video.ncsa.uiuc.edu is valid
>>03/07/05 12:54:24 -150641152 CertificateManager __init__.py:988 DEBUG
>>Opened repository /home/agnode/.AccessGrid/Config/certRepo
>>Initialized cert mgmt.
>>03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Loaded
>>profile and configured with it.
>>Configuring standard environment
>>Using default identity /O=Access
>>Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.ncsa.uiuc.edu
>>Initializing environment with unencrypted cert /O=Access
>>done, success=1
>>Initialized Globus.
>>Initialization Complete.
>>03/07/05 12:54:24 -150641152 ServiceManager __init__.py:988 INFO
>>Using services dir: /home/agnode/.AccessGrid/local_services
>>__DiscoverResources
>>03/07/05 12:54:24 -150641152 Platform __init__.py:988 INFO V4L
>>/dev/video2 description: BT878 video (Osprey 100/150 (87
>>/dev/video2 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
>>/dev/video3 description: BT878 video (Osprey 100/150 (87
>>/dev/video3 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
>>/dev/video1 description: BT878 video (Osprey 100/150 (87
>>/dev/video1 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
>>/dev/video0 description: BT878 video (Osprey 100/150 (87
>>/dev/video0 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
>>Starting Service Manager URL:
>>https://rel-ag-video.ncsa.uiuc.edu:11000/ServiceManager
>>03/07/05 12:55:17 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:23 -189781072 ServiceManager __init__.py:988 INFO
>>AGServiceManager.GetResources
>>__DiscoverResources
>>03/07/05 12:55:23 -189781072 Platform __init__.py:988 INFO V4L
>>03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 INFO
>>62100]
>>03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:62100/Service
>>03/07/05 12:55:26 -189781072 Toolkit __init__.py:988 DEBUG
>>03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 DEBUG Not
>>setting service configuration; none given
>>03/07/05 12:55:29 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:37 -189781072 ServiceManager __init__.py:988 INFO
>>__DiscoverResources
>>03/07/05 12:55:37 -189781072 Platform __init__.py:988 INFO V4L
>>03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 INFO
>>62452]
>>03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:62452/Service
>>03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 DEBUG Not
>>03/07/05 12:55:44 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:54 -189781072 ServiceManager __init__.py:988 INFO
>>__DiscoverResources
>>03/07/05 12:55:54 -189781072 Platform __init__.py:988 INFO V4L
>>03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 INFO
>>63206]
>>03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:63206/Service
>>03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 DEBUG Not
>>03/07/05 12:56:01 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:56:09 -189781072 ServiceManager __init__.py:988 INFO
>>__DiscoverResources
>>03/07/05 12:56:09 -189781072 Platform __init__.py:988 INFO V4L
>>03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 INFO
>>57859]
>>03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:57859/Service
>>03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 DEBUG Not
>>03/07/05 12:56:21 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:56:38 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:57:02 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:57:12 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:57:16 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:58:24 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:58:30 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:58:35 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:58:43 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:59:17 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:59:24 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:59:28 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 12:59:34 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:00:03 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:00:10 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:01 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:02 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:04 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:05 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 INFO
>>55780]
>>03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:55780/Service
>>03/07/05 13:01:08 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:09 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 INFO
>>52102]
>>03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:52102/Service
>>03/07/05 13:01:11 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:12 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 INFO
>>51524]
>>03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:51524/Service
>>03/07/05 13:01:14 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:15 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 INFO
>>53834]
>>03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 DEBUG
>>https://rel-ag-video.ncsa.uiuc.edu:53834/Service
>>03/07/05 13:01:17 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:18 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:31 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:38 -189781072 ServiceManager __init__.py:988 INFO
>>03/07/05 13:01:41 -189781072 ServiceManager __init__.py:988 INFO
>>Thanx,
>>Michael Miller
>>System Engineer
>>Video Technology Services
>>Persistent Infrastructure Directorate
>>National Center for Supercomputing Applications
>>University of Illinois - UC
>>217-649-0747
>>"If you're clear in your vision and trust the people in your team with
>>clear objectives, they will invariably do their best to achieve
>>everything desired, and usually deliver everything you could have hoped
>>for and even more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
