[AG-TECH] Node stuck on startup
Michael daley
Mike.W.Daley at cs.cardiff.ac.uk
Tue Mar 8 03:03:16 CST 2005
We have been seeing a similar problem. Having done a bit of snooping
around. It looks as if the Venue Client does not always shut down
cleanly. On my display machine (Which starts all the other machines). If
you look at the processes running. You fine that Python may still be
running several processes after the Client has been closed. If you kill
these processes the Node restarts OK. I have been meaning to post this
to see if others have seen the same problem.
Mike
Cardiff Node Op
Michael Miller wrote:
> We had a problem with a node getting stuck when starting up. I
> narrowed it down to the AGServiceManager on the video machine.
> Restarting the AGServiceManager.py solved the problem. Is this in
> bugzilla? Anyone know what's happening here that would cause the node
> to get stuck?
> Michael Miller
> NCSA
> 03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 INFO
> AddService: VideoProducerService v 2.500000 u VideoProducerService.zip
> resourceToAssign: /dev/video0
> Retaining version 2.500000
> Extracting service package to
> /home/agnode/.AccessGrid/local_services/VideoProducerService
> Running Service; options: /usr/bin/python2
> ['/home/agnode/.AccessGrid/local_services/VideoProducerService/VideoProducerService.py',
> 64126]
> 03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 DEBUG
> Waiting for service to start: VideoProducerService
> https://rel-ag-video.ncsa.uiuc.edu:64126/Service
> 03/03/05 14:23:32 -189228112 ServiceManager __init__.py:988 INFO
> Service VideoProducerService successfully started
> Setting service configuration
> Assigning resource to service: /dev/video0
> 03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 INFO
> AGServiceManager.AddService
> resourceToAssign: /dev/video1
> 49279]
> 03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:49279/Service
> 03/03/05 14:23:35 -189228112 ServiceManager __init__.py:988 INFO
> Assigning resource to service: /dev/video1
> 03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 INFO
> resourceToAssign: /dev/video2
> 64268]
> 03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:64268/Service
> 03/03/05 14:23:38 -189228112 ServiceManager __init__.py:988 INFO
> Assigning resource to service: /dev/video2
> 03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 INFO
> resourceToAssign: /dev/video3
> 59359]
> 03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:59359/Service
> 03/03/05 14:23:41 -189228112 ServiceManager __init__.py:988 INFO
> Assigning resource to service: /dev/video3
> 03/03/05 14:23:46 -189228112 ServiceManager __init__.py:988 INFO
> AGServiceManager.GetServices
> 03/03/05 14:23:52 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:23:56 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:24:08 -189228112 ServiceManager __init__.py:988 INFO
> AGServiceManager.StopServices
> 03/03/05 14:24:15 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:24:18 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:24:24 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:25:21 -189228112 ServiceManager __init__.py:988 INFO
> 03/03/05 14:25:27 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:42:44 -178680912 Hosting __init__.py:988 ERROR
> Exception in SOAP server main loop
> Traceback (most recent call last):
> File
> "/usr/lib/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
> line 63, in Run
> self._server.handle_request()
> File
> "/usr/src/build/394694-i386/install/usr/lib/python2.3/SocketServer.py",
> line 217, in handle_request
> request, client_address = self.get_request()
> File "/usr/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line
> 140, in get_request
> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 850, in
> get_request
> raise ex.args
> an end-of-file was reached
> 03/04/05 15:45:28 -189228112 ServiceManager __init__.py:988 INFO
> AGServiceManager.RemoveServices
> 03/04/05 15:45:29 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:30 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:32 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:33 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 INFO
> 50259]
> 03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:50259/Service
> 03/04/05 15:45:36 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 INFO
> 59508]
> 03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:59508/Service
> 03/04/05 15:45:40 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 INFO
> 51060]
> 03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:51060/Service
> 03/04/05 15:45:43 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 INFO
> 57285]
> 03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:57285/Service
> 03/04/05 15:45:47 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:45:58 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:46:00 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:46:05 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 15:46:11 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 16:09:49 -189228112 ServiceManager __init__.py:988 INFO
> 03/04/05 16:09:56 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:56:31 -178680912 Hosting __init__.py:988 ERROR
> File
> line 63, in Run
> File
> 140, in get_request
> get_request
> raise ex.args
> 03/07/05 11:59:26 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:27 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:28 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:30 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 INFO
> 61900]
> 03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:61900/Service
> 03/07/05 11:59:34 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:35 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 INFO
> 61787]
> 03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:61787/Service
> 03/07/05 11:59:37 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:38 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 INFO
> 51231]
> 03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:51231/Service
> 03/07/05 11:59:40 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:41 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 INFO
> 61579]
> 03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:61579/Service
> 03/07/05 11:59:43 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 11:59:44 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:00:01 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:00:07 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:00:12 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:00:53 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:01:22 -189228112 ServiceManager __init__.py:988 INFO
> 03/07/05 12:06:16 -233669712 ServiceManager __init__.py:988 INFO
> 03/07/05 12:06:17 -233669712 ServiceManager __init__.py:988 INFO
> 03/07/05 12:06:19 -233669712 ServiceManager __init__.py:988 INFO
> 03/07/05 12:10:42 -244364368 ServiceManager __init__.py:988 INFO
> 03/07/05 12:11:24 -254985296 ServiceManager __init__.py:988 INFO
> 03/07/05 12:21:11 -265606224 ServiceManager __init__.py:988 INFO
> 03/07/05 12:30:51 -276227152 ServiceManager __init__.py:988 INFO
> 03/07/05 12:34:40 -286848080 ServiceManager __init__.py:988 INFO
> 03/07/05 12:37:30 -297469008 ServiceManager __init__.py:988 INFO
> 03/07/05 12:38:35 -308089936 ServiceManager __init__.py:988 INFO
> 03/07/05 12:39:41 -318710864 ServiceManager __init__.py:988 INFO
> 03/07/05 12:40:25 -329331792 ServiceManager __init__.py:988 INFO
> 03/07/05 12:42:49 -339952720 ServiceManager __init__.py:988 INFO
> 03/07/05 12:51:40 -350573648 ServiceManager __init__.py:988 INFO
> 03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Caught
> signal, going down.
> 03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Signal:
> 1 Frame: <frame object at 0x845dc1c>
> 03/07/05 12:53:11 -150088192 ServiceManager __init__.py:988 INFO
> AGServiceManager.Shutdown
> Remove services
> 03/07/05 12:54:23 -150641152 ProxyGen __init__.py:988 DEBUG Using
> GT24 proxy code
> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 DEBUG
> Initializing AG Toolkit version 2.3
> 03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 INFO Logfile
> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Service
> init: have profile None
> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 DEBUG System
> hostname of rel-ag-video.ncsa.uiuc.edu is valid
> 03/07/05 12:54:24 -150641152 CertificateManager __init__.py:988
> DEBUG Opened repository /home/agnode/.AccessGrid/Config/certRepo
> Initialized cert mgmt.
> 03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Loaded
> profile and configured with it.
> DEBUG Configuring standard environment
> DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.ncsa.uiuc.edu
> DEBUG Initializing environment with unencrypted cert /O=Access
> DEBUG done, success=1
> Initialized Globus.
> Initialization Complete.
> 03/07/05 12:54:24 -150641152 ServiceManager __init__.py:988 INFO
> Using services dir: /home/agnode/.AccessGrid/local_services
> __DiscoverResources
> 03/07/05 12:54:24 -150641152 Platform __init__.py:988 INFO V4L
> /dev/video2 description: BT878 video (Osprey 100/150 (87
> /dev/video2 has ports: ['Composite0', 'Composite1', 'Composite2',
> 'S-Video']
> /dev/video3 description: BT878 video (Osprey 100/150 (87
> /dev/video3 has ports: ['Composite0', 'Composite1', 'Composite2',
> 'S-Video']
> /dev/video1 description: BT878 video (Osprey 100/150 (87
> /dev/video1 has ports: ['Composite0', 'Composite1', 'Composite2',
> 'S-Video']
> /dev/video0 description: BT878 video (Osprey 100/150 (87
> /dev/video0 has ports: ['Composite0', 'Composite1', 'Composite2',
> 'S-Video']
> Starting Service Manager URL:
> https://rel-ag-video.ncsa.uiuc.edu:11000/ServiceManager
> 03/07/05 12:55:17 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:23 -189781072 ServiceManager __init__.py:988 INFO
> AGServiceManager.GetResources
> __DiscoverResources
> 03/07/05 12:55:23 -189781072 Platform __init__.py:988 INFO V4L
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 INFO
> 62100]
> 03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:62100/Service
> 03/07/05 12:55:26 -189781072 Toolkit __init__.py:988 DEBUG
> 03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 DEBUG
> Not setting service configuration; none given
> 03/07/05 12:55:29 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:37 -189781072 ServiceManager __init__.py:988 INFO
> __DiscoverResources
> 03/07/05 12:55:37 -189781072 Platform __init__.py:988 INFO V4L
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 INFO
> 62452]
> 03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:62452/Service
> 03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 DEBUG
> 03/07/05 12:55:44 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:54 -189781072 ServiceManager __init__.py:988 INFO
> __DiscoverResources
> 03/07/05 12:55:54 -189781072 Platform __init__.py:988 INFO V4L
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 INFO
> 63206]
> 03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:63206/Service
> 03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 DEBUG
> 03/07/05 12:56:01 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:56:09 -189781072 ServiceManager __init__.py:988 INFO
> __DiscoverResources
> 03/07/05 12:56:09 -189781072 Platform __init__.py:988 INFO V4L
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 'S-Video']
> 03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 INFO
> 57859]
> 03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:57859/Service
> 03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 DEBUG
> 03/07/05 12:56:21 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:56:38 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:57:02 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:57:12 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:57:16 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:58:24 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:58:30 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:58:35 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:58:43 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:59:17 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:59:24 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:59:28 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 12:59:34 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:00:03 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:00:10 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:01 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:02 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:04 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:05 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 INFO
> 55780]
> 03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:55780/Service
> 03/07/05 13:01:08 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:09 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 INFO
> 52102]
> 03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:52102/Service
> 03/07/05 13:01:11 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:12 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 INFO
> 51524]
> 03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:51524/Service
> 03/07/05 13:01:14 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:15 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 INFO
> 53834]
> 03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 DEBUG
> https://rel-ag-video.ncsa.uiuc.edu:53834/Service
> 03/07/05 13:01:17 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:18 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:31 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:38 -189781072 ServiceManager __init__.py:988 INFO
> 03/07/05 13:01:41 -189781072 ServiceManager __init__.py:988 INFO
> Thanx,
> Michael Miller
> System Engineer
> Video Technology Services
> Persistent Infrastructure Directorate
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have
> hoped for and even more." -Paul Debevec
