[AG-TECH] Node stuck on startup
Michael Miller
myk at ncsa.uiuc.edu
Mon Mar 7 13:44:11 CST 2005
We had a problem with a node getting stuck when starting up. I narrowed it
down to the AGServiceManager on the video machine. Restarting the
AGServiceManager.py solved the problem. Is this in bugzilla? Anyone know
what's happening here that would cause the node to get stuck?
Michael Miller
NCSA
03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988
INFO AddService: VideoProducerService v 2.500000 u VideoProducerService.zip
INFO resourceToAssign: /dev/video0
INFO Retaining version 2.500000
INFO Extracting service package to
/home/agnode/.AccessGrid/local_services/VideoProducerService
INFO Running Service; options: /usr/bin/python2
['/home/agnode/.AccessGrid/local_services/VideoProducerService/VideoProducerService.py',
64126]
03/03/05 14:23:30 -189228112 ServiceManager __init__.py:988 DEBUG
Waiting for service to start: VideoProducerService
https://rel-ag-video.ncsa.uiuc.edu:64126/Service
03/03/05 14:23:32 -189228112 ServiceManager __init__.py:988
INFO Service VideoProducerService successfully started
INFO Setting service configuration
INFO Assigning resource to service: /dev/video0
03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988
INFO AGServiceManager.AddService
INFO resourceToAssign: /dev/video1
49279]
03/03/05 14:23:33 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:49279/Service
03/03/05 14:23:35 -189228112 ServiceManager __init__.py:988
INFO Assigning resource to service: /dev/video1
03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988
INFO resourceToAssign: /dev/video2
64268]
03/03/05 14:23:36 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:64268/Service
03/03/05 14:23:38 -189228112 ServiceManager __init__.py:988
INFO Assigning resource to service: /dev/video2
03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988
INFO resourceToAssign: /dev/video3
59359]
03/03/05 14:23:39 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:59359/Service
03/03/05 14:23:41 -189228112 ServiceManager __init__.py:988
INFO Assigning resource to service: /dev/video3
03/03/05 14:23:46 -189228112 ServiceManager __init__.py:988
INFO AGServiceManager.GetServices
03/03/05 14:23:52 -189228112 ServiceManager __init__.py:988
03/03/05 14:23:56 -189228112 ServiceManager __init__.py:988
03/03/05 14:24:08 -189228112 ServiceManager __init__.py:988
INFO AGServiceManager.StopServices
03/03/05 14:24:15 -189228112 ServiceManager __init__.py:988
03/03/05 14:24:18 -189228112 ServiceManager __init__.py:988
03/03/05 14:24:24 -189228112 ServiceManager __init__.py:988
03/03/05 14:25:21 -189228112 ServiceManager __init__.py:988
03/03/05 14:25:27 -189228112 ServiceManager __init__.py:988
03/04/05 15:42:44 -178680912 Hosting __init__.py:988 ERROR Exception in
SOAP server main loop
Traceback (most recent call last):
File
"/usr/lib/python2.3/site-packages/AccessGrid/hosting/SOAPpy/Server.py",
line 63, in Run
self._server.handle_request()
File
"/usr/src/build/394694-i386/install/usr/lib/python2.3/SocketServer.py",
line 217, in handle_request
request, client_address = self.get_request()
File "/usr/lib/python2.3/site-packages/SOAPpy/GSIServer.py", line 140,
in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "/usr/lib/python2.3/site-packages/pyGlobus/io.py", line 850, in
get_request
raise ex.args
an end-of-file was reached
03/04/05 15:45:28 -189228112 ServiceManager __init__.py:988
INFO AGServiceManager.RemoveServices
03/04/05 15:45:29 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:30 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:32 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:33 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988
50259]
03/04/05 15:45:34 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:50259/Service
03/04/05 15:45:36 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988
59508]
03/04/05 15:45:38 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:59508/Service
03/04/05 15:45:40 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988
51060]
03/04/05 15:45:42 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:51060/Service
03/04/05 15:45:43 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988
57285]
03/04/05 15:45:45 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:57285/Service
03/04/05 15:45:47 -189228112 ServiceManager __init__.py:988
03/04/05 15:45:58 -189228112 ServiceManager __init__.py:988
03/04/05 15:46:00 -189228112 ServiceManager __init__.py:988
03/04/05 15:46:05 -189228112 ServiceManager __init__.py:988
03/04/05 15:46:11 -189228112 ServiceManager __init__.py:988
03/04/05 16:09:49 -189228112 ServiceManager __init__.py:988
03/04/05 16:09:56 -189228112 ServiceManager __init__.py:988
03/07/05 11:56:31 -178680912 Hosting __init__.py:988 ERROR Exception in
File
line 63, in Run
File
in get_request
get_request
raise ex.args
03/07/05 11:59:26 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:27 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:28 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:30 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988
61900]
03/07/05 11:59:32 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:61900/Service
03/07/05 11:59:34 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:35 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988
61787]
03/07/05 11:59:36 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:61787/Service
03/07/05 11:59:37 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:38 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988
51231]
03/07/05 11:59:39 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:51231/Service
03/07/05 11:59:40 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:41 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988
61579]
03/07/05 11:59:42 -189228112 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:61579/Service
03/07/05 11:59:43 -189228112 ServiceManager __init__.py:988
03/07/05 11:59:44 -189228112 ServiceManager __init__.py:988
03/07/05 12:00:01 -189228112 ServiceManager __init__.py:988
03/07/05 12:00:07 -189228112 ServiceManager __init__.py:988
03/07/05 12:00:12 -189228112 ServiceManager __init__.py:988
03/07/05 12:00:53 -189228112 ServiceManager __init__.py:988
03/07/05 12:01:22 -189228112 ServiceManager __init__.py:988
03/07/05 12:06:16 -233669712 ServiceManager __init__.py:988
03/07/05 12:06:17 -233669712 ServiceManager __init__.py:988
03/07/05 12:06:19 -233669712 ServiceManager __init__.py:988
03/07/05 12:10:42 -244364368 ServiceManager __init__.py:988
03/07/05 12:11:24 -254985296 ServiceManager __init__.py:988
03/07/05 12:21:11 -265606224 ServiceManager __init__.py:988
03/07/05 12:30:51 -276227152 ServiceManager __init__.py:988
03/07/05 12:34:40 -286848080 ServiceManager __init__.py:988
03/07/05 12:37:30 -297469008 ServiceManager __init__.py:988
03/07/05 12:38:35 -308089936 ServiceManager __init__.py:988
03/07/05 12:39:41 -318710864 ServiceManager __init__.py:988
03/07/05 12:40:25 -329331792 ServiceManager __init__.py:988
03/07/05 12:42:49 -339952720 ServiceManager __init__.py:988
03/07/05 12:51:40 -350573648 ServiceManager __init__.py:988
03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Caught
signal, going down.
03/07/05 12:53:11 -150088192 Toolkit __init__.py:988 INFO Signal: 1
Frame: <frame object at 0x845dc1c>
03/07/05 12:53:11 -150088192 ServiceManager __init__.py:988
INFO AGServiceManager.Shutdown
INFO Remove services
03/07/05 12:54:23 -150641152 ProxyGen __init__.py:988 DEBUG Using GT24
proxy code
03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 DEBUG Initializing
AG Toolkit version 2.3
03/07/05 12:54:23 -150641152 Toolkit __init__.py:988 INFO Logfile
03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Service
init: have profile None
03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 DEBUG System
hostname of rel-ag-video.ncsa.uiuc.edu is valid
03/07/05 12:54:24 -150641152 CertificateManager __init__.py:988 DEBUG
Opened repository /home/agnode/.AccessGrid/Config/certRepo
03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Initialized
cert mgmt.
03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Loaded
profile and configured with it.
Configuring standard environment
Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.ncsa.uiuc.edu
Initializing environment with unencrypted cert /O=Access
done, success=1
Globus.
Initialization Complete.
03/07/05 12:54:24 -150641152 ServiceManager __init__.py:988 INFO Using
services dir: /home/agnode/.AccessGrid/local_services
INFO __DiscoverResources
03/07/05 12:54:24 -150641152 Platform __init__.py:988 INFO V4L
/dev/video2 description: BT878 video (Osprey 100/150 (87
/dev/video2 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
/dev/video3 description: BT878 video (Osprey 100/150 (87
/dev/video3 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
/dev/video1 description: BT878 video (Osprey 100/150 (87
/dev/video1 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
/dev/video0 description: BT878 video (Osprey 100/150 (87
/dev/video0 has ports: ['Composite0', 'Composite1', 'Composite2', 'S-Video']
03/07/05 12:54:24 -150641152 Toolkit __init__.py:988 INFO Starting
Service Manager URL: https://rel-ag-video.ncsa.uiuc.edu:11000/ServiceManager
03/07/05 12:55:17 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:23 -189781072 ServiceManager __init__.py:988
INFO AGServiceManager.GetResources
03/07/05 12:55:23 -189781072 Platform __init__.py:988 INFO V4L
03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988
62100]
03/07/05 12:55:26 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:62100/Service
03/07/05 12:55:26 -189781072 Toolkit __init__.py:988 DEBUG Initializing
03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:27 -189781072 ServiceManager __init__.py:988 DEBUG Not
setting service configuration; none given
03/07/05 12:55:29 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:37 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:37 -189781072 Platform __init__.py:988 INFO V4L
03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988
62452]
03/07/05 12:55:41 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:62452/Service
03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:42 -189781072 ServiceManager __init__.py:988 DEBUG Not
03/07/05 12:55:44 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:54 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:54 -189781072 Platform __init__.py:988 INFO V4L
03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988
63206]
03/07/05 12:55:57 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:63206/Service
03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988
03/07/05 12:55:59 -189781072 ServiceManager __init__.py:988 DEBUG Not
03/07/05 12:56:01 -189781072 ServiceManager __init__.py:988
03/07/05 12:56:09 -189781072 ServiceManager __init__.py:988
03/07/05 12:56:09 -189781072 Platform __init__.py:988 INFO V4L
03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988
57859]
03/07/05 12:56:17 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:57859/Service
03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988
03/07/05 12:56:19 -189781072 ServiceManager __init__.py:988 DEBUG Not
03/07/05 12:56:21 -189781072 ServiceManager __init__.py:988
03/07/05 12:56:38 -189781072 ServiceManager __init__.py:988
03/07/05 12:57:02 -189781072 ServiceManager __init__.py:988
03/07/05 12:57:12 -189781072 ServiceManager __init__.py:988
03/07/05 12:57:16 -189781072 ServiceManager __init__.py:988
03/07/05 12:58:24 -189781072 ServiceManager __init__.py:988
03/07/05 12:58:30 -189781072 ServiceManager __init__.py:988
03/07/05 12:58:35 -189781072 ServiceManager __init__.py:988
03/07/05 12:58:43 -189781072 ServiceManager __init__.py:988
03/07/05 12:59:17 -189781072 ServiceManager __init__.py:988
03/07/05 12:59:24 -189781072 ServiceManager __init__.py:988
03/07/05 12:59:28 -189781072 ServiceManager __init__.py:988
03/07/05 12:59:34 -189781072 ServiceManager __init__.py:988
03/07/05 13:00:03 -189781072 ServiceManager __init__.py:988
03/07/05 13:00:10 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:01 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:02 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:04 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:05 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988
55780]
03/07/05 13:01:07 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:55780/Service
03/07/05 13:01:08 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:09 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988
52102]
03/07/05 13:01:10 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:52102/Service
03/07/05 13:01:11 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:12 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988
51524]
03/07/05 13:01:13 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:51524/Service
03/07/05 13:01:14 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:15 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988
53834]
03/07/05 13:01:16 -189781072 ServiceManager __init__.py:988 DEBUG
https://rel-ag-video.ncsa.uiuc.edu:53834/Service
03/07/05 13:01:17 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:18 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:31 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:38 -189781072 ServiceManager __init__.py:988
03/07/05 13:01:41 -189781072 ServiceManager __init__.py:988
Thanx,
Michael Miller
System Engineer
Video Technology Services
Persistent Infrastructure Directorate
National Center for Supercomputing Applications
University of Illinois - UC
217-649-0747
"If you're clear in your vision and trust the people in your team with
clear objectives, they will invariably do their best to achieve everything
desired, and usually deliver everything you could have hoped for and even
more." -Paul Debevec
