[AG-TECH] venue connection issues for new AG user - reprise
Julia Mullen
julia.mullen at gmail.com
Thu Jun 23 15:42:47 CDT 2005
Hi again -
here is the venueclient error log.
Thanks -
Julie
---------- Forwarded message ----------
Date: Jun 23, 2005 4:24 PM
Subject: Re: Access Grid Toolkit | Users | Getting Started
To: Julia Mullen <julia.mullen at gmail.com>
Perhaps this will help. It is the VenueClient error log.
-david
06/23/05 14:23:01 652 Toolkit toolkit.py:90 DEBUG Initializing AG
Toolkit version 2.3
06/23/05 14:23:01 652 Toolkit toolkit.py:132 INFO Logfile Name:
VenueClient.log
06/23/05 14:23:01 652 Toolkit config.py:219 ERROR Error setting
globus hostname.
Traceback (most recent call last):
File "C:\Python23\Lib\site-packages\AccessGrid\Config.py", line 212,
in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
06/23/05 14:23:01 652 Toolkit config.py:348 DEBUG retrieved local IP
address 129.24.24.208
06/23/05 14:23:01 652 CertificateManager certificatemanager.py:257
DEBUG Opened repository C:\Documents and Settings\David A.
Bader\Application Data\AccessGrid\Config\certRepo
06/23/05 14:23:01 652 Toolkit toolkit.py:395 DEBUG Got repo.
06/23/05 14:23:01 652 Toolkit toolkit.py:397 DEBUG looking in system
ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
06/23/05 14:23:01 652 Toolkit toolkit.py:401 DEBUG Getting cert:
1c3f2ca8.0
06/23/05 14:23:01 652 Toolkit toolkit.py:406 WARNING Not importing
cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
45cc9e80.0
cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
d1b603c3.0
cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
f18fa857.0
cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
06/23/05 14:23:01 652 Toolkit toolkit.py:410 DEBUG Init'ing globus.
06/23/05 14:23:01 652 CertificateManager certificatemanager.py:734
DEBUG Configuring standard environment
06/23/05 14:23:02 652 CertificateManager certificatemanager.py:802
DEBUG Using default identity /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=cc.gatech.edu/CN=David Bader
06/23/05 14:23:02 652 CertificateManager certificatemanager.py:873
DEBUG Initializing environment with proxy cert for /O=Access
06/23/05 14:23:02 652 CertificateManager certificatemanager.py:907
DEBUG Looking for identity (unused) None
06/23/05 14:23:02 652 CertificateManager certificatemanager.py:892
DEBUG Configuring for user proxy issued from /O=Access
06/23/05 14:23:02 652 CertificateManager certificatemanager.py:895
DEBUG Proxy C:\DOCUME~1\DAVIDA~1.BAD\LOCALS~1\Temp\proxy will expire
06/23/05 15:51:17
06/23/05 14:23:02 652 Toolkit toolkit.py:414 DEBUG Done with globus.
06/23/05 14:23:02 652 VenueClient venueclient.py:284 DEBUG
__StartWebService: venueclient: https://129.24.24.208:11000/VenueClient
06/23/05 14:23:02 652 ServiceManager agservicemanager.py:75 INFO
Using services dir: C:\Documents and Settings\David A. Bader\Application
Data\AccessGrid\local_services
06/23/05 14:23:02 652 ServiceManager agservicemanager.py:414 INFO
__DiscoverResources
06/23/05 14:23:02 652 Toolkit config.py:997 INFO Using vfwscan to
get devices
06/23/05 14:23:02 652 Toolkit config.py:998 DEBUG vfwscanexe =
C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe
06/23/05 14:23:02 652 Toolkit config.py:1003 DEBUG filelines = []
06/23/05 14:23:02 652 Toolkit config.py:1010 INFO Retrieving
devices from registry
06/23/05 14:23:02 652 Toolkit config.py:1031 INFO GetResources: []
06/23/05 14:23:02 652 VenueClient venueclient.py:293 DEBUG
__StartWebService: service manager:
https://129.24.24.208:11000/ServiceManager
06/23/05 14:23:02 652 NodeService agnodeservice.py:733 INFO
NodeService.__ReadConfigFile
06/23/05 14:23:02 652 Toolkit toolkit.py:328 DEBUG Looking for:
Data\AccessGrid\Config\AGNodeService.cfg
06/23/05 14:23:02 652 Toolkit toolkit.py:333 DEBUG Looking for:
C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/23/05 14:23:02 652 NodeService agnodeservice.py:741 DEBUG DEFAULT
NODE SERVICE CONFIG: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/23/05 14:23:02 652 NodeService agnodeservice.py:745 INFO Reading
node service config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/23/05 14:23:02 652 VenueClient venueclient.py:299 DEBUG
__StartWebService: node service: https://129.24.24.208:11000/NodeService
06/23/05 14:23:02 652 VenueClient venueclient.py:1317 DEBUG
SerNodeUrl: Set node service url: https://129.24.24.208:11000/NodeService
06/23/05 14:23:02 652 NodeService agnodeservice.py:675 INFO
NodeService.GetDefaultConfiguration
06/23/05 14:23:02 652 NodeService agnodeservice.py:558 INFO
Migration unnecessary
06/23/05 14:23:02 652 NodeService agnodeservice.py:351 INFO
NodeService.LoadDefaultConfig
06/23/05 14:23:02 652 NodeService agnodeservice.py:355 INFO Loading
default node configuration: defaultWindows
06/23/05 14:23:02 652 NodeService agnodeservice.py:369 INFO
NodeService.LoadConfiguration
06/23/05 14:23:02 652 NodeService agnodeservice.py:384 INFO Trying
to load node configuration from: C:\Documents and Settings\David A.
Bader\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
06/23/05 14:23:02 652 NodeService agnodeservice.py:457 INFO
AddServiceManager: Invalid service manager url
(https://localhost:11000/ServiceManager)
06/23/05 14:23:02 652 NodeService agnodeservice.py:358 ERROR
Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
356, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
500, in LoadConfiguration
raise Exception(exceptionText)
Exception: Couldn't reach service manager: localhost:11000
06/23/05 14:23:02 652 VenueClient venueclient.py:310 ERROR Error
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
308, in __StartWebService
self.ns.LoadDefaultConfig()
359, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
06/23/05 14:23:02 652 VenueClient venueclient.py:182 DEBUG
__createPersonalDataStore: Creating personal datastore at C:\Documents
Data\AccessGrid\Config\personalDataStore using prefix personalDataStore
and port 0
06/23/05 14:23:02 652 DataStore datastore.py:1500 DEBUG Creating
thread 0
06/23/05 14:23:02 652 DataStore datastore.py:1505 DEBUG Starting
thread 0
06/23/05 14:23:02 3016 DataStore datastore.py:1513 DEBUG Worker 0
starting
06/23/05 14:23:02 652 DataStore datastore.py:1507 DEBUG Waiting thread 0
06/23/05 14:23:02 652 DataStore datastore.py:1510 DEBUG Done
creating workers
06/23/05 14:23:02 652 DataStore datastore.py:263 DEBUG Reading
persisted data from: C:\Documents and Settings\David A.
Bader\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
06/23/05 14:23:02 652 VenueClient venueclient.py:207 DEBUG
__createPersonalDataStore: Load personal data from file
06/23/05 14:23:02 652 VenueClientController
venueclientcontroller.py:1277 DEBUG There is no personal venues file to
load.
06/23/05 14:23:03 652 VenueClient venueclient.py:803 DEBUG
EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
06/23/05 14:23:03 652 CertificateManager certificatemanager.py:907
06/23/05 14:23:03 652 CertificateManager certificatemanager.py:638
DEBUG HaveValidProxy: found proxy ident /O=Access
Grid/OU=agdev-ca.mcs.anl.gov/OU=cc.gatech.edu/CN=David Bader/CN=proxy
06/23/05 14:23:03 652 VenueClient venueclient.py:830 INFO
EnterVenue: Error getting node capabilities
06/23/05 14:23:03 652 VenueClient venueclient.py:702 DEBUG
EnterVenue: Invoke venue enter
06/23/05 14:23:03 652 VenueClient venueclient.py:863 ERROR
EnterVenue: failed
834, in EnterVenue
self.__EnterVenue(URL)
703, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) =
self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331,
in Enter
(r1, r2, r3) = self.proxy.Enter(profile)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in
__call__
return self.__r_call(*args, **kw)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in
__r_call
self.__hd, self.__ma)
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
config = self.config, noroot = self.noroot)
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620,
in buildSOAP
return t.build()
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118,
in build
body_ns = self.genns(ns_map, NS.ENV)[0]
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204,
in genns
if type(nsURI) == TupleType: # already a tuple
NameError: global name 'TupleType' is not defined
06/23/05 14:23:03 652 VenueClient venueclientui.py:1959 DEBUG
bin.VenueClient::EnterVenue: Enter venue with url:
06/23/05 14:23:03 652 VenueClient venueclientui.py:1972 DEBUG
warningString:
06/23/05 14:23:05 652 VenueClient venueclientui.py:1599 INFO
--------- END VenueClient
06/23/05 14:23:05 652 DataStore datastore.py:1577 DEBUG Quitting
thread 0
06/23/05 14:23:05 3016 DataStore datastore.py:1518 DEBUG Worker 0
gets cmd quit
06/23/05 14:23:05 3016 DataStore datastore.py:1531 DEBUG Worker 0
exiting
06/23/05 14:23:05 3516 DataStore datastore.py:1590 INFO
GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most
likely shutting down.
06/23/05 14:23:05 652 NodeService agnodeservice.py:113 INFO
NodeService.Stop
06/23/05 14:23:05 652 ServiceManager agservicemanager.py:84 INFO
AGServiceManager.Shutdown
06/23/05 14:23:05 652 ServiceManager agservicemanager.py:85 INFO
Remove services
06/23/05 14:23:05 652 ServiceManager agservicemanager.py:379 INFO
AGServiceManager.RemoveServices
06/23/05 14:23:05 652 ServiceManager agservicemanager.py:87 INFO
Stop network interface
06/23/05 14:23:05 3012 Hosting server.py:65 ERROR Exception in SOAP
server main loop
File
"C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py",
line 63, in Run
self._server.handle_request()
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
request, client_address = self.get_request()
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in
get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
get_request
self.socket.listen()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
GSITCPSocketException: an I/O operation was cancelled
06/23/05 14:23:05 652 Hosting server.py:97 ERROR server_close() failed
File
line 95, in Stop
self._server.server_close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in
server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1
to globus_io_register_close
File
line 95, in Stop
server_close
self.socket.close()
IOBase.close(self)
raise ex
Julia Mullen wrote:
>Hi David -
>Here is another link to the thread for Thinkpad 43 item:
>http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2005/06/msg00092.html
>let me know if you can get to this link. Else I can walk you there.
>Julie
>On 6/23/05, David A. Bader <bader at cc.gatech.edu> wrote:
>>Whoops -- I see it now :-)
>>-d
>>Julia Mullen wrote:
>>>HI David,
>>>Great! And you already have your cert! This is very fast.
>>>Let me answer the hardware question first as that is the easy
>>>question. You need a USB camera - we (the AG community) recommend the
>>>Logitech Quickcam Pro 4000 because it produces nice quality video.
>>>You will also need a headset/microphone. This is more user specific
>>>as it depends on what type of headphones you like - as long as it has
>>>both a
>>>headset and a microphone we are all set.
>>>The next thing to do is to test it. This is trickier. I have
>>>borrowed a laptop and will be setting up my node tonight and testing
>>>tomorrow. What times are good for you tomorrow? Are any good - as I
>>>recall you are selling houses and moving. If not tomorrow, can you
>>>send me some dates and times that are good, and a backup phone number
>>>for trouble shooting - and
>>>I will set up a testing time for you?
>>>If you need to get in touch with me by phone the number is: 781-981-0839.
>>>I have a voicemail box, though it does not yet identify it as mine.
>>>Thanks -
>>> Julie
>>>>Julia,
>>>> I've now installed AGTk-2.3, and have installed my certificate. What
>>>>next? How do I test it? I do not know where to connect. Also, I have an
>>>>IBM T41 laptop running WinXP. What is the easiest/minimalist/cheapest
>>>>set of additional hardware needed (with specific model numbers) to be
>>>>ready to go.
>>>>Thanks,
>>>>-david
>>>>David Koester wrote:
>>>>>David B.:
>>>>>Julia can answer this question.
>>>>>Hope this helps!
>>>>>David K.
>>>>>Dr. David Koester
>>>>>The MITRE Corporation
>>>>>26 Electronic Parkway
>>>>>Rome, NY 13441-4514
>>>>>Phone: 315.336.4966 x229 (voice)
>>>>> 315.330.4277 x229 (voice)
>>>>> 315.336.4753 (fax)
>>>>> 315.527.8360 (cell)
>>>>>Email: dkoester at mitre.org
>>>>>"Any Intelligent fool can make things bigger, more complex... It takes a
>>>>>touch of genius -- and a lot of courage -- to move in the opposite
>>>>>direction."
>>>>>-- Albert Einstein
>>>>>-----Original Message-----
>>>>>From: David A. Bader [mailto:dbader at ece.unm.edu]
>>>>>Sent: Wednesday, June 22, 2005 4:25 PM
>>>>>To: Dave Koester
>>>>>Subject: Access Grid Toolkit | Users | Getting Started
>>>>>http://www-unix.mcs.anl.gov/fl/research/accessgrid/software/index.html
>>>>>The link to "certificate" is broken. What certificate do I need?
>>>>>-d
>>>>David A. Bader
>>>>College of Computing
>>>>Georgia Institute of Technology
>>>>Atlanta, GA 30332 USA
>>David A. Bader
David A. Bader
