[AG-TECH] access grid problems
Catherall, Scott
scott at ccnt.hsc.usc.edu
Thu Jun 23 16:57:22 CDT 2005
When I run the "service manager" I get this error:
C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCNTL module is
deprecated;
please use fcntl
DeprecationWarning)
C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS module is
deprecat
ed; please use termios
DeprecationWarning)
Starting Service Manager URL:
https://scclaptop5.norccc.usc.edu:11000/ServiceMan
ager
When I run the "node service" I get this error:
deprecated;
please use fcntl
DeprecationWarning)
deprecat
DeprecationWarning)
Starting Node Service URL:
https://scclaptop5.norccc.usc.edu:11000/NodeService
ager
Traceback (most recent call last):
File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 145, in
main()
File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 130, in
main
gNodeService.LoadDefaultConfig()
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
359, in
LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
Any ideas?
Thanks
Sent: Thursday, June 23, 2005 10:50 AM
To: 'ag-tech at mcs.anl.gov'
Subject: FW: access grid problems
I am not able to get the Venue Client running on a particular computer.
I have been involved in installing on other computers and know the
procedure for a successful install. This particular computer gets the
following errors when I attempt to create a node. Can someone give me
some ideas? I have uninstalled and installed twice. I even went through
and removed all other python installs. There was one at
c:\ibmtools\python22.
deprecated; please use fcntl
DeprecationWarning)
deprecated; please use termios
DeprecationWarning)
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050623/4ed6fdcc/attachment.htm>
Name: not available
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050623/4ed6fdcc/attachment.jpeg>
