[AG-TECH] Gentoo: agpm.py and VenueServer fail.
west suhanic
west.suhanic at gmail.com
Wed Jun 22 08:21:07 CDT 2005
Hi Thomas:
> Do you have any files in /etc/AccessGrid? You should have several directories: Config,
> Logs, NodeServices, Services, SharedApplications. If you don't have these, the emerge
> failed horribly, and you should try running in verbose mode to see what is going wrong.
I have all these directories except SharedApplications. As soon as I
made SharedApplications under /etc/AccessGrid, /usr/bin/VenueServer
--debug came up but complained about no identity-(which is entirely
reasonable).
> What command are you giving to emerge the package?
the emerge command from the web page: emerge -aq ag-libs/agtk
So I think the fact that SharedApplications does not get built is an issue.
Suggestions?
west
