[AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer and BridgeServer
Ben Ware
bware at utk.edu
Sat Jun 18 14:55:03 CDT 2005
I am having the exact same problem, could anyone offer any new hints?
I am about to try what Thomas Uram suggested with moving the file, from
his email on June 14th, but it seems that West had problems with this as
well.
Ben
West Suhanic wrote:
>Hi Jason:
>The exact gentoo error is:
>gcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function-cast -W
>missing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-4.2.22-r3
>/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tc
>l-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/generic
> -c
>voxlet.cgcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function
>-cast -Wmissing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-4
>.2.22-r3/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-
>media/tcl-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/
>generic -c auddev_ixj.c
>In file included from auddev_ixj.c:19:
>/usr/include/linux/ixjuser.h:353: error: parse error before '*' token
>make: *** [auddev_ixj.o] Error 1
>make: *** Waiting for unfinished jobs....
>!!! ERROR: ag-media/rat-4.2.22-r3 failed.
>!!! Function src_compile, Line 39, Exitcode 2
>!!! Failed to make rat
>!!! If you need support, post the topmost build error, NOT this status
>message.
>I also just tried emerging the various components instead of everything in
>an attempt
>to get the venue and bridge server operational. However it failed. When I
>ran VenueServer
>I got a toolkit initialization error.
>regards,
>west
>----- Original Message -----
>From: "Jason Pepas" <cell at ices.utexas.edu>
>To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
>Cc: <ag-tech at mcs.anl.gov>
>Sent: Saturday, June 11, 2005 1:04 PM
>Subject: Re: [AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer
>and BridgeServer
>>What was the error message?
>>-jason pepas
>>On Sat, Jun 11, 2005 at 12:16:59AM -0400, West Suhanic wrote:
>>>Hello All:
>>>I tried the following emerge command:
>>>emerge -aq ag-libs/agtk <-- This command fails when trying to emerge
>rat. Please note
>>>when I do emerge rat this too fails. uname -a yields: Gentoo 2.6.11-r3
>>>I am trying to get my VenueServer running under gentoo. If I can it
>would really
>>>streamline my hardware set-up and get me institutional system admin
>support.
>>>I have two questions. The first question is: How can I emerge the
>>>server without the stuff does not work? My second question is: Without
>the AGtk client interface how do
>>>I setup the VenueServer using vi to edit its configuration files?
>>>regards,
>>>West Suhanic
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20050618/b7c53294/attachment.htm>
