[AG-TECH] Gentoo: agpm.py and VenueServer fail.
Thomas D. Uram
turam at mcs.anl.gov
Wed Jun 22 07:52:08 CDT 2005
West:
Do you have any files in /etc/AccessGrid? You should have several directories: Config,
Logs, NodeServices, Services, SharedApplications. If you don't have these, the emerge
failed horribly, and you should try running in verbose mode to see what is going wrong.
What command are you giving to emerge the package?
Lastly, the ~/.AccessGrid directory is created the first time the user runs the software,
during initialization. If initialization is failing for you in not finding required files
in /etc/AccessGrid, it won't get this far, so you'll not have this directory.
Tom
On 06/21/05 08:46, west suhanic wrote:
> Hi Thomas:
> I checked the emerge log. I did not see any complaint about or even
> mention of /etc/AccessGrid. I did not see mention of /etc . Also there
> was no
> ~/.AccessGrid created. I am open to any and all suggestions.
> regards,
> west
> On 6/21/05, Thomas D. Uram <turam at mcs.anl.gov> wrote:
>>The complaint is about /etc/AccessGrid/SharedApplications .
>>I expect to see some failure in the emerge output regarding this and other directories.
>>West: Do you see any failures regarding directories in /etc/AccessGrid? Do you see a
>>complaint about configuration files (which reside in /etc)?
>>Tom
>>On 06/20/05 17:22, Douglas Kosovic wrote:
>>>Hi West,
>>>> File
>>>>"/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py",
>>>>line 100, in _Initialize
>>>> self.GetSharedAppDir()
>>>> File
>>>>line 208, in GetSharedAppDir
>>>> raise Exception, "AGTkConfig: app dir does not exist."
>>>>Exception: AGTkConfig: app dir does not exist.
>>>>Any suggestions?
>>>I think it's complaining about either one of the following dirs:
>>> ~/.AccessGrid/SharedApplications/
>>> $AGTK_USER/SharedApplications/
>>>The latter only if the AGTK_USER env variable is set.
>>>Check the ownership and permissions of ~/.AccessGrid/ or just issue
>>>something like:
>>> mv ~/.AccessGrid ~/AccessGrid.bak
>>>Cheers,
>>>Doug
