[AG-TECH] Gentoo: agpm.py and VenueServer fail.
West Suhanic
giraffe911 at rogers.com
Tue Jun 14 10:15:17 CDT 2005
Hi Doug:
Thanks for the note on the Quicknet device. By doing what you
suggested, the emerge command now works. However when I run
agpm.py --post-install it fails with the following error message:
Traceback (most recent call last):
File "/usr/bin/agpm.py", line 445, in ?
main()
File "/usr/bin/agpm.py", line 303, in main
tkConf = AGTkConfig.instance()
File
"/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py", line
65, in instance
AGTkConfig(initIfNeeded)
File
94, in __init__
self._Initialize()
File
100, in _Initialize
self.GetSharedAppDir()
File
208, in GetSharedAppDir
raise Exception, "AGTkConfig: app dir does not exist."
Exception: AGTkConfig: app dir does not exist.
Also when I run /usr/bin/VenueServer --debug the following error log message
is
generated:
06/14/05 10:17:18 16384 Toolkit Toolkit.py:108 ERROR Toolkit
Initialization failed.
File "/usr/lib/python2.3/site-packages/AccessGrid/Toolkit.py", line 106,
in Initialize
self.agtkConfig = AGTkConfig.instance(0)
File
65, in instance
File
94, in __init__
self._Initialize()
File
100, in _Initialize
File
Woudlanyone know where, under Gentoo, do I create the appropriate app dir?
regards,
west
----- Original Message -----
From: "Douglas Kosovic" <douglask at itee.uq.edu.au>
To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
Cc: <ag-tech at mcs.anl.gov>
Sent: Tuesday, June 14, 2005 4:23 AM
Subject: Re: [AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer
and BridgeServer
> Hi West,
voxlet.cgcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function
-cast -Wmissing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-
4
.22-r3/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-
media/tcl-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/
> > generic -c auddev_ixj.c
> > In file included from auddev_ixj.c:19:
> > /usr/include/linux/ixjuser.h:353: error: parse error before '*' token
> > make: *** [auddev_ixj.o] Error 1
> It's failing on the Quicknet Technologies audio device driver header file,
> which is probably of no use unless you've got a Quicknet telephony device.
> You could try stopping the rat configuration step from trying to build
> auddev_ixj.o by doing something like:
> mv /usr/include/linux/telephony.h /usr/include/linux/telephony.h.bak
> Doug
