[AG-TECH] Gentoo: agpm.py and VenueServer fail.
Thomas D. Uram
turam at mcs.anl.gov
Tue Jun 14 10:45:02 CDT 2005
Hi West:
If you're missing that directory, the installation may have gone wrong in other ways too.
Rather than create individual directories, I'd suggest that you re-emerge the toolkit,
watching for problems that occur. If you find any, you can report them here (or to
bugzilla) and we can help you resolve them.
Note that Gentoo regards files in /etc as configuration data, and may issue a warning at
the end of the emerge about updates to these files, which need to be handled manually.
Tom
On 06/14/05 10:15, West Suhanic wrote:
> Hi Doug:
> Thanks for the note on the Quicknet device. By doing what you
> suggested, the emerge command now works. However when I run
> agpm.py --post-install it fails with the following error message:
> Traceback (most recent call last):
> File "/usr/bin/agpm.py", line 445, in ?
> main()
> File "/usr/bin/agpm.py", line 303, in main
> tkConf = AGTkConfig.instance()
> File
> "/usr/lib/python2.3/site-packages/AccessGrid/Platform/unix/Config.py", line
> 65, in instance
> AGTkConfig(initIfNeeded)
> File
> 94, in __init__
> self._Initialize()
> File
> 100, in _Initialize
> self.GetSharedAppDir()
> File
> 208, in GetSharedAppDir
> raise Exception, "AGTkConfig: app dir does not exist."
> Exception: AGTkConfig: app dir does not exist.
> Also when I run /usr/bin/VenueServer --debug the following error log message
> is
> generated:
> 06/14/05 10:17:18 16384 Toolkit Toolkit.py:108 ERROR Toolkit
> Initialization failed.
> File "/usr/lib/python2.3/site-packages/AccessGrid/Toolkit.py", line 106,
> in Initialize
> self.agtkConfig = AGTkConfig.instance(0)
> File
> 65, in instance
> File
> 94, in __init__
> self._Initialize()
> File
> 100, in _Initialize
> File
> Woudlanyone know where, under Gentoo, do I create the appropriate app dir?
> regards,
> west
> From: "Douglas Kosovic" <douglask at itee.uq.edu.au>
> To: "West Suhanic" <wsuhanic at alumni.uwaterloo.ca>
> Cc: <ag-tech at mcs.anl.gov>
> Sent: Tuesday, June 14, 2005 4:23 AM
> Subject: Re: [AG-TECH] Gentoo: emerge fails on rat. I only need VenueServer
> and BridgeServer
>>Hi West,
> voxlet.cgcc -O2 -march=pentium4 -fomit-frame-pointer -W -Wall -Wbad-function
> -cast -Wmissing-prototypes -Werror -DHAVE_CONFIG_H -I/var/tmp/portage/rat-
> 4
> .22-r3/work/ag-media/common/src -I/var/tmp/portage/rat-4.2.22-r3/work/ag-
> media/tcl-8.0/generic -I/var/tmp/portage/rat-4.2.22-r3/work/ag-media/tk-8.0/
>>>generic -c auddev_ixj.c
>>>In file included from auddev_ixj.c:19:
>>>/usr/include/linux/ixjuser.h:353: error: parse error before '*' token
>>>make: *** [auddev_ixj.o] Error 1
>>It's failing on the Quicknet Technologies audio device driver header file,
>>which is probably of no use unless you've got a Quicknet telephony device.
>>You could try stopping the rat configuration step from trying to build
>>auddev_ixj.o by doing something like:
>> mv /usr/include/linux/telephony.h /usr/include/linux/telephony.h.bak
>>Doug
