[AG-TECH] Can not enter venue with Thinkpad T43
Anne Gorczyca
amg at haystack.mit.edu
Thu Jun 9 14:53:22 CDT 2005
Sorry. I forgot to add the logfile. It's attached now.
On Thursday 09 June 2005 03:47 pm, Anne Gorczyca wrote:
> Tom,
> New logfile is attached.
> Results of set after removing PYTHONCASEOK from environment:
> ALLUSERSPROFILE=C:\Documents and Settings\All Users
> APPDATA=C:\Documents and Settings\Sys Admin\Application Data
> CommonProgramFiles=C:\Program Files\Common Files
> COMPUTERNAME=IBMT43-AMG
> ComSpec=C:\WINDOWS\system32\cmd.exe
> FP_NO_HOST_CHECK=NO
> GLOBUS_HOSTNAME=localhost
> HOMEDIR=C:\Program Files\mbone
> HOMEDRIVE=C:
> HOMEPATH=\Documents and Settings\Sys Admin
> IBMSHARE=C:\IBMSHARE
> LOGONSERVER=\\IBMT43-AMG
> NUMBER_OF_PROCESSORS=1
> OS=Windows_NT
> Path=C:\Python23\.;C:\Program
> Files\ThinkPad\Utilities;C:\system32;C:;C:\System32\Wbem;C:\Program
> Files\Intel\Wireless\Bin\;C:\Program Files\ATI Technologies\ATI
> Control Panel;C:\WINDOWS\Downloaded Program
> Files;C:\IBMTOOLS\Python22;C:\Program Files\PC-Doctor for
> Windows\services;C:\Program Files\SecureCRT\;C:\Program Files\Mbone
> PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.pyo;.pyc;.p
>y;.pyw;.pys PROCESSOR_ARCHITECTURE=x86
> PROCESSOR_IDENTIFIER=x86 Family 6 Model 13 Stepping 8, GenuineIntel
> PROCESSOR_LEVEL=6
> PROCESSOR_REVISION=0d08
> PROMPT=$P$G
> PYTHONPATH=C:\IBMTOOLS\utils\support;C:\IBMTOOLS\utils\logger
> RRU=C:\Program Files\IBM\IBM Rapid Restore Ultra\
> SESSIONNAME=Console
> SystemDrive=C:
> SystemRoot=C:\WINDOWS
> TCL_LIBRARY=C:\Python23\tcl\tcl8.4
> TEMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
> TK_LIBRARY=C:\Python23\tcl\tk8.4
> TMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
> USERDOMAIN=IBMT43-AMG
> USERNAME=Sys Admin
> USERPROFILE=C:\Documents and Settings\Sys Admin
> windir=C:\WINDOWS
> On Thursday 09 June 2005 12:44 pm, Thomas D. Uram wrote:
> > Can you resend that logfile so I can see if anything's changed?
> > Can you start a command window, execute the 'set' command, and send
> > the results?
> > Thanks,
> > Tom
> > On 06/09/05 11:36, Anne Gorczyca wrote:
> > > Tom,
> > > Thanks, but I've just removed PYTHONCASEOK entirely as an
> > > environment variable and restarted the machine. Problem still
> > > exists.
> > > Anne
> > > On Thursday 09 June 2005 12:28 pm, Thomas D. Uram wrote:
> > >>I talked with Anne today in the test meeting, but wanted to
> > >> respond for the benefit of any one on the list who is installing
> > >> on a newer Thinkpad.
> > >>The telltale sign of this problem is this exception:
> > >>NameError: global name 'TupleType' is not defined
> > >>The problem arises due to environment variable settings added by
> > >> IBM. The offending variable is PYTHONCASEOK. To fix the
> > >> problem, delete this environment variable from the list (if it
> > >> is set to any value whatsoever, the problem will remain). (It's
> > >> in bugzilla also:
> > >> http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208)
> > >>Tom
> > >>On 06/09/05 10:11, Anne Gorczyca wrote:
> > >>>Hi everyone,
> > >>>I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43
> > >>>running XP w/ SP2. We've performed installations on several
> > >>> systems using the same set of files. However, after obtaining a
> > >>> certificate and trying to enter a venue, it lmost immediately
> > >>> pops up "Can not connect to venue located at
> > >>>https://vv2.mcs.anl.gov:9000/Venues/default. Please, try again."
> > >>>We've consulted the archives and the buglist and found out that
> > >>>there have been problems with the Thinkpads, but we've changed
> > >>> all the environmental variables to point to python23 instead of
> > >>> the python22 that comes preloaded from IBM. I've set
> > >>> GLOBUS_HOSTNAME to localhost even though I'm just trying to use
> > >>> wired ethernet, not WLAN. I've set PYTHONCASE to _unset_. What
> > >>> else can I try?
> > >>>When the client is brought up in debug mode this is what's
> > >>>displayed: C:\Python23\lib\fcntl.py:7: DeprecationWarning: the
> > >>>FCTNL module is deprecated; please us fcntl
> > >>> DeprecationWarning>
> > >>>C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS
> > >>>module is deprecated; please us termios
> > >>> DeprecationWarning>
> > >>>Attached is a portion of the VenueClient log showing one attempt
> > >>>this morning to connect to a venue.
> > >>>Thank you for any suggestions!
> > >>>Anne
> > >>>Anne M. Gorczyca
> > >>>M.I.T. Haystack Observatory
> > >>>Westford, MA 01886
> > >>>Phone: 781-981-5630
> > >>>FAX: 781-981-5766
> > >>>06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599
> > >>> INFO --------- END VenueClient 06/09/05 10:12:43 1040 DataStore
> > >>> datastore.py:1577 DEBUG Quitting thread 0 06/09/05 10:12:43
> > >>> 3412 DataStore datastore.py:1518 DEBUG Worker 0 gets cmd
> > >>> quit 06/09/05 10:12:43 3412 DataStore datastore.py:1531
> > >>> DEBUG Worker 0 exiting 06/09/05 10:12:43 3416 DataStore
> > >>> datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket,
> > >>> interrupted I/O operation, most likely shutting down. 06/09/05
> > >>> 10:12:43 1040 NodeService agnodeservice.py:113 INFO
> > >>> NodeService.Stop 06/09/05 10:12:43 1040 ServiceManager
> > >>> agservicemanager.py:84 INFO AGServiceManager.Shutdown 06/09/05
> > >>> 10:12:43 1040
> > >>>ServiceManager agservicemanager.py:85 INFO Remove services
> > >>> agservicemanager.py:379 INFO AGServiceManager.RemoveServices
> > >>> agservicemanager.py:87 INFO Stop network interface 06/09/05
> > >>> 10:12:43 3436 Hosting server.py:65 ERROR Exception in SOAP
> > >>> server main loop Traceback (most recent call last):
> > >>> File
> > >>>"C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.
> > >>>py " , line 63, in Run self._server.handle_request()
> > >>> File "C:\Python23\lib\SocketServer.py", line 217, in
> > >>>handle_request request, client_address = self.get_request()
> > >>> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
> > >>>140, in get_request sock, addr =
> > >>>ThreadingGSITCPSocketServer.get_request(self) File
> > >>>"C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> > >>>get_request self.socket.listen()
> > >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857,
> > >>> in listen raise ex
> > >>>GSITCPSocketException: an I/O operation was cancelled
> > >>>06/09/05 10:12:43 1040 Hosting server.py:97 ERROR
> > >>>server_close() failed Traceback (most recent call last):
> > >>> File
> > >>>py " , line 95, in Stop self._server.server_close()
> > >>> 1043, in server_close self.socket.close()
> > >>> 1020, in close IOBase.close(self)
> > >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176,
> > >>> in close raise ex
> > >>>IOBaseException: an uninitialied data structure was passed as
> > >>>argument 1 to globus_io_register_close 06/09/05 10:12:43 1040
> > >>>Hosting server.py:97 ERROR server_close() failed Traceback
> > >>> File
> > >>> in close raise ex
> > >>>argument 1 to globus_io_register_close 06/09/05 10:13:23 3008
> > >>>Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock:
> > >>>Connection to sntp server at ntp-1.accessgrid.org failed
> > >>> File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py",
> > >>> line 176, in __CheckForInvalidClock serverTime =
> > >>> GetSNTPTime(timeserver, timeout)
> > >>> File
> > >>> "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py",
> > >>> line 43, in GetSNTPTime client.sendto( data, (server, 123 ))
> > >>> gaierror: (7, 'getaddrinfo failed')
> > >>>06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using
> > >>>GLOBUS_HOSTNAME=localhost as set in the environment 06/09/05
> > >>>10:13:23 3008 CertificateManager certificatemanager.py:257
> > >>>DEBUG Opened repository C:\Documents and Settings\Sys
> > >>>Admin\Application Data\AccessGrid\Config\certRepo 06/09/05
> > >>> 10:13:23 3008 Toolkit toolkit.py:395 DEBUG Got repo.
> > >>> 06/09/05 10:13:23 3008 Toolkit toolkit.py:397 DEBUG looking
> > >>> in system ca dir: C:\Program
> > >>> Files\AGTk-2.3\Config\CAcertificates 06/09/05 10:13:23 3008
> > >>> Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
> > >>> 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not
> > >>> importing cert C:\Program
> > >>>Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0 06/09/05
> > >>> 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert:
> > >>> 45cc9e80.0 06/09/05 10:13:23 3008 Toolkit toolkit.py:406
> > >>> WARNING Not importing cert C:\Program
> > >>>Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0 06/09/05
> > >>> d1b603c3.0 06/09/05 10:13:23 3008 Toolkit toolkit.py:406
> > >>>Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0 06/09/05
> > >>> f18fa857.0 06/09/05 10:13:23 3008 Toolkit toolkit.py:406
> > >>>Files\AGTk-2.3\Config\CAcertificates\f18fa857.0 06/09/05
> > >>> 10:13:23 3008 Toolkit toolkit.py:410 DEBUG Init'ing globus.
> > >>> 06/09/05 10:13:23 3008 CertificateManager
> > >>> certificatemanager.py:734 DEBUG Configuring standard
> > >>> environment 06/09/05 10:13:23 3008 CertificateManager
> > >>> certificatemanager.py:802 DEBUG Using default identity
> > >>> /O=Access
> > >>>Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne
> > >>> Gorczyca 06/09/05 10:13:23 3008 CertificateManager
> > >>>certificatemanager.py:873 DEBUG Initializing environment with
> > >>> proxy cert for /O=Access
> > >>>certificatemanager.py:907 DEBUG Looking for identity (unused)
> > >>> None 06/09/05 10:13:23 3008 CertificateManager
> > >>>certificatemanager.py:892 DEBUG Configuring for user proxy
> > >>> issued from /O=Access
> > >>>certificatemanager.py:895 DEBUG Proxy
> > >>>C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05
> > >>>16:10:02 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG
> > >>>Done with globus. 06/09/05 10:13:23 3008 VenueClient
> > >>>venueclient.py:284 DEBUG __StartWebService: venueclient:
> > >>>https://localhost:11000/VenueClient 06/09/05 10:13:23 3008
> > >>>ServiceManager agservicemanager.py:75 INFO Using services
> > >>> dir: C:\Documents and Settings\Sys Admin\Application
> > >>>Data\AccessGrid\local_services 06/09/05 10:13:23 3008
> > >>>ServiceManager agservicemanager.py:414 INFO
> > >>>__DiscoverResources 06/09/05 10:13:23 3008 Toolkit
> > >>>config.py:997 INFO Using vfwscan to get devices 06/09/05
> > >>> 10:13:23 3008 Toolkit config.py:998 DEBUG vfwscanexe =
> > >>>C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe 06/09/05 10:13:23 3008
> > >>> Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image
> > >>> Capture (Win32)\n'] 06/09/05 10:13:23 3008 Toolkit
> > >>> config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture
> > >>> (Win32)'] 06/09/05 10:13:23 3008 VenueClient
> > >>> venueclient.py:293 DEBUG
> > >>>__StartWebService: service manager:
> > >>>https://localhost:11000/ServiceManager 06/09/05 10:13:23 3008
> > >>>NodeService agnodeservice.py:733 INFO
> > >>>NodeService.__ReadConfigFile 06/09/05 10:13:23 3008 Toolkit
> > >>>toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys
> > >>>Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
> > >>> 06/09/05 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking
> > >>> for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> > >>> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:741
> > >>> DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program
> > >>>Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05 10:13:23 3008
> > >>>NodeService agnodeservice.py:745 INFO Reading node service
> > >>>config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> > >>>06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG
> > >>>__StartWebService: node service:
> > >>>https://localhost:11000/NodeService 06/09/05 10:13:23 3008
> > >>>VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node
> > >>>service url: https://localhost:11000/NodeService 06/09/05
> > >>> 10:13:23 3008 NodeService agnodeservice.py:675 INFO
> > >>>NodeService.GetDefaultConfiguration 06/09/05 10:13:23 3008
> > >>>NodeService agnodeservice.py:558 INFO Migration unnecessary
> > >>>06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO
> > >>>NodeService.LoadDefaultConfig 06/09/05 10:13:23 3008 NodeService
> > >>> agnodeservice.py:355 INFO Loading default node configuration:
> > >>>defaultWindows 06/09/05 10:13:23 3008 NodeService
> > >>>agnodeservice.py:369 INFO NodeService.LoadConfiguration
> > >>> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:384
> > >>> INFO Trying to load node configuration from: C:\Documents and
> > >>> Data\AccessGrid\Config\nodeConfig\defaultWindows 06/09/05
> > >>> 10:13:23 3008 NodeService agnodeservice.py:457 INFO
> > >>> AddServiceManager: Invalid service manager url
> > >>>(https://localhost:11000/ServiceManager) 06/09/05 10:13:23 3008
> > >>>NodeService agnodeservice.py:358 ERROR Exception loading
> > >>>default configuration. Traceback (most recent call last):
> > >>> File
> > >>> "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> > >>> line 356, in LoadDefaultConfig self.LoadConfiguration(
> > >>>self.defaultConfig )
> > >>> File
> > >>> line 500, in LoadConfiguration raise Exception(exceptionText)
> > >>> Exception: Couldn't reach service manager: localhost:11000
> > >>> 06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR
> > >>> Error loading default configuration Traceback (most recent call
> > >>> last):
> > >>> File
> > >>> "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
> > >>> 308, in __StartWebService self.ns.LoadDefaultConfig() File
> > >>> line 359, in LoadDefaultConfig raise Exception("Failed to load
> > >>> default configuration <%s>" % Exception: Failed to load default
> > >>> configuration <defaultWindows> 06/09/05 10:13:23 3008
> > >>> VenueClient venueclient.py:182 DEBUG __createPersonalDataStore:
> > >>> Creating personal datastore at C:\Documents and Settings\Sys
> > >>>Admin\Application Data\AccessGrid\Config\personalDataStore using
> > >>>prefix personalDataStore and port 0 06/09/05 10:13:23 3008
> > >>>DataStore datastore.py:1500 DEBUG Creating thread 0 06/09/05
> > >>>10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting
> > >>> thread 0 06/09/05 10:13:23 3088 DataStore datastore.py:1513
> > >>> DEBUG Worker 0 starting 06/09/05 10:13:23 3008 DataStore
> > >>>datastore.py:1507 DEBUG Waiting thread 0 06/09/05 10:13:23 3008
> > >>>DataStore datastore.py:1510 DEBUG Done creating workers
> > >>>06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG
> > >>> Reading persisted data from: C:\Documents and Settings\Sys
> > >>>Admin\Application
> > >>>Data\AccessGrid\Config\personalDataStore\DataStore.dat 06/09/05
> > >>>10:13:23 3008 VenueClient venueclient.py:207 DEBUG
> > >>>__createPersonalDataStore: Load personal data from file 06/09/05
> > >>>10:13:23 3008 VenueClientController
> > >>>venueclientcontroller.py:1277 DEBUG There is no personal venues
> > >>>file to load. 06/09/05 10:13:27 3008 VenueClient
> > >>>venueclient.py:803 DEBUG EnterVenue;
> > >>>url=https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05
> > >>> 10:13:27 3008 CertificateManager certificatemanager.py:907
> > >>> DEBUG Looking for identity (unused) None 06/09/05 10:13:27 3008
> > >>> CertificateManager certificatemanager.py:638 DEBUG
> > >>>HaveValidProxy: found proxy ident /O=Access
> > >>>Gorczyca/CN=proxy 06/09/05 10:13:27 3008 CertificateManager
> > >>> None 06/09/05 10:13:27 3008 CertificateManager
> > >>>certificatemanager.py:638 DEBUG HaveValidProxy: found proxy
> > >>> ident /O=Access
> > >>> Gorczyca/CN=proxy 06/09/05 10:13:27 3008 VenueClient
> > >>>venueclient.py:830 INFO EnterVenue: Error getting node
> > >>>capabilities 06/09/05 10:13:27 3008 VenueClient
> > >>>venueclient.py:702 DEBUG EnterVenue: Invoke venue enter 06/09/05
> > >>>10:13:27 3008 VenueClient venueclient.py:863 ERROR
> > >>> EnterVenue: failed Traceback (most recent call last):
> > >>> File
> > >>> 834, in EnterVenue self.__EnterVenue(URL)
> > >>> File
> > >>> 703, in __EnterVenue (venueState, self.privateId,
> > >>>self.streamDescList ) = self.__venueProxy.Enter( self.profile )
> > >>>File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
> > >>>3331, in Enter (r1, r2, r3) = self.proxy.Enter(profile)
> > >>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line
> > >>> 453, in __call__ return self.__r_call(*args, **kw)
> > >>> 475, in __r_call self.__hd, self.__ma)
> > >>> 338, in __call config = self.config, noroot = self.noroot)
> > >>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py",
> > >>> line 620, in buildSOAP return t.build()
> > >>> line 118, in build body_ns = self.genns(ns_map, NS.ENV)[0]
> > >>> line 204, in genns if type(nsURI) == TupleType: # already a
> > >>> tuple NameError: global name 'TupleType' is not defined
> > >>>06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959
> > >>> DEBUG bin.VenueClient::EnterVenue: Enter venue with url:
> > >>>https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27
> > >>> 3008 VenueClient venueclientui.py:1972 DEBUG warningString:
> > !DSPAM:42a8720522495123898698!
06/09/05 12:30:55 3764 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=localhost as set in the environment
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:257 DEBUG Opened repository C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\certRepo
06/09/05 12:30:56 3764 Toolkit toolkit.py:395 DEBUG Got repo.
06/09/05 12:30:56 3764 Toolkit toolkit.py:397 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
06/09/05 12:30:56 3764 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
06/09/05 12:30:56 3764 Toolkit toolkit.py:410 DEBUG Init'ing globus.
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:734 DEBUG Configuring standard environment
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:802 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:873 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:892 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 12:30:56 3764 CertificateManager certificatemanager.py:895 DEBUG Proxy C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05 16:10:02
06/09/05 12:30:56 3764 Toolkit toolkit.py:414 DEBUG Done with globus.
06/09/05 12:30:56 3764 VenueClient venueclient.py:284 DEBUG __StartWebService: venueclient: https://localhost:11000/VenueClient
06/09/05 12:30:56 3764 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\local_services
06/09/05 12:30:56 3764 ServiceManager agservicemanager.py:414 INFO __DiscoverResources
06/09/05 12:30:56 3764 Toolkit config.py:997 INFO Using vfwscan to get devices
06/09/05 12:30:56 3764 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe
06/09/05 12:30:56 3764 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
06/09/05 12:30:56 3764 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
06/09/05 12:30:56 3764 VenueClient venueclient.py:293 DEBUG __StartWebService: service manager: https://localhost:11000/ServiceManager
06/09/05 12:30:56 3764 NodeService agnodeservice.py:733 INFO NodeService.__ReadConfigFile
06/09/05 12:30:56 3764 Toolkit toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
06/09/05 12:30:56 3764 Toolkit toolkit.py:333 DEBUG Looking for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 12:30:56 3764 NodeService agnodeservice.py:741 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 12:30:56 3764 NodeService agnodeservice.py:745 INFO Reading node service config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 12:30:56 3764 VenueClient venueclient.py:299 DEBUG __StartWebService: node service: https://localhost:11000/NodeService
06/09/05 12:30:56 3764 VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node service url: https://localhost:11000/NodeService
06/09/05 12:30:56 3764 NodeService agnodeservice.py:675 INFO NodeService.GetDefaultConfiguration
06/09/05 12:30:56 3764 NodeService agnodeservice.py:558 INFO Migration unnecessary
06/09/05 12:30:56 3764 NodeService agnodeservice.py:351 INFO NodeService.LoadDefaultConfig
06/09/05 12:30:56 3764 NodeService agnodeservice.py:355 INFO Loading default node configuration: defaultWindows
06/09/05 12:30:56 3764 NodeService agnodeservice.py:369 INFO NodeService.LoadConfiguration
06/09/05 12:30:56 3764 NodeService agnodeservice.py:384 INFO Trying to load node configuration from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
06/09/05 12:30:56 3764 NodeService agnodeservice.py:457 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
06/09/05 12:30:56 3764 NodeService agnodeservice.py:358 ERROR Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 356, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 500, in LoadConfiguration
06/09/05 12:30:56 3764 VenueClient venueclient.py:310 ERROR Error loading default configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 308, in __StartWebService
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
06/09/05 12:30:56 3764 VenueClient venueclient.py:182 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
06/09/05 12:30:56 3764 DataStore datastore.py:1500 DEBUG Creating thread 0
06/09/05 12:30:56 3764 DataStore datastore.py:1505 DEBUG Starting thread 0
06/09/05 12:30:56 1680 DataStore datastore.py:1513 DEBUG Worker 0 starting
06/09/05 12:30:56 3764 DataStore datastore.py:1507 DEBUG Waiting thread 0
06/09/05 12:30:56 3764 DataStore datastore.py:1510 DEBUG Done creating workers
06/09/05 12:30:56 3764 DataStore datastore.py:263 DEBUG Reading persisted data from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
06/09/05 12:30:56 3764 VenueClient venueclient.py:207 DEBUG __createPersonalDataStore: Load personal data from file
06/09/05 12:30:56 3764 VenueClientController venueclientcontroller.py:1277 DEBUG There is no personal venues file to load.
06/09/05 12:31:01 3764 VenueClient venueclient.py:803 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 12:31:01 3764 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 12:31:01 3764 CertificateManager certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca/CN=proxy
06/09/05 12:31:01 3764 VenueClient venueclient.py:830 INFO EnterVenue: Error getting node capabilities
06/09/05 12:31:01 3764 VenueClient venueclient.py:702 DEBUG EnterVenue: Invoke venue enter
06/09/05 12:31:01 3764 VenueClient venueclient.py:863 ERROR EnterVenue: failed
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 834, in EnterVenue
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 703, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331, in Enter
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in buildSOAP
return t.build()
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in build
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in genns
if type(nsURI) == TupleType: # already a tuple
06/09/05 12:31:01 3764 VenueClient venueclientui.py:1959 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 12:31:01 3764 VenueClient venueclientui.py:1972 DEBUG warningString:
06/09/05 12:31:16 3764 VenueClient venueclientui.py:1599 INFO --------- END VenueClient
06/09/05 12:31:16 3764 DataStore datastore.py:1577 DEBUG Quitting thread 0
06/09/05 12:31:16 1680 DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
06/09/05 12:31:16 1680 DataStore datastore.py:1531 DEBUG Worker 0 exiting
06/09/05 12:31:16 1252 DataStore datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
06/09/05 12:31:16 3764 NodeService agnodeservice.py:113 INFO NodeService.Stop
06/09/05 12:31:16 3764 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
06/09/05 12:31:16 3764 ServiceManager agservicemanager.py:85 INFO Remove services
06/09/05 12:31:16 3764 ServiceManager agservicemanager.py:379 INFO AGServiceManager.RemoveServices
06/09/05 12:31:16 3764 ServiceManager agservicemanager.py:87 INFO Stop network interface
06/09/05 12:31:16 284 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
06/09/05 12:31:16 3764 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
