[AG-TECH] Can not enter venue with Thinkpad T43
Andrew Patrick
Andrew.Patrick at nrc-cnrc.gc.ca
Thu Jun 9 11:49:35 CDT 2005
When you say ...
I've set PYTHONCASE to _unset_.
What you should be doing is removing the environment variable PYTHONCASEOK. What
is necessary is not setting it to the string "_unset_" but rather removing the
variable completely.
Specific steps to do this are
- right-click on My Computer icon on the desktop
- select Properties
- select the Advanced tab
- select the Environment Variables button
- find the PYTHONCASEOK variable in the list of System Variables and delete it
- close the Properties windows and reboot
When I configure my Thinkpad for AG, I also edit the PATH to remove references
to Python22 and add a reference to Python23. I also remove the PYTHONPATH,
TCL_LIBRARY and TK_LIBRARY variables. These steps may not be necessary.
I have also found that if you use any of the IBM utilities (such as system
recovery and managing passwords) that rely on Python22, these variables can get
set again.
Anne Gorczyca wrote:
> Hi everyone,
> I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43 running
> XP w/ SP2. We've performed installations on several systems using the
> same set of files. However, after obtaining a certificate and trying to
> enter a venue, it lmost immediately pops up "Can not connect to venue
> located at https://vv2.mcs.anl.gov:9000/Venues/default. Please, try
> again."
> We've consulted the archives and the buglist and found out that there
> have been problems with the Thinkpads, but we've changed all the
> environmental variables to point to python23 instead of the python22
> that comes preloaded from IBM. I've set GLOBUS_HOSTNAME to localhost
> even though I'm just trying to use wired ethernet, not WLAN. I've set
> PYTHONCASE to _unset_. What else can I try?
> When the client is brought up in debug mode this is what's displayed:
> C:\Python23\lib\fcntl.py:7: DeprecationWarning: the FCTNL module is
> deprecated; please us fcntl
> DeprecationWarning>
> C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS module is
> deprecated; please us termios
> DeprecationWarning>
> Attached is a portion of the VenueClient log showing one attempt this
> morning to connect to a venue.
> Thank you for any suggestions!
> Anne
> Anne M. Gorczyca
> amg at haystack.mit.edu
> M.I.T. Haystack Observatory
> Westford, MA 01886
> Phone: 781-981-5630
> FAX: 781-981-5766
> 06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO --------- END VenueClient
> 06/09/05 10:12:43 1040 DataStore datastore.py:1577 DEBUG Quitting thread 0
> 06/09/05 10:12:43 3412 DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
> 06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG Worker 0 exiting
> 06/09/05 10:12:43 3416 DataStore datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
> 06/09/05 10:12:43 1040 NodeService agnodeservice.py:113 INFO NodeService.Stop
> 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
> 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:85 INFO Remove services
> 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379 INFO AGServiceManager.RemoveServices
> 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:87 INFO Stop network interface
> 06/09/05 10:12:43 3436 Hosting server.py:65 ERROR Exception in SOAP server main loop
> Traceback (most recent call last):
> File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
> self._server.handle_request()
> File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
> request, client_address = self.get_request()
> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
> sock, addr = ThreadingGSITCPSocketServer.get_request(self)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
> self.socket.listen()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
> raise ex
> GSITCPSocketException: an I/O operation was cancelled
> 06/09/05 10:12:43 1040 Hosting server.py:97 ERROR server_close() failed
> File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
> self._server.server_close()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
> self.socket.close()
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
> IOBase.close(self)
> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
> raise ex
> IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
> self.socket.close()
> IOBase.close(self)
> raise ex
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock: Connection to sntp server at ntp-1.accessgrid.org failed
> File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line 176, in __CheckForInvalidClock
> serverTime = GetSNTPTime(timeserver, timeout)
> File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py", line 43, in GetSNTPTime
> client.sendto( data, (server, 123 ))
> gaierror: (7, 'getaddrinfo failed')
> 06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=localhost as set in the environment
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:257 DEBUG Opened repository C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\certRepo
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:395 DEBUG Got repo.
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:397 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:410 DEBUG Init'ing globus.
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:734 DEBUG Configuring standard environment
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:802 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:873 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:892 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> 06/09/05 10:13:23 3008 CertificateManager certificatemanager.py:895 DEBUG Proxy C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05 16:10:02
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG Done with globus.
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:284 DEBUG __StartWebService: venueclient: https://localhost:11000/VenueClient
> 06/09/05 10:13:23 3008 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\local_services
> 06/09/05 10:13:23 3008 ServiceManager agservicemanager.py:414 INFO __DiscoverResources
> 06/09/05 10:13:23 3008 Toolkit config.py:997 INFO Using vfwscan to get devices
> 06/09/05 10:13:23 3008 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe
> 06/09/05 10:13:23 3008 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
> 06/09/05 10:13:23 3008 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:293 DEBUG __StartWebService: service manager: https://localhost:11000/ServiceManager
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:733 INFO NodeService.__ReadConfigFile
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
> 06/09/05 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:745 INFO Reading node service config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG __StartWebService: node service: https://localhost:11000/NodeService
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node service url: https://localhost:11000/NodeService
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:675 INFO NodeService.GetDefaultConfiguration
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:558 INFO Migration unnecessary
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO NodeService.LoadDefaultConfig
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:355 INFO Loading default node configuration: defaultWindows
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:369 INFO NodeService.LoadConfiguration
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to load node configuration from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
> 06/09/05 10:13:23 3008 NodeService agnodeservice.py:358 ERROR Exception loading default configuration.
> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 356, in LoadDefaultConfig
> self.LoadConfiguration( self.defaultConfig )
> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 500, in LoadConfiguration
> raise Exception(exceptionText)
> Exception: Couldn't reach service manager: localhost:11000
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR Error loading default configuration
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 308, in __StartWebService
> self.ns.LoadDefaultConfig()
> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359, in LoadDefaultConfig
> raise Exception("Failed to load default configuration <%s>" %
> Exception: Failed to load default configuration <defaultWindows>
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:182 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
> 06/09/05 10:13:23 3008 DataStore datastore.py:1500 DEBUG Creating thread 0
> 06/09/05 10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting thread 0
> 06/09/05 10:13:23 3088 DataStore datastore.py:1513 DEBUG Worker 0 starting
> 06/09/05 10:13:23 3008 DataStore datastore.py:1507 DEBUG Waiting thread 0
> 06/09/05 10:13:23 3008 DataStore datastore.py:1510 DEBUG Done creating workers
> 06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG Reading persisted data from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
> 06/09/05 10:13:23 3008 VenueClient venueclient.py:207 DEBUG __createPersonalDataStore: Load personal data from file
> 06/09/05 10:13:23 3008 VenueClientController venueclientcontroller.py:1277 DEBUG There is no personal venues file to load.
> 06/09/05 10:13:27 3008 VenueClient venueclient.py:803 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 06/09/05 10:13:27 3008 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
> 06/09/05 10:13:27 3008 CertificateManager certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca/CN=proxy
> 06/09/05 10:13:27 3008 VenueClient venueclient.py:830 INFO EnterVenue: Error getting node capabilities
> 06/09/05 10:13:27 3008 VenueClient venueclient.py:702 DEBUG EnterVenue: Invoke venue enter
> 06/09/05 10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue: failed
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 834, in EnterVenue
> self.__EnterVenue(URL)
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 703, in __EnterVenue
> (venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
> File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331, in Enter
> (r1, r2, r3) = self.proxy.Enter(profile)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
> return self.__r_call(*args, **kw)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
> self.__hd, self.__ma)
> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
> config = self.config, noroot = self.noroot)
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in buildSOAP
> return t.build()
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in build
> body_ns = self.genns(ns_map, NS.ENV)[0]
> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in genns
> if type(nsURI) == TupleType: # already a tuple
> NameError: global name 'TupleType' is not defined
> 06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
> 06/09/05 10:13:27 3008 VenueClient venueclientui.py:1972 DEBUG warningString:
Andrew Patrick, Ph.D.
Senior Scientist
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
E-mail: Andrew.Patrick at nrc-cnrc.gc.ca
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
WWW - Personal: http://www.andrewpatrick.ca
Phone: (613) 991-3374 Fax: (613) 952-7151 Cell/SMS: (613) 277-9211
