[AG-TECH] Can not enter venue with Thinkpad T43
Anne Gorczyca
amg at haystack.mit.edu
Thu Jun 9 14:47:58 CDT 2005
Tom,
New logfile is attached.
Results of set after removing PYTHONCASEOK from environment:
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Sys Admin\Application Data
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=IBMT43-AMG
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
GLOBUS_HOSTNAME=localhost
HOMEDIR=C:\Program Files\mbone
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Sys Admin
IBMSHARE=C:\IBMSHARE
LOGONSERVER=\\IBMT43-AMG
NUMBER_OF_PROCESSORS=1
OS=Windows_NT
Path=C:\Python23\.;C:\Program Files\ThinkPad\Utilities;C:\system32;C:;C:\System32\Wbem;C:\Program Files\Intel\Wireless\Bin\;C:\Program Files\ATI Technologies\ATI Control Panel;C:\WINDOWS\Downloaded Program Files;C:\IBMTOOLS\Python22;C:\Program Files\PC-Doctor for Windows\services;C:\Program Files\SecureCRT\;C:\Program Files\Mbone
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.pyo;.pyc;.py;.pyw;.pys
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 13 Stepping 8, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0d08
PROMPT=$P$G
PYTHONPATH=C:\IBMTOOLS\utils\support;C:\IBMTOOLS\utils\logger
RRU=C:\Program Files\IBM\IBM Rapid Restore Ultra\
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TCL_LIBRARY=C:\Python23\tcl\tcl8.4
TEMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
TK_LIBRARY=C:\Python23\tcl\tk8.4
TMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
USERDOMAIN=IBMT43-AMG
USERNAME=Sys Admin
USERPROFILE=C:\Documents and Settings\Sys Admin
windir=C:\WINDOWS
On Thursday 09 June 2005 12:44 pm, Thomas D. Uram wrote:
> Can you resend that logfile so I can see if anything's changed?
> Can you start a command window, execute the 'set' command, and send
> the results?
> Thanks,
> Tom
> On 06/09/05 11:36, Anne Gorczyca wrote:
> > Tom,
> > Thanks, but I've just removed PYTHONCASEOK entirely as an
> > environment variable and restarted the machine. Problem still
> > exists.
> > Anne
> > On Thursday 09 June 2005 12:28 pm, Thomas D. Uram wrote:
> >>I talked with Anne today in the test meeting, but wanted to respond
> >>for the benefit of any one on the list who is installing on a newer
> >>Thinkpad.
> >>The telltale sign of this problem is this exception:
> >>NameError: global name 'TupleType' is not defined
> >>The problem arises due to environment variable settings added by
> >> IBM. The offending variable is PYTHONCASEOK. To fix the problem,
> >> delete this environment variable from the list (if it is set to
> >> any value whatsoever, the problem will remain). (It's in bugzilla
> >> also: http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208)
> >>Tom
> >>On 06/09/05 10:11, Anne Gorczyca wrote:
> >>>Hi everyone,
> >>>I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43
> >>>running XP w/ SP2. We've performed installations on several
> >>> systems using the same set of files. However, after obtaining a
> >>> certificate and trying to enter a venue, it lmost immediately
> >>> pops up "Can not connect to venue located at
> >>>https://vv2.mcs.anl.gov:9000/Venues/default. Please, try again."
> >>>We've consulted the archives and the buglist and found out that
> >>>there have been problems with the Thinkpads, but we've changed all
> >>>the environmental variables to point to python23 instead of the
> >>>python22 that comes preloaded from IBM. I've set GLOBUS_HOSTNAME
> >>> to localhost even though I'm just trying to use wired ethernet,
> >>> not WLAN. I've set PYTHONCASE to _unset_. What else can I try?
> >>>When the client is brought up in debug mode this is what's
> >>>displayed: C:\Python23\lib\fcntl.py:7: DeprecationWarning: the
> >>>FCTNL module is deprecated; please us fcntl
> >>> DeprecationWarning>
> >>>C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS
> >>>module is deprecated; please us termios
> >>> DeprecationWarning>
> >>>Attached is a portion of the VenueClient log showing one attempt
> >>>this morning to connect to a venue.
> >>>Thank you for any suggestions!
> >>>Anne
> >>>Anne M. Gorczyca
> >>>M.I.T. Haystack Observatory
> >>>Westford, MA 01886
> >>>Phone: 781-981-5630
> >>>FAX: 781-981-5766
> >>>06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO
> >>>--------- END VenueClient 06/09/05 10:12:43 1040 DataStore
> >>>datastore.py:1577 DEBUG Quitting thread 0 06/09/05 10:12:43 3412
> >>>DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
> >>>06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG
> >>> Worker 0 exiting 06/09/05 10:12:43 3416 DataStore
> >>> datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket,
> >>> interrupted I/O operation, most likely shutting down. 06/09/05
> >>> 10:12:43 1040 NodeService agnodeservice.py:113 INFO
> >>> NodeService.Stop 06/09/05 10:12:43 1040 ServiceManager
> >>> agservicemanager.py:84 INFO AGServiceManager.Shutdown 06/09/05
> >>> 10:12:43 1040
> >>>ServiceManager agservicemanager.py:85 INFO Remove services
> >>>06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379
> >>>INFO AGServiceManager.RemoveServices 06/09/05 10:12:43 1040
> >>>ServiceManager agservicemanager.py:87 INFO Stop network
> >>>interface 06/09/05 10:12:43 3436 Hosting server.py:65 ERROR
> >>>Exception in SOAP server main loop Traceback (most recent call
> >>>last):
> >>> File
> >>>"C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py
> >>>" , line 63, in Run self._server.handle_request()
> >>> File "C:\Python23\lib\SocketServer.py", line 217, in
> >>>handle_request request, client_address = self.get_request()
> >>> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
> >>>140, in get_request sock, addr =
> >>>ThreadingGSITCPSocketServer.get_request(self) File
> >>>"C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> >>>get_request self.socket.listen()
> >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857,
> >>> in listen raise ex
> >>>GSITCPSocketException: an I/O operation was cancelled
> >>>06/09/05 10:12:43 1040 Hosting server.py:97 ERROR
> >>>server_close() failed Traceback (most recent call last):
> >>> File
> >>>" , line 95, in Stop self._server.server_close()
> >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043,
> >>>in server_close self.socket.close()
> >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020,
> >>>in close IOBase.close(self)
> >>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176,
> >>> in close raise ex
> >>>IOBaseException: an uninitialied data structure was passed as
> >>>argument 1 to globus_io_register_close 06/09/05 10:12:43 1040
> >>>Hosting server.py:97 ERROR server_close() failed Traceback
> >>> File
> >>> in close raise ex
> >>>argument 1 to globus_io_register_close 06/09/05 10:13:23 3008
> >>>Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock:
> >>>Connection to sntp server at ntp-1.accessgrid.org failed Traceback
> >>> File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line
> >>>176, in __CheckForInvalidClock serverTime =
> >>> GetSNTPTime(timeserver, timeout)
> >>> File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py",
> >>>line 43, in GetSNTPTime client.sendto( data, (server, 123 ))
> >>>gaierror: (7, 'getaddrinfo failed')
> >>>06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using
> >>>GLOBUS_HOSTNAME=localhost as set in the environment 06/09/05
> >>>10:13:23 3008 CertificateManager certificatemanager.py:257
> >>>DEBUG Opened repository C:\Documents and Settings\Sys
> >>>Admin\Application Data\AccessGrid\Config\certRepo 06/09/05
> >>> 10:13:23 3008 Toolkit toolkit.py:395 DEBUG Got repo. 06/09/05
> >>> 10:13:23 3008 Toolkit toolkit.py:397 DEBUG looking in system
> >>> ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates 06/09/05
> >>> 10:13:23 3008 Toolkit toolkit.py:401 DEBUG Getting cert:
> >>> 1c3f2ca8.0 06/09/05 10:13:23 3008 Toolkit toolkit.py:406
> >>> WARNING Not importing cert C:\Program
> >>>Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0 06/09/05 10:13:23
> >>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
> >>>06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not
> >>>Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0 06/09/05 10:13:23
> >>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
> >>>Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0 06/09/05 10:13:23
> >>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
> >>>Files\AGTk-2.3\Config\CAcertificates\f18fa857.0 06/09/05 10:13:23
> >>>3008 Toolkit toolkit.py:410 DEBUG Init'ing globus. 06/09/05
> >>>10:13:23 3008 CertificateManager certificatemanager.py:734
> >>>DEBUG Configuring standard environment 06/09/05 10:13:23 3008
> >>>CertificateManager certificatemanager.py:802 DEBUG Using
> >>>default identity /O=Access
> >>>Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> >>>06/09/05 10:13:23 3008 CertificateManager
> >>>certificatemanager.py:873 DEBUG Initializing environment with
> >>> proxy cert for /O=Access
> >>>certificatemanager.py:907 DEBUG Looking for identity (unused) None
> >>>certificatemanager.py:892 DEBUG Configuring for user proxy issued
> >>>from /O=Access
> >>>certificatemanager.py:895 DEBUG Proxy
> >>>C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05
> >>>16:10:02 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG
> >>>Done with globus. 06/09/05 10:13:23 3008 VenueClient
> >>>venueclient.py:284 DEBUG __StartWebService: venueclient:
> >>>https://localhost:11000/VenueClient 06/09/05 10:13:23 3008
> >>>ServiceManager agservicemanager.py:75 INFO Using services
> >>> dir: C:\Documents and Settings\Sys Admin\Application
> >>>Data\AccessGrid\local_services 06/09/05 10:13:23 3008
> >>>ServiceManager agservicemanager.py:414 INFO
> >>>__DiscoverResources 06/09/05 10:13:23 3008 Toolkit
> >>>config.py:997 INFO Using vfwscan to get devices 06/09/05 10:13:23
> >>>3008 Toolkit config.py:998 DEBUG vfwscanexe =
> >>>C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe 06/09/05 10:13:23 3008
> >>> Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image
> >>> Capture (Win32)\n'] 06/09/05 10:13:23 3008 Toolkit
> >>> config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture
> >>> (Win32)'] 06/09/05 10:13:23 3008 VenueClient
> >>> venueclient.py:293 DEBUG
> >>>__StartWebService: service manager:
> >>>https://localhost:11000/ServiceManager 06/09/05 10:13:23 3008
> >>>NodeService agnodeservice.py:733 INFO
> >>>NodeService.__ReadConfigFile 06/09/05 10:13:23 3008 Toolkit
> >>>toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys
> >>>Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
> >>> 06/09/05 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking
> >>> for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05
> >>> 10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT
> >>> NODE SERVICE CONFIG: C:\Program
> >>>Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05 10:13:23 3008
> >>>NodeService agnodeservice.py:745 INFO Reading node service
> >>>config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> >>>06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG
> >>>__StartWebService: node service:
> >>>https://localhost:11000/NodeService 06/09/05 10:13:23 3008
> >>>VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node
> >>>service url: https://localhost:11000/NodeService 06/09/05
> >>> 10:13:23 3008 NodeService agnodeservice.py:675 INFO
> >>>NodeService.GetDefaultConfiguration 06/09/05 10:13:23 3008
> >>>NodeService agnodeservice.py:558 INFO Migration unnecessary
> >>>06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO
> >>>NodeService.LoadDefaultConfig 06/09/05 10:13:23 3008 NodeService
> >>> agnodeservice.py:355 INFO Loading default node configuration:
> >>>defaultWindows 06/09/05 10:13:23 3008 NodeService
> >>>agnodeservice.py:369 INFO NodeService.LoadConfiguration 06/09/05
> >>>10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to
> >>>load node configuration from: C:\Documents and Settings\Sys
> >>>Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
> >>>06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO
> >>>AddServiceManager: Invalid service manager url
> >>>(https://localhost:11000/ServiceManager) 06/09/05 10:13:23 3008
> >>>NodeService agnodeservice.py:358 ERROR Exception loading
> >>>default configuration. Traceback (most recent call last):
> >>> File
> >>> "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line
> >>> 356, in LoadDefaultConfig self.LoadConfiguration(
> >>>self.defaultConfig )
> >>> File
> >>> 500, in LoadConfiguration raise Exception(exceptionText)
> >>> Exception: Couldn't reach service manager: localhost:11000
> >>> 06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR
> >>> Error loading default configuration Traceback (most recent call
> >>> last):
> >>> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py",
> >>>line 308, in __StartWebService self.ns.LoadDefaultConfig()
> >>> File
> >>> 359, in LoadDefaultConfig raise Exception("Failed to load default
> >>> configuration <%s>" % Exception: Failed to load default
> >>> configuration <defaultWindows> 06/09/05 10:13:23 3008 VenueClient
> >>> venueclient.py:182 DEBUG __createPersonalDataStore: Creating
> >>> personal datastore at C:\Documents and Settings\Sys
> >>>Admin\Application Data\AccessGrid\Config\personalDataStore using
> >>>prefix personalDataStore and port 0 06/09/05 10:13:23 3008
> >>>DataStore datastore.py:1500 DEBUG Creating thread 0 06/09/05
> >>>10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting
> >>> thread 0 06/09/05 10:13:23 3088 DataStore datastore.py:1513
> >>> DEBUG Worker 0 starting 06/09/05 10:13:23 3008 DataStore
> >>>datastore.py:1507 DEBUG Waiting thread 0 06/09/05 10:13:23 3008
> >>>DataStore datastore.py:1510 DEBUG Done creating workers
> >>>06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG
> >>> Reading persisted data from: C:\Documents and Settings\Sys
> >>>Admin\Application
> >>>Data\AccessGrid\Config\personalDataStore\DataStore.dat 06/09/05
> >>>10:13:23 3008 VenueClient venueclient.py:207 DEBUG
> >>>__createPersonalDataStore: Load personal data from file 06/09/05
> >>>10:13:23 3008 VenueClientController
> >>>venueclientcontroller.py:1277 DEBUG There is no personal venues
> >>>file to load. 06/09/05 10:13:27 3008 VenueClient
> >>>venueclient.py:803 DEBUG EnterVenue;
> >>>url=https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27
> >>>3008 CertificateManager certificatemanager.py:907 DEBUG
> >>> Looking for identity (unused) None 06/09/05 10:13:27 3008
> >>>CertificateManager certificatemanager.py:638 DEBUG
> >>>HaveValidProxy: found proxy ident /O=Access
> >>>Gorczyca/CN=proxy 06/09/05 10:13:27 3008 CertificateManager
> >>>certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident
> >>>/O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne
> >>>Gorczyca/CN=proxy 06/09/05 10:13:27 3008 VenueClient
> >>>venueclient.py:830 INFO EnterVenue: Error getting node
> >>>capabilities 06/09/05 10:13:27 3008 VenueClient
> >>>venueclient.py:702 DEBUG EnterVenue: Invoke venue enter 06/09/05
> >>>10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue:
> >>>line 834, in EnterVenue self.__EnterVenue(URL)
> >>>line 703, in __EnterVenue (venueState, self.privateId,
> >>>self.streamDescList ) = self.__venueProxy.Enter( self.profile )
> >>>File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
> >>>3331, in Enter (r1, r2, r3) = self.proxy.Enter(profile)
> >>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453,
> >>>in __call__ return self.__r_call(*args, **kw)
> >>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475,
> >>>in __r_call self.__hd, self.__ma)
> >>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338,
> >>>in __call config = self.config, noroot = self.noroot)
> >>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line
> >>>620, in buildSOAP return t.build()
> >>>118, in build body_ns = self.genns(ns_map, NS.ENV)[0]
> >>>204, in genns if type(nsURI) == TupleType: # already a tuple
> >>>06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG
> >>>bin.VenueClient::EnterVenue: Enter venue with url:
> >>>https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27 3008
> >>>VenueClient venueclientui.py:1972 DEBUG warningString:
> !DSPAM:42a8720522495123898698!
