[AG-TECH] Can not enter venue with Thinkpad T43
Thomas D. Uram
turam at mcs.anl.gov
Thu Jun 9 11:44:37 CDT 2005
Can you resend that logfile so I can see if anything's changed?
Can you start a command window, execute the 'set' command, and send the results?
Tom
On 06/09/05 11:36, Anne Gorczyca wrote:
> Tom,
> Thanks, but I've just removed PYTHONCASEOK entirely as an environment
> variable and restarted the machine. Problem still exists.
> Anne
> On Thursday 09 June 2005 12:28 pm, Thomas D. Uram wrote:
>>I talked with Anne today in the test meeting, but wanted to respond
>>for the benefit of any one on the list who is installing on a newer
>>Thinkpad.
>>The telltale sign of this problem is this exception:
>>NameError: global name 'TupleType' is not defined
>>The problem arises due to environment variable settings added by IBM.
>> The offending variable is PYTHONCASEOK. To fix the problem, delete
>>this environment variable from the list (if it is set to any value
>>whatsoever, the problem will remain). (It's in bugzilla also:
>>http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208)
>>Tom
>>On 06/09/05 10:11, Anne Gorczyca wrote:
>>>Hi everyone,
>>>I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43
>>>running XP w/ SP2. We've performed installations on several systems
>>>using the same set of files. However, after obtaining a certificate
>>>and trying to enter a venue, it lmost immediately pops up "Can not
>>>connect to venue located at
>>>https://vv2.mcs.anl.gov:9000/Venues/default. Please, try again."
>>>We've consulted the archives and the buglist and found out that
>>>there have been problems with the Thinkpads, but we've changed all
>>>the environmental variables to point to python23 instead of the
>>>python22 that comes preloaded from IBM. I've set GLOBUS_HOSTNAME to
>>>localhost even though I'm just trying to use wired ethernet, not
>>>WLAN. I've set PYTHONCASE to _unset_. What else can I try?
>>>When the client is brought up in debug mode this is what's
>>>displayed: C:\Python23\lib\fcntl.py:7: DeprecationWarning: the
>>>FCTNL module is deprecated; please us fcntl
>>> DeprecationWarning>
>>>C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS
>>>module is deprecated; please us termios
>>> DeprecationWarning>
>>>Attached is a portion of the VenueClient log showing one attempt
>>>this morning to connect to a venue.
>>>Thank you for any suggestions!
>>>Anne
>>>Anne M. Gorczyca
>>>amg at haystack.mit.edu
>>>M.I.T. Haystack Observatory
>>>Westford, MA 01886
>>>Phone: 781-981-5630
>>>FAX: 781-981-5766
>>>06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO
>>>--------- END VenueClient 06/09/05 10:12:43 1040 DataStore
>>>datastore.py:1577 DEBUG Quitting thread 0 06/09/05 10:12:43 3412
>>>DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
>>>06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG Worker
>>>0 exiting 06/09/05 10:12:43 3416 DataStore datastore.py:1590
>>>INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O
>>>operation, most likely shutting down. 06/09/05 10:12:43 1040
>>>NodeService agnodeservice.py:113 INFO NodeService.Stop
>>>06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:84
>>>INFO AGServiceManager.Shutdown 06/09/05 10:12:43 1040
>>>ServiceManager agservicemanager.py:85 INFO Remove services
>>>06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379
>>>INFO AGServiceManager.RemoveServices 06/09/05 10:12:43 1040
>>>ServiceManager agservicemanager.py:87 INFO Stop network
>>>interface 06/09/05 10:12:43 3436 Hosting server.py:65 ERROR
>>>Exception in SOAP server main loop Traceback (most recent call
>>>last):
>>> File
>>>"C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py"
>>>, line 63, in Run self._server.handle_request()
>>> File "C:\Python23\lib\SocketServer.py", line 217, in
>>>handle_request request, client_address = self.get_request()
>>> File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
>>>140, in get_request sock, addr =
>>>ThreadingGSITCPSocketServer.get_request(self) File
>>>"C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
>>>get_request self.socket.listen()
>>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
>>>listen raise ex
>>>GSITCPSocketException: an I/O operation was cancelled
>>>06/09/05 10:12:43 1040 Hosting server.py:97 ERROR
>>>server_close() failed Traceback (most recent call last):
>>> File
>>>, line 95, in Stop self._server.server_close()
>>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043,
>>>in server_close self.socket.close()
>>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020,
>>>in close IOBase.close(self)
>>> File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
>>>close raise ex
>>>IOBaseException: an uninitialied data structure was passed as
>>>argument 1 to globus_io_register_close 06/09/05 10:12:43 1040
>>>Hosting server.py:97 ERROR server_close() failed Traceback
>>> File
>>>close raise ex
>>>argument 1 to globus_io_register_close 06/09/05 10:13:23 3008
>>>Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock:
>>>Connection to sntp server at ntp-1.accessgrid.org failed Traceback
>>> File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line
>>>176, in __CheckForInvalidClock serverTime = GetSNTPTime(timeserver,
>>>timeout)
>>> File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py",
>>>line 43, in GetSNTPTime client.sendto( data, (server, 123 ))
>>>gaierror: (7, 'getaddrinfo failed')
>>>06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using
>>>GLOBUS_HOSTNAME=localhost as set in the environment 06/09/05
>>>10:13:23 3008 CertificateManager certificatemanager.py:257
>>>DEBUG Opened repository C:\Documents and Settings\Sys
>>>Admin\Application Data\AccessGrid\Config\certRepo 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:395 DEBUG Got repo. 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:397 DEBUG looking in system ca dir:
>>>C:\Program Files\AGTk-2.3\Config\CAcertificates 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
>>>06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not
>>>importing cert C:\Program
>>>Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
>>>Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
>>>Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
>>>Files\AGTk-2.3\Config\CAcertificates\f18fa857.0 06/09/05 10:13:23
>>>3008 Toolkit toolkit.py:410 DEBUG Init'ing globus. 06/09/05
>>>10:13:23 3008 CertificateManager certificatemanager.py:734
>>>DEBUG Configuring standard environment 06/09/05 10:13:23 3008
>>>CertificateManager certificatemanager.py:802 DEBUG Using
>>>default identity /O=Access
>>>Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
>>>06/09/05 10:13:23 3008 CertificateManager
>>>certificatemanager.py:873 DEBUG Initializing environment with proxy
>>>cert for /O=Access
>>>certificatemanager.py:907 DEBUG Looking for identity (unused) None
>>>certificatemanager.py:892 DEBUG Configuring for user proxy issued
>>>from /O=Access
>>>certificatemanager.py:895 DEBUG Proxy
>>>C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05
>>>16:10:02 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG
>>>Done with globus. 06/09/05 10:13:23 3008 VenueClient
>>>venueclient.py:284 DEBUG __StartWebService: venueclient:
>>>https://localhost:11000/VenueClient 06/09/05 10:13:23 3008
>>>ServiceManager agservicemanager.py:75 INFO Using services dir:
>>>C:\Documents and Settings\Sys Admin\Application
>>>Data\AccessGrid\local_services 06/09/05 10:13:23 3008
>>>ServiceManager agservicemanager.py:414 INFO
>>>__DiscoverResources 06/09/05 10:13:23 3008 Toolkit
>>>config.py:997 INFO Using vfwscan to get devices 06/09/05 10:13:23
>>>3008 Toolkit config.py:998 DEBUG vfwscanexe =
>>>C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe 06/09/05 10:13:23 3008 Toolkit
>>> config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture
>>>(Win32)\n'] 06/09/05 10:13:23 3008 Toolkit config.py:1031 INFO
>>>GetResources: ['Microsoft WDM Image Capture (Win32)'] 06/09/05
>>>10:13:23 3008 VenueClient venueclient.py:293 DEBUG
>>>__StartWebService: service manager:
>>>https://localhost:11000/ServiceManager 06/09/05 10:13:23 3008
>>>NodeService agnodeservice.py:733 INFO
>>>NodeService.__ReadConfigFile 06/09/05 10:13:23 3008 Toolkit
>>>toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys
>>>Admin\Application Data\AccessGrid\Config\AGNodeService.cfg 06/09/05
>>>10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking for:
>>>C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05
>>>10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT
>>>NODE SERVICE CONFIG: C:\Program
>>>Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05 10:13:23 3008
>>>NodeService agnodeservice.py:745 INFO Reading node service
>>>config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
>>>06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG
>>>__StartWebService: node service:
>>>https://localhost:11000/NodeService 06/09/05 10:13:23 3008
>>>VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node
>>>service url: https://localhost:11000/NodeService 06/09/05 10:13:23
>>>3008 NodeService agnodeservice.py:675 INFO
>>>NodeService.GetDefaultConfiguration 06/09/05 10:13:23 3008
>>>NodeService agnodeservice.py:558 INFO Migration unnecessary
>>>06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO
>>>NodeService.LoadDefaultConfig 06/09/05 10:13:23 3008 NodeService
>>> agnodeservice.py:355 INFO Loading default node configuration:
>>>defaultWindows 06/09/05 10:13:23 3008 NodeService
>>>agnodeservice.py:369 INFO NodeService.LoadConfiguration 06/09/05
>>>10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to
>>>load node configuration from: C:\Documents and Settings\Sys
>>>Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
>>>06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO
>>>AddServiceManager: Invalid service manager url
>>>(https://localhost:11000/ServiceManager) 06/09/05 10:13:23 3008
>>>NodeService agnodeservice.py:358 ERROR Exception loading
>>>default configuration. Traceback (most recent call last):
>>> File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
>>>line 356, in LoadDefaultConfig self.LoadConfiguration(
>>>self.defaultConfig )
>>>line 500, in LoadConfiguration raise Exception(exceptionText)
>>>Exception: Couldn't reach service manager: localhost:11000
>>>06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR
>>>Error loading default configuration Traceback (most recent call
>>>last):
>>> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py",
>>>line 308, in __StartWebService self.ns.LoadDefaultConfig()
>>>line 359, in LoadDefaultConfig raise Exception("Failed to load
>>>default configuration <%s>" % Exception: Failed to load default
>>>configuration <defaultWindows> 06/09/05 10:13:23 3008 VenueClient
>>> venueclient.py:182 DEBUG __createPersonalDataStore: Creating
>>>personal datastore at C:\Documents and Settings\Sys
>>>Admin\Application Data\AccessGrid\Config\personalDataStore using
>>>prefix personalDataStore and port 0 06/09/05 10:13:23 3008
>>>DataStore datastore.py:1500 DEBUG Creating thread 0 06/09/05
>>>10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting thread
>>>0 06/09/05 10:13:23 3088 DataStore datastore.py:1513 DEBUG
>>>Worker 0 starting 06/09/05 10:13:23 3008 DataStore
>>>datastore.py:1507 DEBUG Waiting thread 0 06/09/05 10:13:23 3008
>>>DataStore datastore.py:1510 DEBUG Done creating workers
>>>06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG Reading
>>>persisted data from: C:\Documents and Settings\Sys
>>>Admin\Application
>>>Data\AccessGrid\Config\personalDataStore\DataStore.dat 06/09/05
>>>10:13:23 3008 VenueClient venueclient.py:207 DEBUG
>>>__createPersonalDataStore: Load personal data from file 06/09/05
>>>10:13:23 3008 VenueClientController
>>>venueclientcontroller.py:1277 DEBUG There is no personal venues
>>>file to load. 06/09/05 10:13:27 3008 VenueClient
>>>venueclient.py:803 DEBUG EnterVenue;
>>>url=https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27
>>>3008 CertificateManager certificatemanager.py:907 DEBUG Looking
>>>for identity (unused) None 06/09/05 10:13:27 3008
>>>CertificateManager certificatemanager.py:638 DEBUG
>>>HaveValidProxy: found proxy ident /O=Access
>>>Gorczyca/CN=proxy 06/09/05 10:13:27 3008 CertificateManager
>>>certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident
>>>/O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne
>>>Gorczyca/CN=proxy 06/09/05 10:13:27 3008 VenueClient
>>>venueclient.py:830 INFO EnterVenue: Error getting node
>>>capabilities 06/09/05 10:13:27 3008 VenueClient
>>>venueclient.py:702 DEBUG EnterVenue: Invoke venue enter 06/09/05
>>>10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue:
>>>line 834, in EnterVenue self.__EnterVenue(URL)
>>>line 703, in __EnterVenue (venueState, self.privateId,
>>>self.streamDescList ) = self.__venueProxy.Enter( self.profile )
>>>File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
>>>3331, in Enter (r1, r2, r3) = self.proxy.Enter(profile)
>>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453,
>>>in __call__ return self.__r_call(*args, **kw)
>>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475,
>>>in __r_call self.__hd, self.__ma)
>>> File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338,
>>>in __call config = self.config, noroot = self.noroot)
>>> File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line
>>>620, in buildSOAP return t.build()
>>>118, in build body_ns = self.genns(ns_map, NS.ENV)[0]
>>>204, in genns if type(nsURI) == TupleType: # already a tuple
>>>06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG
>>>bin.VenueClient::EnterVenue: Enter venue with url:
>>>https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27 3008
>>>VenueClient venueclientui.py:1972 DEBUG warningString:
>>!DSPAM:42a86e2e21718345725203!
