[AG-TECH] Can not enter venue with Thinkpad T43
Anne Gorczyca
amg at haystack.mit.edu
Thu Jun 9 15:14:30 CDT 2005
Andrew,
After removing just PYTHONCASEOK as Tom reported, I also tried all of your suggestions. Again, the logfile is attached (I hope I remember this time) and a fresh copy of the environment variables. Machine has been rebooted each time.
I was aware that if I used the blue "Access IBM" button or other tools that the environment variables would be reset. However, I haven't found this to be the case so far. If I ever get the AccessGrid to work, I'll watch out for that problem.
Thanks.
ALLUSERSPROFILE=C:\Documents and Settings\All Users
APPDATA=C:\Documents and Settings\Sys Admin\Application Data
CommonProgramFiles=C:\Program Files\Common Files
COMPUTERNAME=IBMT43-AMG
ComSpec=C:\WINDOWS\system32\cmd.exe
FP_NO_HOST_CHECK=NO
GLOBUS_HOSTNAME=localhost
HOMEDIR=C:\Program Files\mbone
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\Sys Admin
IBMSHARE=C:\IBMSHARE
LOGONSERVER=\\IBMT43-AMG
NUMBER_OF_PROCESSORS=1
OS=Windows_NT
Path=C:\Python23;C:\Program Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Intel\Wireless\Bin\;C:\Program
Files\ATI Technologies\ATI Control Panel;C:\WINDOWS\Downloaded Program Files;C:\Program Files\PC-Doctor for Windows\services;C:\Program Files\SecureCRT\;C:\Program Files\Mbone
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.pyo;.pyc;.py;.pyw;.pys
PROCESSOR_ARCHITECTURE=x86
PROCESSOR_IDENTIFIER=x86 Family 6 Model 13 Stepping 8, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=0d08
PROMPT=$P$G
RRU=C:\Program Files\IBM\IBM Rapid Restore Ultra\
SESSIONNAME=Console
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
TMP=C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp
USERDOMAIN=IBMT43-AMG
USERNAME=Sys Admin
USERPROFILE=C:\Documents and Settings\Sys Admin
windir=C:\WINDOWS
On Thursday 09 June 2005 12:49 pm, Andrew Patrick wrote:
> When you say ...
> I've set PYTHONCASE to _unset_.
> What you should be doing is removing the environment variable
> PYTHONCASEOK. What is necessary is not setting it to the string
> "_unset_" but rather removing the variable completely.
> Specific steps to do this are
> - right-click on My Computer icon on the desktop
> - select Properties
> - select the Advanced tab
> - select the Environment Variables button
> - find the PYTHONCASEOK variable in the list of System Variables and
> delete it - close the Properties windows and reboot
> When I configure my Thinkpad for AG, I also edit the PATH to remove
> references to Python22 and add a reference to Python23. I also remove
> the PYTHONPATH, TCL_LIBRARY and TK_LIBRARY variables. These steps may
> not be necessary.
> I have also found that if you use any of the IBM utilities (such as
> system recovery and managing passwords) that rely on Python22, these
> variables can get set again.
> Anne Gorczyca wrote:
> > Hi everyone,
> > I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43
> > running XP w/ SP2. We've performed installations on several systems
> > using the same set of files. However, after obtaining a certificate
> > and trying to enter a venue, it lmost immediately pops up "Can not
> > connect to venue located at
> > https://vv2.mcs.anl.gov:9000/Venues/default. Please, try again."
> > We've consulted the archives and the buglist and found out that
> > there have been problems with the Thinkpads, but we've changed all
> > the environmental variables to point to python23 instead of the
> > python22 that comes preloaded from IBM. I've set GLOBUS_HOSTNAME to
> > localhost even though I'm just trying to use wired ethernet, not
> > WLAN. I've set PYTHONCASE to _unset_. What else can I try?
> > When the client is brought up in debug mode this is what's
> > displayed: C:\Python23\lib\fcntl.py:7: DeprecationWarning: the
> > FCTNL module is deprecated; please us fcntl
> > DeprecationWarning>
> > C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS
> > module is deprecated; please us termios
> > DeprecationWarning>
> > Attached is a portion of the VenueClient log showing one attempt
> > this morning to connect to a venue.
> > Thank you for any suggestions!
> > Anne
> > Anne M. Gorczyca
> > M.I.T. Haystack Observatory
> > Westford, MA 01886
> > Phone: 781-981-5630
> > FAX: 781-981-5766
> > 06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO
> > --------- END VenueClient 06/09/05 10:12:43 1040 DataStore
> > datastore.py:1577 DEBUG Quitting thread 0 06/09/05 10:12:43 3412
> > DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
> > 06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG Worker
> > 0 exiting 06/09/05 10:12:43 3416 DataStore datastore.py:1590
> > INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O
> > operation, most likely shutting down. 06/09/05 10:12:43 1040
> > NodeService agnodeservice.py:113 INFO NodeService.Stop
> > 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:84
> > INFO AGServiceManager.Shutdown 06/09/05 10:12:43 1040
> > ServiceManager agservicemanager.py:85 INFO Remove services
> > 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379
> > INFO AGServiceManager.RemoveServices 06/09/05 10:12:43 1040
> > ServiceManager agservicemanager.py:87 INFO Stop network
> > interface 06/09/05 10:12:43 3436 Hosting server.py:65 ERROR
> > Exception in SOAP server main loop Traceback (most recent call
> > last):
> > File
> > "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py"
> >, line 63, in Run self._server.handle_request()
> > File "C:\Python23\lib\SocketServer.py", line 217, in
> > handle_request request, client_address = self.get_request()
> > File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
> > 140, in get_request sock, addr =
> > ThreadingGSITCPSocketServer.get_request(self) File
> > "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> > get_request self.socket.listen()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
> > listen raise ex
> > GSITCPSocketException: an I/O operation was cancelled
> > 06/09/05 10:12:43 1040 Hosting server.py:97 ERROR
> > server_close() failed Traceback (most recent call last):
> > File
> >, line 95, in Stop self._server.server_close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043,
> > in server_close self.socket.close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020,
> > in close IOBase.close(self)
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
> > close raise ex
> > IOBaseException: an uninitialied data structure was passed as
> > argument 1 to globus_io_register_close 06/09/05 10:12:43 1040
> > Hosting server.py:97 ERROR server_close() failed Traceback
> > File
> > close raise ex
> > argument 1 to globus_io_register_close 06/09/05 10:13:23 3008
> > Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock:
> > Connection to sntp server at ntp-1.accessgrid.org failed Traceback
> > File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line
> > 176, in __CheckForInvalidClock serverTime = GetSNTPTime(timeserver,
> > timeout)
> > File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py",
> > line 43, in GetSNTPTime client.sendto( data, (server, 123 ))
> > gaierror: (7, 'getaddrinfo failed')
> > 06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using
> > GLOBUS_HOSTNAME=localhost as set in the environment 06/09/05
> > 10:13:23 3008 CertificateManager certificatemanager.py:257
> > DEBUG Opened repository C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\certRepo 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:395 DEBUG Got repo. 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:397 DEBUG looking in system ca dir:
> > C:\Program Files\AGTk-2.3\Config\CAcertificates 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
> > 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not
> > importing cert C:\Program
> > Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
> > Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
> > Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
> > Files\AGTk-2.3\Config\CAcertificates\f18fa857.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:410 DEBUG Init'ing globus. 06/09/05
> > 10:13:23 3008 CertificateManager certificatemanager.py:734
> > DEBUG Configuring standard environment 06/09/05 10:13:23 3008
> > CertificateManager certificatemanager.py:802 DEBUG Using
> > default identity /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> > 06/09/05 10:13:23 3008 CertificateManager
> > certificatemanager.py:873 DEBUG Initializing environment with proxy
> > cert for /O=Access
> > certificatemanager.py:907 DEBUG Looking for identity (unused) None
> > certificatemanager.py:892 DEBUG Configuring for user proxy issued
> > from /O=Access
> > certificatemanager.py:895 DEBUG Proxy
> > C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05
> > 16:10:02 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG
> > Done with globus. 06/09/05 10:13:23 3008 VenueClient
> > venueclient.py:284 DEBUG __StartWebService: venueclient:
> > https://localhost:11000/VenueClient 06/09/05 10:13:23 3008
> > ServiceManager agservicemanager.py:75 INFO Using services dir:
> > Data\AccessGrid\local_services 06/09/05 10:13:23 3008
> > ServiceManager agservicemanager.py:414 INFO
> > __DiscoverResources 06/09/05 10:13:23 3008 Toolkit
> > config.py:997 INFO Using vfwscan to get devices 06/09/05 10:13:23
> > 3008 Toolkit config.py:998 DEBUG vfwscanexe =
> > C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe 06/09/05 10:13:23 3008 Toolkit
> > config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture
> > (Win32)\n'] 06/09/05 10:13:23 3008 Toolkit config.py:1031 INFO
> > GetResources: ['Microsoft WDM Image Capture (Win32)'] 06/09/05
> > 10:13:23 3008 VenueClient venueclient.py:293 DEBUG
> > __StartWebService: service manager:
> > https://localhost:11000/ServiceManager 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:733 INFO
> > NodeService.__ReadConfigFile 06/09/05 10:13:23 3008 Toolkit
> > toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\AGNodeService.cfg 06/09/05
> > 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking for:
> > C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05
> > 10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT
> > NODE SERVICE CONFIG: C:\Program
> > Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:745 INFO Reading node service
> > config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> > 06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG
> > __StartWebService: node service:
> > https://localhost:11000/NodeService 06/09/05 10:13:23 3008
> > VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node
> > service url: https://localhost:11000/NodeService 06/09/05 10:13:23
> > 3008 NodeService agnodeservice.py:675 INFO
> > NodeService.GetDefaultConfiguration 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:558 INFO Migration unnecessary
> > 06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO
> > NodeService.LoadDefaultConfig 06/09/05 10:13:23 3008 NodeService
> > agnodeservice.py:355 INFO Loading default node configuration:
> > defaultWindows 06/09/05 10:13:23 3008 NodeService
> > agnodeservice.py:369 INFO NodeService.LoadConfiguration 06/09/05
> > 10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to
> > load node configuration from: C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
> > 06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO
> > AddServiceManager: Invalid service manager url
> > (https://localhost:11000/ServiceManager) 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:358 ERROR Exception loading
> > default configuration. Traceback (most recent call last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> > line 356, in LoadDefaultConfig self.LoadConfiguration(
> > self.defaultConfig )
> > line 500, in LoadConfiguration raise Exception(exceptionText)
> > Exception: Couldn't reach service manager: localhost:11000
> > 06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR
> > Error loading default configuration Traceback (most recent call
> > last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py",
> > line 308, in __StartWebService self.ns.LoadDefaultConfig()
> > line 359, in LoadDefaultConfig raise Exception("Failed to load
> > default configuration <%s>" % Exception: Failed to load default
> > configuration <defaultWindows> 06/09/05 10:13:23 3008 VenueClient
> > venueclient.py:182 DEBUG __createPersonalDataStore: Creating
> > personal datastore at C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\personalDataStore using
> > prefix personalDataStore and port 0 06/09/05 10:13:23 3008
> > DataStore datastore.py:1500 DEBUG Creating thread 0 06/09/05
> > 10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting thread
> > 0 06/09/05 10:13:23 3088 DataStore datastore.py:1513 DEBUG
> > Worker 0 starting 06/09/05 10:13:23 3008 DataStore
> > datastore.py:1507 DEBUG Waiting thread 0 06/09/05 10:13:23 3008
> > DataStore datastore.py:1510 DEBUG Done creating workers
> > 06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG Reading
> > persisted data from: C:\Documents and Settings\Sys
> > Admin\Application
> > Data\AccessGrid\Config\personalDataStore\DataStore.dat 06/09/05
> > 10:13:23 3008 VenueClient venueclient.py:207 DEBUG
> > __createPersonalDataStore: Load personal data from file 06/09/05
> > 10:13:23 3008 VenueClientController
> > venueclientcontroller.py:1277 DEBUG There is no personal venues
> > file to load. 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:803 DEBUG EnterVenue;
> > url=https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27
> > 3008 CertificateManager certificatemanager.py:907 DEBUG Looking
> > for identity (unused) None 06/09/05 10:13:27 3008
> > CertificateManager certificatemanager.py:638 DEBUG
> > HaveValidProxy: found proxy ident /O=Access
> > Gorczyca/CN=proxy 06/09/05 10:13:27 3008 CertificateManager
> > certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident
> > /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne
> > Gorczyca/CN=proxy 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:830 INFO EnterVenue: Error getting node
> > capabilities 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:702 DEBUG EnterVenue: Invoke venue enter 06/09/05
> > 10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue:
> > line 834, in EnterVenue self.__EnterVenue(URL)
> > line 703, in __EnterVenue (venueState, self.privateId,
> > self.streamDescList ) = self.__venueProxy.Enter( self.profile )
> > File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
> > 3331, in Enter (r1, r2, r3) = self.proxy.Enter(profile)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453,
> > in __call__ return self.__r_call(*args, **kw)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475,
> > in __r_call self.__hd, self.__ma)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338,
> > in __call config = self.config, noroot = self.noroot)
> > File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line
> > 620, in buildSOAP return t.build()
> > 118, in build body_ns = self.genns(ns_map, NS.ENV)[0]
> > 204, in genns if type(nsURI) == TupleType: # already a tuple
> > NameError: global name 'TupleType' is not defined
> > 06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG
> > bin.VenueClient::EnterVenue: Enter venue with url:
> > https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27 3008
> > VenueClient venueclientui.py:1972 DEBUG warningString:
06/09/05 16:02:24 2680 Toolkit config.py:196 DEBUG Using GLOBUS_HOSTNAME=localhost as set in the environment
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:257 DEBUG Opened repository C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\certRepo
06/09/05 16:02:24 2680 Toolkit toolkit.py:395 DEBUG Got repo.
06/09/05 16:02:24 2680 Toolkit toolkit.py:397 DEBUG looking in system ca dir: C:\Program Files\AGTk-2.3\Config\CAcertificates
06/09/05 16:02:24 2680 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:406 WARNING Not importing cert C:\Program Files\AGTk-2.3\Config\CAcertificates\f18fa857.0
06/09/05 16:02:24 2680 Toolkit toolkit.py:410 DEBUG Init'ing globus.
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:734 DEBUG Configuring standard environment
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:802 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:873 DEBUG Initializing environment with proxy cert for /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:892 DEBUG Configuring for user proxy issued from /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
06/09/05 16:02:24 2680 CertificateManager certificatemanager.py:895 DEBUG Proxy C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05 16:10:02
06/09/05 16:02:24 2680 Toolkit toolkit.py:414 DEBUG Done with globus.
06/09/05 16:02:25 2680 VenueClient venueclient.py:284 DEBUG __StartWebService: venueclient: https://localhost:11000/VenueClient
06/09/05 16:02:25 2680 ServiceManager agservicemanager.py:75 INFO Using services dir: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\local_services
06/09/05 16:02:25 2680 ServiceManager agservicemanager.py:414 INFO __DiscoverResources
06/09/05 16:02:25 2680 Toolkit config.py:997 INFO Using vfwscan to get devices
06/09/05 16:02:25 2680 Toolkit config.py:998 DEBUG vfwscanexe = C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe
06/09/05 16:02:25 2680 Toolkit config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture (Win32)\n']
06/09/05 16:02:25 2680 Toolkit config.py:1031 INFO GetResources: ['Microsoft WDM Image Capture (Win32)']
06/09/05 16:02:25 2680 VenueClient venueclient.py:293 DEBUG __StartWebService: service manager: https://localhost:11000/ServiceManager
06/09/05 16:02:25 2680 NodeService agnodeservice.py:733 INFO NodeService.__ReadConfigFile
06/09/05 16:02:25 2680 Toolkit toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\AGNodeService.cfg
06/09/05 16:02:25 2680 Toolkit toolkit.py:333 DEBUG Looking for: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 16:02:25 2680 NodeService agnodeservice.py:741 DEBUG DEFAULT NODE SERVICE CONFIG: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 16:02:25 2680 NodeService agnodeservice.py:745 INFO Reading node service config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
06/09/05 16:02:25 2680 VenueClient venueclient.py:299 DEBUG __StartWebService: node service: https://localhost:11000/NodeService
06/09/05 16:02:25 2680 VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node service url: https://localhost:11000/NodeService
06/09/05 16:02:25 2680 NodeService agnodeservice.py:675 INFO NodeService.GetDefaultConfiguration
06/09/05 16:02:25 2680 NodeService agnodeservice.py:558 INFO Migration unnecessary
06/09/05 16:02:25 2680 NodeService agnodeservice.py:351 INFO NodeService.LoadDefaultConfig
06/09/05 16:02:25 2680 NodeService agnodeservice.py:355 INFO Loading default node configuration: defaultWindows
06/09/05 16:02:25 2680 NodeService agnodeservice.py:369 INFO NodeService.LoadConfiguration
06/09/05 16:02:25 2680 NodeService agnodeservice.py:384 INFO Trying to load node configuration from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
06/09/05 16:02:25 2680 NodeService agnodeservice.py:457 INFO AddServiceManager: Invalid service manager url (https://localhost:11000/ServiceManager)
06/09/05 16:02:25 2680 NodeService agnodeservice.py:358 ERROR Exception loading default configuration.
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 356, in LoadDefaultConfig
self.LoadConfiguration( self.defaultConfig )
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 500, in LoadConfiguration
06/09/05 16:02:25 2680 VenueClient venueclient.py:310 ERROR Error loading default configuration
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 308, in __StartWebService
File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359, in LoadDefaultConfig
raise Exception("Failed to load default configuration <%s>" %
Exception: Failed to load default configuration <defaultWindows>
06/09/05 16:02:25 2680 VenueClient venueclient.py:182 DEBUG __createPersonalDataStore: Creating personal datastore at C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore using prefix personalDataStore and port 0
06/09/05 16:02:25 2680 DataStore datastore.py:1500 DEBUG Creating thread 0
06/09/05 16:02:25 2680 DataStore datastore.py:1505 DEBUG Starting thread 0
06/09/05 16:02:25 3744 DataStore datastore.py:1513 DEBUG Worker 0 starting
06/09/05 16:02:25 2680 DataStore datastore.py:1507 DEBUG Waiting thread 0
06/09/05 16:02:25 2680 DataStore datastore.py:1510 DEBUG Done creating workers
06/09/05 16:02:25 2680 DataStore datastore.py:263 DEBUG Reading persisted data from: C:\Documents and Settings\Sys Admin\Application Data\AccessGrid\Config\personalDataStore\DataStore.dat
06/09/05 16:02:25 2680 VenueClient venueclient.py:207 DEBUG __createPersonalDataStore: Load personal data from file
06/09/05 16:02:25 2680 VenueClientController venueclientcontroller.py:1277 DEBUG There is no personal venues file to load.
06/09/05 16:02:29 2680 VenueClient venueclient.py:803 DEBUG EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 16:02:29 2680 CertificateManager certificatemanager.py:907 DEBUG Looking for identity (unused) None
06/09/05 16:02:29 2680 CertificateManager certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca/CN=proxy
06/09/05 16:02:29 2680 VenueClient venueclient.py:830 INFO EnterVenue: Error getting node capabilities
06/09/05 16:02:29 2680 VenueClient venueclient.py:702 DEBUG EnterVenue: Invoke venue enter
06/09/05 16:02:29 2680 VenueClient venueclient.py:863 ERROR EnterVenue: failed
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 834, in EnterVenue
File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line 703, in __EnterVenue
(venueState, self.privateId, self.streamDescList ) = self.__venueProxy.Enter( self.profile )
File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line 3331, in Enter
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453, in __call__
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475, in __r_call
File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338, in __call
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 620, in buildSOAP
return t.build()
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 118, in build
File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line 204, in genns
06/09/05 16:02:29 2680 VenueClient venueclientui.py:1959 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://vv2.mcs.anl.gov:9000/Venues/default
06/09/05 16:02:29 2680 VenueClient venueclientui.py:1972 DEBUG warningString:
06/09/05 16:02:37 2680 VenueClient venueclientui.py:1599 INFO --------- END VenueClient
06/09/05 16:02:37 2680 DataStore datastore.py:1577 DEBUG Quitting thread 0
06/09/05 16:02:37 3744 DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
06/09/05 16:02:37 3744 DataStore datastore.py:1531 DEBUG Worker 0 exiting
06/09/05 16:02:37 3712 DataStore datastore.py:1590 INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O operation, most likely shutting down.
06/09/05 16:02:37 2680 NodeService agnodeservice.py:113 INFO NodeService.Stop
06/09/05 16:02:37 2680 ServiceManager agservicemanager.py:84 INFO AGServiceManager.Shutdown
06/09/05 16:02:37 2680 ServiceManager agservicemanager.py:85 INFO Remove services
06/09/05 16:02:37 2680 ServiceManager agservicemanager.py:379 INFO AGServiceManager.RemoveServices
06/09/05 16:02:37 2680 ServiceManager agservicemanager.py:87 INFO Stop network interface
06/09/05 16:02:37 3916 Hosting server.py:65 ERROR Exception in SOAP server main loop
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 63, in Run
File "C:\Python23\lib\SocketServer.py", line 217, in handle_request
File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line 140, in get_request
sock, addr = ThreadingGSITCPSocketServer.get_request(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in get_request
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in listen
raise ex
06/09/05 16:02:37 2680 Hosting server.py:97 ERROR server_close() failed
File "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py", line 95, in Stop
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043, in server_close
self.socket.close()
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020, in close
IOBase.close(self)
File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in close
raise ex
IOBaseException: an uninitialied data structure was passed as argument 1 to globus_io_register_close
self.socket.close()
IOBase.close(self)
raise ex
