[AG-TECH] Can not enter venue with Thinkpad T43
Anne Gorczyca
amg at haystack.mit.edu
Thu Jun 9 11:36:14 CDT 2005
Tom,
Thanks, but I've just removed PYTHONCASEOK entirely as an environment
variable and restarted the machine. Problem still exists.
Anne
On Thursday 09 June 2005 12:28 pm, Thomas D. Uram wrote:
> I talked with Anne today in the test meeting, but wanted to respond
> for the benefit of any one on the list who is installing on a newer
> Thinkpad.
> The telltale sign of this problem is this exception:
> NameError: global name 'TupleType' is not defined
> The problem arises due to environment variable settings added by IBM.
> The offending variable is PYTHONCASEOK. To fix the problem, delete
> this environment variable from the list (if it is set to any value
> whatsoever, the problem will remain). (It's in bugzilla also:
> http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208)
> Tom
> On 06/09/05 10:11, Anne Gorczyca wrote:
> > Hi everyone,
> > I'm having problems using AG Toolkit 2.3 on a new Thinkpad T43
> > running XP w/ SP2. We've performed installations on several systems
> > using the same set of files. However, after obtaining a certificate
> > and trying to enter a venue, it lmost immediately pops up "Can not
> > connect to venue located at
> > https://vv2.mcs.anl.gov:9000/Venues/default. Please, try again."
> > We've consulted the archives and the buglist and found out that
> > there have been problems with the Thinkpads, but we've changed all
> > the environmental variables to point to python23 instead of the
> > python22 that comes preloaded from IBM. I've set GLOBUS_HOSTNAME to
> > localhost even though I'm just trying to use wired ethernet, not
> > WLAN. I've set PYTHONCASE to _unset_. What else can I try?
> > When the client is brought up in debug mode this is what's
> > displayed: C:\Python23\lib\fcntl.py:7: DeprecationWarning: the
> > FCTNL module is deprecated; please us fcntl
> > DeprecationWarning>
> > C:\Python23\lib\termios.py:7: DeprecationWarning: the TERMIOS
> > module is deprecated; please us termios
> > DeprecationWarning>
> > Attached is a portion of the VenueClient log showing one attempt
> > this morning to connect to a venue.
> > Thank you for any suggestions!
> > Anne
> > Anne M. Gorczyca
> > M.I.T. Haystack Observatory
> > Westford, MA 01886
> > Phone: 781-981-5630
> > FAX: 781-981-5766
> > 06/09/05 10:12:43 1040 VenueClient venueclientui.py:1599 INFO
> > --------- END VenueClient 06/09/05 10:12:43 1040 DataStore
> > datastore.py:1577 DEBUG Quitting thread 0 06/09/05 10:12:43 3412
> > DataStore datastore.py:1518 DEBUG Worker 0 gets cmd quit
> > 06/09/05 10:12:43 3412 DataStore datastore.py:1531 DEBUG Worker
> > 0 exiting 06/09/05 10:12:43 3416 DataStore datastore.py:1590
> > INFO GSIHTTPTransferServer: GSITCPSocket, interrupted I/O
> > operation, most likely shutting down. 06/09/05 10:12:43 1040
> > NodeService agnodeservice.py:113 INFO NodeService.Stop
> > 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:84
> > INFO AGServiceManager.Shutdown 06/09/05 10:12:43 1040
> > ServiceManager agservicemanager.py:85 INFO Remove services
> > 06/09/05 10:12:43 1040 ServiceManager agservicemanager.py:379
> > INFO AGServiceManager.RemoveServices 06/09/05 10:12:43 1040
> > ServiceManager agservicemanager.py:87 INFO Stop network
> > interface 06/09/05 10:12:43 3436 Hosting server.py:65 ERROR
> > Exception in SOAP server main loop Traceback (most recent call
> > last):
> > File
> > "C:\Python23\Lib\site-packages\AccessGrid\hosting\SOAPpy\Server.py"
> >, line 63, in Run self._server.handle_request()
> > File "C:\Python23\lib\SocketServer.py", line 217, in
> > handle_request request, client_address = self.get_request()
> > File "C:\Python23\Lib\site-packages\SOAPpy\GSIServer.py", line
> > 140, in get_request sock, addr =
> > ThreadingGSITCPSocketServer.get_request(self) File
> > "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 525, in
> > get_request self.socket.listen()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 857, in
> > listen raise ex
> > GSITCPSocketException: an I/O operation was cancelled
> > 06/09/05 10:12:43 1040 Hosting server.py:97 ERROR
> > server_close() failed Traceback (most recent call last):
> > File
> >, line 95, in Stop self._server.server_close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1043,
> > in server_close self.socket.close()
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 1020,
> > in close IOBase.close(self)
> > File "C:\Python23\Lib\site-packages\pyGlobus\io.py", line 176, in
> > close raise ex
> > IOBaseException: an uninitialied data structure was passed as
> > argument 1 to globus_io_register_close 06/09/05 10:12:43 1040
> > Hosting server.py:97 ERROR server_close() failed Traceback
> > File
> > close raise ex
> > argument 1 to globus_io_register_close 06/09/05 10:13:23 3008
> > Toolkit toolkit.py:178 ERROR Toolkit.__CheckForValidClock:
> > Connection to sntp server at ntp-1.accessgrid.org failed Traceback
> > File "C:\Python23\Lib\site-packages\AccessGrid\Toolkit.py", line
> > 176, in __CheckForInvalidClock serverTime = GetSNTPTime(timeserver,
> > timeout)
> > File "C:\Python23\Lib\site-packages\AccessGrid\NetUtilities.py",
> > line 43, in GetSNTPTime client.sendto( data, (server, 123 ))
> > gaierror: (7, 'getaddrinfo failed')
> > 06/09/05 10:13:23 3008 Toolkit config.py:196 DEBUG Using
> > GLOBUS_HOSTNAME=localhost as set in the environment 06/09/05
> > 10:13:23 3008 CertificateManager certificatemanager.py:257
> > DEBUG Opened repository C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\certRepo 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:395 DEBUG Got repo. 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:397 DEBUG looking in system ca dir:
> > C:\Program Files\AGTk-2.3\Config\CAcertificates 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 1c3f2ca8.0
> > 06/09/05 10:13:23 3008 Toolkit toolkit.py:406 WARNING Not
> > importing cert C:\Program
> > Files\AGTk-2.3\Config\CAcertificates\1c3f2ca8.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: 45cc9e80.0
> > Files\AGTk-2.3\Config\CAcertificates\45cc9e80.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: d1b603c3.0
> > Files\AGTk-2.3\Config\CAcertificates\d1b603c3.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:401 DEBUG Getting cert: f18fa857.0
> > Files\AGTk-2.3\Config\CAcertificates\f18fa857.0 06/09/05 10:13:23
> > 3008 Toolkit toolkit.py:410 DEBUG Init'ing globus. 06/09/05
> > 10:13:23 3008 CertificateManager certificatemanager.py:734
> > DEBUG Configuring standard environment 06/09/05 10:13:23 3008
> > CertificateManager certificatemanager.py:802 DEBUG Using
> > default identity /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne Gorczyca
> > 06/09/05 10:13:23 3008 CertificateManager
> > certificatemanager.py:873 DEBUG Initializing environment with proxy
> > cert for /O=Access
> > certificatemanager.py:907 DEBUG Looking for identity (unused) None
> > certificatemanager.py:892 DEBUG Configuring for user proxy issued
> > from /O=Access
> > certificatemanager.py:895 DEBUG Proxy
> > C:\DOCUME~1\SYSADM~1\LOCALS~1\Temp\proxy will expire 06/09/05
> > 16:10:02 06/09/05 10:13:23 3008 Toolkit toolkit.py:414 DEBUG
> > Done with globus. 06/09/05 10:13:23 3008 VenueClient
> > venueclient.py:284 DEBUG __StartWebService: venueclient:
> > https://localhost:11000/VenueClient 06/09/05 10:13:23 3008
> > ServiceManager agservicemanager.py:75 INFO Using services dir:
> > C:\Documents and Settings\Sys Admin\Application
> > Data\AccessGrid\local_services 06/09/05 10:13:23 3008
> > ServiceManager agservicemanager.py:414 INFO
> > __DiscoverResources 06/09/05 10:13:23 3008 Toolkit
> > config.py:997 INFO Using vfwscan to get devices 06/09/05 10:13:23
> > 3008 Toolkit config.py:998 DEBUG vfwscanexe =
> > C:\PROGRA~1\AGTk-2.3\bin\vfwscan.exe 06/09/05 10:13:23 3008 Toolkit
> > config.py:1003 DEBUG filelines = ['Microsoft WDM Image Capture
> > (Win32)\n'] 06/09/05 10:13:23 3008 Toolkit config.py:1031 INFO
> > GetResources: ['Microsoft WDM Image Capture (Win32)'] 06/09/05
> > 10:13:23 3008 VenueClient venueclient.py:293 DEBUG
> > __StartWebService: service manager:
> > https://localhost:11000/ServiceManager 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:733 INFO
> > NodeService.__ReadConfigFile 06/09/05 10:13:23 3008 Toolkit
> > toolkit.py:328 DEBUG Looking for: C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\AGNodeService.cfg 06/09/05
> > 10:13:23 3008 Toolkit toolkit.py:333 DEBUG Looking for:
> > C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05
> > 10:13:23 3008 NodeService agnodeservice.py:741 DEBUG DEFAULT
> > NODE SERVICE CONFIG: C:\Program
> > Files\AGTk-2.3\Config\AGNodeService.cfg 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:745 INFO Reading node service
> > config file: C:\Program Files\AGTk-2.3\Config\AGNodeService.cfg
> > 06/09/05 10:13:23 3008 VenueClient venueclient.py:299 DEBUG
> > __StartWebService: node service:
> > https://localhost:11000/NodeService 06/09/05 10:13:23 3008
> > VenueClient venueclient.py:1317 DEBUG SerNodeUrl: Set node
> > service url: https://localhost:11000/NodeService 06/09/05 10:13:23
> > 3008 NodeService agnodeservice.py:675 INFO
> > NodeService.GetDefaultConfiguration 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:558 INFO Migration unnecessary
> > 06/09/05 10:13:23 3008 NodeService agnodeservice.py:351 INFO
> > NodeService.LoadDefaultConfig 06/09/05 10:13:23 3008 NodeService
> > agnodeservice.py:355 INFO Loading default node configuration:
> > defaultWindows 06/09/05 10:13:23 3008 NodeService
> > agnodeservice.py:369 INFO NodeService.LoadConfiguration 06/09/05
> > 10:13:23 3008 NodeService agnodeservice.py:384 INFO Trying to
> > load node configuration from: C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\nodeConfig\defaultWindows
> > 06/09/05 10:13:23 3008 NodeService agnodeservice.py:457 INFO
> > AddServiceManager: Invalid service manager url
> > (https://localhost:11000/ServiceManager) 06/09/05 10:13:23 3008
> > NodeService agnodeservice.py:358 ERROR Exception loading
> > default configuration. Traceback (most recent call last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py",
> > line 356, in LoadDefaultConfig self.LoadConfiguration(
> > self.defaultConfig )
> > line 500, in LoadConfiguration raise Exception(exceptionText)
> > Exception: Couldn't reach service manager: localhost:11000
> > 06/09/05 10:13:23 3008 VenueClient venueclient.py:310 ERROR
> > Error loading default configuration Traceback (most recent call
> > last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py",
> > line 308, in __StartWebService self.ns.LoadDefaultConfig()
> > line 359, in LoadDefaultConfig raise Exception("Failed to load
> > default configuration <%s>" % Exception: Failed to load default
> > configuration <defaultWindows> 06/09/05 10:13:23 3008 VenueClient
> > venueclient.py:182 DEBUG __createPersonalDataStore: Creating
> > personal datastore at C:\Documents and Settings\Sys
> > Admin\Application Data\AccessGrid\Config\personalDataStore using
> > prefix personalDataStore and port 0 06/09/05 10:13:23 3008
> > DataStore datastore.py:1500 DEBUG Creating thread 0 06/09/05
> > 10:13:23 3008 DataStore datastore.py:1505 DEBUG Starting thread
> > 0 06/09/05 10:13:23 3088 DataStore datastore.py:1513 DEBUG
> > Worker 0 starting 06/09/05 10:13:23 3008 DataStore
> > datastore.py:1507 DEBUG Waiting thread 0 06/09/05 10:13:23 3008
> > DataStore datastore.py:1510 DEBUG Done creating workers
> > 06/09/05 10:13:23 3008 DataStore datastore.py:263 DEBUG Reading
> > persisted data from: C:\Documents and Settings\Sys
> > Admin\Application
> > Data\AccessGrid\Config\personalDataStore\DataStore.dat 06/09/05
> > 10:13:23 3008 VenueClient venueclient.py:207 DEBUG
> > __createPersonalDataStore: Load personal data from file 06/09/05
> > 10:13:23 3008 VenueClientController
> > venueclientcontroller.py:1277 DEBUG There is no personal venues
> > file to load. 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:803 DEBUG EnterVenue;
> > url=https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27
> > 3008 CertificateManager certificatemanager.py:907 DEBUG Looking
> > for identity (unused) None 06/09/05 10:13:27 3008
> > CertificateManager certificatemanager.py:638 DEBUG
> > HaveValidProxy: found proxy ident /O=Access
> > Gorczyca/CN=proxy 06/09/05 10:13:27 3008 CertificateManager
> > certificatemanager.py:638 DEBUG HaveValidProxy: found proxy ident
> > /O=Access Grid/OU=agdev-ca.mcs.anl.gov/OU=haystack.mit.edu/CN=Anne
> > Gorczyca/CN=proxy 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:830 INFO EnterVenue: Error getting node
> > capabilities 06/09/05 10:13:27 3008 VenueClient
> > venueclient.py:702 DEBUG EnterVenue: Invoke venue enter 06/09/05
> > 10:13:27 3008 VenueClient venueclient.py:863 ERROR EnterVenue:
> > line 834, in EnterVenue self.__EnterVenue(URL)
> > line 703, in __EnterVenue (venueState, self.privateId,
> > self.streamDescList ) = self.__venueProxy.Enter( self.profile )
> > File "C:\Python23\Lib\site-packages\AccessGrid\Venue.py", line
> > 3331, in Enter (r1, r2, r3) = self.proxy.Enter(profile)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 453,
> > in __call__ return self.__r_call(*args, **kw)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 475,
> > in __r_call self.__hd, self.__ma)
> > File "C:\Python23\Lib\site-packages\SOAPpy\Client.py", line 338,
> > in __call config = self.config, noroot = self.noroot)
> > File "C:\Python23\Lib\site-packages\SOAPpy\SOAPBuilder.py", line
> > 620, in buildSOAP return t.build()
> > 118, in build body_ns = self.genns(ns_map, NS.ENV)[0]
> > 204, in genns if type(nsURI) == TupleType: # already a tuple
> > 06/09/05 10:13:27 3008 VenueClient venueclientui.py:1959 DEBUG
> > bin.VenueClient::EnterVenue: Enter venue with url:
> > https://vv2.mcs.anl.gov:9000/Venues/default 06/09/05 10:13:27 3008
> > VenueClient venueclientui.py:1972 DEBUG warningString:
> !DSPAM:42a86e2e21718345725203!
