[AG-TECH] BridgeServer not bridging?
Thomas D. Uram
turam at mcs.anl.gov
Wed Jan 19 17:37:32 CST 2005
The only additional access required is VenueServer.GetVenues.
Tom
Todd Zimmerman wrote:
> Not sure if this is your issue - but I've just run into something very
> similar - it was caused by our bridgeserver certificate not being
> authorized to connect to the venueserver (two different machines - two
> different certificates).
> I added the bridgeserver DN to the venueserver administrators list and
> it worked after that.
> Giving administrator access is a bit extreme, obviously - and I'd like
> to narrow the scope of authorization; however, I wasn't sure which
> 'Actions' the bridgeserver was required to be authorized for. Any
> advice from other admins would be great!
> Todd
> Collaboration & Visualization Technician
> WestGrid - www.westgrid.ca
> IRMACS - www.irmacs.com
> Ph. 604.268.6979
> Todd Zimmerman - toddz at sfu.ca
> Socrates wrote:
>> Hi,
>> I'm trying to run a bridge on my local server but it doesn't seem to
>> work.
>> I start the BridgeServer.py script with a config file containing the
>> URI of the server (want all Venues bridged). I start the Client on
>> another machine but the "unicast" option in the menu is still grayed
>> out.
>> WiKi says that the Lucky Labrador Venue is bridged by Argonne:
>> http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/BridgedVenues
>> Starting my Client on that room doesn't enable "unicast" on the menu
>> either.
>> Any ideas? This is all Fedora Core 3. No errors reported in
>> BridgeServer.log, VenueServer.log or VenueClient.log.
>> Thanks,
