[AG-TECH] BridgeServer not bridging?
Todd Zimmerman
toddz at sfu.ca
Wed Jan 19 15:00:55 CST 2005
Not sure if this is your issue - but I've just run into something very
similar - it was caused by our bridgeserver certificate not being
authorized to connect to the venueserver (two different machines - two
different certificates).
I added the bridgeserver DN to the venueserver administrators list and
it worked after that.
Giving administrator access is a bit extreme, obviously - and I'd like
to narrow the scope of authorization; however, I wasn't sure which
'Actions' the bridgeserver was required to be authorized for. Any
advice from other admins would be great!
Todd
Collaboration & Visualization Technician
WestGrid - www.westgrid.ca
IRMACS - www.irmacs.com
Ph. 604.268.6979
Todd Zimmerman - toddz at sfu.ca
Socrates wrote:
> Hi,
> I'm trying to run a bridge on my local server but it doesn't seem to work.
> I start the BridgeServer.py script with a config file containing the
> URI of the server (want all Venues bridged). I start the Client on
> another machine but the "unicast" option in the menu is still grayed
> out.
> WiKi says that the Lucky Labrador Venue is bridged by Argonne:
> ( http://www-unix.mcs.anl.gov/fl/research/accessgrid/wiki/moin.cgi/BridgedVenues
> Starting my Client on that room doesn't enable "unicast" on the menu either.
> Any ideas? This is all Fedora Core 3. No errors reported in
> BridgeServer.log, VenueServer.log or VenueClient.log.
> Thanks,
