[AG-TECH] shared apps not opening
Susanne Lefvert
lefvert at mcs.anl.gov
Wed Jan 19 12:54:27 CST 2005
Hello Shawn,
In some cases, files left from and older AG installation causes this
problem. Please try following:
* Rename C:\Documents and Settings\Username\Application
Data\AccessGrid\ApplicationDatabase
Data\AccessGrid\Config\ApplicationDatabase
Data\AccessGrid\SharedApplications
Then restart the client and see if that works better.
Hope this helps,
Susanne
On Tue, 18 Jan 2005, Shawn Needham wrote:
> I'm running into a problem when trying to open a Shared Browser or
> Presentation with the latest installation of the AG Toolkit. I'm running
> Windows XP Pro Version 2002.
> I am able to add the select and add the application, but when I attempt to
> open/launch the application no dialog appears. In the past I used to get
> the dialog where you could insert your url, but that is not starting on
> my current installation. I tried uinstalling & reinstalling python,
> wxPython and the AG Toolkit and ran into the same problem.
> For wxPython, I had to download a different version than the wxPython from
> the AG software site as that version (wxPythonWIN32-2.5.1.5-Py23.exe)
> produced the following error:
> 16 bit MS-DOS Subsytm; The NTVDM CPU has encountered an illegal instruction.
> I grabbed the closest version I could find on wxPython.org
> (2.5.2.8u-Py23). and audio/video services are working for the AG, but I'm
> not able to utilize the shared apps.
> Does anyone have any suggestions?
> Thanks,
> Shawn
