[AG-TECH] shared apps not opening
Shawn Needham
shawn at flash.uchicago.edu
Wed Jan 19 13:34:19 CST 2005
Thanks Susan,
Renaming those file/folders associated with my older installations did
take care of the problem. Both my shared browser and shared presentation
are working again.
Thanks again,
Shawn
On Wed, 19 Jan 2005, Susanne Lefvert wrote:
> Hello Shawn,
> In some cases, files left from and older AG installation causes this
> problem. Please try following:
> * Rename C:\Documents and Settings\Username\Application
> Data\AccessGrid\ApplicationDatabase
> Data\AccessGrid\Config\ApplicationDatabase
> Data\AccessGrid\SharedApplications
> Then restart the client and see if that works better.
> Hope this helps,
> Susanne
> On Tue, 18 Jan 2005, Shawn Needham wrote:
> > I'm running into a problem when trying to open a Shared Browser or
> > Presentation with the latest installation of the AG Toolkit. I'm running
> > Windows XP Pro Version 2002.
> > I am able to add the select and add the application, but when I attempt to
> > open/launch the application no dialog appears. In the past I used to get
> > the dialog where you could insert your url, but that is not starting on
> > my current installation. I tried uinstalling & reinstalling python,
> > wxPython and the AG Toolkit and ran into the same problem.
> > For wxPython, I had to download a different version than the wxPython from
> > the AG software site as that version (wxPythonWIN32-2.5.1.5-Py23.exe)
> > produced the following error:
> > 16 bit MS-DOS Subsytm; The NTVDM CPU has encountered an illegal instruction.
> > I grabbed the closest version I could find on wxPython.org
> > (2.5.2.8u-Py23). and audio/video services are working for the AG, but I'm
> > not able to utilize the shared apps.
> > Does anyone have any suggestions?
> > Thanks,
> > Shawn
