[AG-TECH] VRVS via AG
Kun Wei
weikun at caltech.edu
Fri Jan 7 11:11:44 CST 2005
Hi, Andrew;
VRVS AG Gateway is developed by VRVS to act as a bridge between AG
multicast/any multicast and unicast network. It runs on a fair Linux
box(not high demand on hardware, but the more powerful,l, the better:)
Please send contact at vrvs.org to request hosting a VRVS AG Gateway. The
cost is low, you need provide the server, provide local support, make
sure it is on 24x7.
Thanks
Kun
Andrew Rowley wrote:
> Hi,
> Is there any way that we could run our own VRVS-AG bridge? i.e is this just
> a software server or is there some hardware here too and is the software
> free?
> Andrew :)
> Access Grid Support Centre,
> RSS Group,
> Manchester Computing,
> Kilburn Building,
> University of Manchester,
> Oxford Road,
> Manchester,
> M13 9PL,
> UK
> Tel: +44(0)161-275 0685
> Email: Andrew.Rowley at manchester.ac.uk
> -----Original Message-----
> From: Bob Riddle [mailto:bdr at internet2.edu]
> Sent: 06 January 2005 13:03
> To: Andrew Rowley
> Cc: 'Jeffrey Bary'; ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] VRVS via AG
> all you need to do is tell support at vrvs.org which room(s) you would like
> to be bridged. For example, all of the "rooms" in the Internet2
> "Community" are bridged and you are welcome to make use of these - juts
> remember to send me a note!
>>Hi,
>>I don't think that this is a VRVS-Access Grid room. To see the list of
> VRVS
>>rooms that can be used with Access Grid, go to http://www.vrvs.org/ and
>>login, then click on "Enter" on the left menu bar and select the
>>"VAccessGrid" in the top right hand corner (quite small, above options).
>>This lists the Virtual Venues that can be used for Access Grid - VRVS
>>interaction.
>>I am guessing that there might be a way to add to this list of venues. I
>>would be interested in knowing how this might be done...
>>Andrew :)
>>RSS Group,
>>Kilburn Building,
>>Oxford Road,
>>Manchester,
>>M13 9PL,
>>UK
>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf
>>Of Jeffrey Bary
>>Sent: 05 January 2005 22:20
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] VRVS via AG
>>Can I get to a VRVS venue via the AG ? In particular the Fog Room.
>>It has a couple of H.323 sources. Will that work ?
>>-Jeff
