[AG-TECH] VRVS via AG
    Andrew Rowley
    Andrew.Rowley at manchester.ac.uk
    Fri Jan  7 03:54:21 CST 2005
Is there any way that we could run our own VRVS-AG bridge? i.e is this just
a software server or is there some hardware here too and is the software
free?
Andrew :)
Access Grid Support Centre,
RSS Group,
Manchester Computing,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
-----Original Message-----
Sent: 06 January 2005 13:03
To: Andrew Rowley
Cc: 'Jeffrey Bary'; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] VRVS via AG
all you need to do is tell support at vrvs.org which room(s) you would like
to be bridged.  For example, all of the "rooms" in the Internet2
"Community" are bridged and you are welcome to make use of these - juts
remember to send me a note!
Andrew Rowley wrote:
>Hi,
>I don't think that this is a VRVS-Access Grid room.  To see the list of
VRVS
>rooms that can be used with Access Grid, go to http://www.vrvs.org/ and
>login, then click on "Enter" on the left menu bar and select the
>"VAccessGrid" in the top right hand corner (quite small, above options).
>This lists the Virtual Venues that can be used for Access Grid - VRVS
>interaction.
>I am guessing that there might be a way to add to this list of venues.  I
>would be interested in knowing how this might be done...
>Andrew :)
>RSS Group,
>Kilburn Building,
>Oxford Road,
>Manchester,
>M13 9PL,
>UK
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf
>Of Jeffrey Bary
>Sent: 05 January 2005 22:20
>To: ag-tech at mcs.anl.gov
>Subject: [AG-TECH] VRVS via AG
>Can I get to a VRVS venue via the AG ? In particular the Fog Room.
>It has a couple of H.323 sources. Will that work ?
>-Jeff
Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
1000 Oakbrook Drive, Suite 300    Ann Arbor, Michigan  48104
Business Phone: 734.913.4257      Fax Number:  734.913.4255
"Math illiteracy affects 7 out of every 5 people"
