[AG-TECH] VRVS via AG
    Bob Riddle
    bdr at internet2.edu
    Thu Jan  6 07:02:58 CST 2005
all you need to do is tell support at vrvs.org which room(s) you would like
to be bridged.  For example, all of the "rooms" in the Internet2
"Community" are bridged and you are welcome to make use of these - juts
remember to send me a note!
Andrew Rowley wrote:
>Hi,
>I don't think that this is a VRVS-Access Grid room.  To see the list of VRVS
>rooms that can be used with Access Grid, go to http://www.vrvs.org/ and
>login, then click on "Enter" on the left menu bar and select the
>"VAccessGrid" in the top right hand corner (quite small, above options).
>This lists the Virtual Venues that can be used for Access Grid - VRVS
>interaction.
>I am guessing that there might be a way to add to this list of venues.  I
>would be interested in knowing how this might be done...
>Andrew :)
>Access Grid Support Centre,
>RSS Group,
>Manchester Computing,
>Kilburn Building,
>University of Manchester,
>Oxford Road,
>Manchester,
>M13 9PL,
>UK
>Tel: +44(0)161-275 0685
>Email: Andrew.Rowley at manchester.ac.uk
>-----Original Message-----
>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
>Of Jeffrey Bary
>Sent: 05 January 2005 22:20
>To: ag-tech at mcs.anl.gov
>Subject: [AG-TECH] VRVS via AG
>Can I get to a VRVS venue via the AG ? In particular the Fog Room.
>It has a couple of H.323 sources. Will that work ?
>-Jeff
Bob Riddle (bdr at internet2.edu)    Technologist,Internet2
1000 Oakbrook Drive, Suite 300    Ann Arbor, Michigan  48104
Business Phone: 734.913.4257      Fax Number:  734.913.4255
"Math illiteracy affects 7 out of every 5 people"
