[AG-TECH] Problems configuring a laptop client.
Thomas D. Uram
turam at mcs.anl.gov
Fri Feb 25 15:15:50 CST 2005
Hi Brian:
Is there any more indication of the problem in the VenueClient.log file? You'll find it
in C:\Documents and Settings\<you>\Application Data\AccessGrid\Logs. If you don't see any
clear problem there, you can send the file to me and I'll take a look.
It looks to me like some state didn't get cleaned off from the previous installation. You
might want to try an uninstall, ensure that the AccessGrid directory is gone from
C:\Python23\lib\site-packages, and install again. This is not normally necessary, but
might be in this case, depending on how you reached the current state.
Tom
Brian Tieman wrote:
> Hi all!
> I'm tring to set up a VenueClient on my laptop. I've installed python,
> wxpython and the AGTK2.3--exactly as I have on several other machines.
> The problem is that on the laptop when I run the venueClient, it takes
> forever to start. It will eventually start--and I can connect to venues
> and do most things. The problem is that I can't open up the "Manage my
> node" tool and configure my node--I can't connect to the node manager..
> I used to have AGTK2.1 installed on this machine, but I never had it set
> up for any AV. I believe I've uninstalled everything properly and
> scoured any remaining files from my machine. After installing the
> AGTK2.3 and running the debug venueClient, I get the errors below.
> Any advice on what to do would be greatly appreciated!
> Thank You!
> Brian
> *** Method ServiceManager:AddServicePackage exception ******************
> Traceback (most recent call last):
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOAP
> py\Server.py", line 407, in do_POST
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acce
> ssGrid\AGServiceManager.py", line 484, in AddServicePackage
> File
> ssGrid\AGServiceManager.py", line 109, in AddServicePackage
> server.RegisterObject(nsi, path="/NodeService")
> File
> ssGrid\AGServiceManager.py", line 269, in AddService
> Exception: Error starting service
> <Fault SOAP-ENV:Server: Method Failed: ServiceManager:AddServicePackage>
> File
> File
> File
> File
