[AG-TECH] Problems configuring a laptop client.
Eric Olson
eolson at mcs.anl.gov
Fri Feb 25 15:21:43 CST 2005
Hi Brian,
It sounds like unsetting the windows environment variable GLOBUS_HOSTNAME
could help.
Here's a previous discussion of this:
http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2004/06/msg00022.html
If that doesn't fix everything, there is the possibility that you have an
old node configuration causing problems. We should be able to
tell from looking at your logs.
Eric
On Fri, 25 Feb 2005, Brian Tieman wrote:
> Hi all!
> I'm tring to set up a VenueClient on my laptop. I've installed python,
> wxpython and the AGTK2.3--exactly as I have on several other machines.
> The problem is that on the laptop when I run the venueClient, it takes
> forever to start. It will eventually start--and I can connect to venues
> and do most things. The problem is that I can't open up the "Manage my
> node" tool and configure my node--I can't connect to the node manager..
> I used to have AGTK2.1 installed on this machine, but I never had it set
> up for any AV. I believe I've uninstalled everything properly and
> scoured any remaining files from my machine. After installing the
> AGTK2.3 and running the debug venueClient, I get the errors below.
> Any advice on what to do would be greatly appreciated!
> Thank You!
> Brian
> *** Method ServiceManager:AddServicePackage exception ******************
> Traceback (most recent call last):
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOAP
> py\Server.py", line 407, in do_POST
> File
> "C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acce
> ssGrid\AGServiceManager.py", line 484, in AddServicePackage
> File
> ssGrid\AGServiceManager.py", line 109, in AddServicePackage
> server.RegisterObject(nsi, path="/NodeService")
> File
> ssGrid\AGServiceManager.py", line 269, in AddService
> Exception: Error starting service
> <Fault SOAP-ENV:Server: Method Failed: ServiceManager:AddServicePackage>
> File
> File
> File
> File
