[AG-TECH] Problems configuring a laptop client.
Brian Tieman
tieman at aps.anl.gov
Fri Feb 25 14:29:46 CST 2005
Hi all!
I'm tring to set up a VenueClient on my laptop. I've installed python,
wxpython and the AGTK2.3--exactly as I have on several other machines.
The problem is that on the laptop when I run the venueClient, it takes
forever to start. It will eventually start--and I can connect to venues
and do most things. The problem is that I can't open up the "Manage my
node" tool and configure my node--I can't connect to the node manager..
I used to have AGTK2.1 installed on this machine, but I never had it set
up for any AV. I believe I've uninstalled everything properly and
scoured any remaining files from my machine. After installing the
AGTK2.3 and running the debug venueClient, I get the errors below.
Any advice on what to do would be greatly appreciated!
Thank You!
Brian
*** Method ServiceManager:AddServicePackage exception ******************
Traceback (most recent call last):
File
"C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\SOAP
py\Server.py", line 407, in do_POST
File
"C:\software\AccessGrid\build\dist-20040910_210059\Lib\site-packages\Acce
ssGrid\AGServiceManager.py", line 484, in AddServicePackage
File
ssGrid\AGServiceManager.py", line 109, in AddServicePackage
server.RegisterObject(nsi, path="/NodeService")
File
ssGrid\AGServiceManager.py", line 269, in AddService
Exception: Error starting service
<Fault SOAP-ENV:Server: Method Failed: ServiceManager:AddServicePackage>
File
File
File
File
