[AG-TECH] Video freezing on the iSight
    Jason Bell
    j.bell at cqu.edu.au
    Tue Feb 22 20:35:57 CST 2005
G'day Paul
Thanks for your feedback.
Basically when my video freezes, it does so on the other machines in the
same venues as well.
The only thing they I can se that might be affecting it is that I am
running this on a low-end iMac and at times it is running at 0%
idle.....
Other than that, I have no idea what else could be causing it.
Jason.
Jason Bell, B.I.T.
B. Info. Tech. (Honours) Student
Network Engineer
Information Technology Division
Central Queensland University
High Performance Computing Support Officer
Research Assistant to the Nonlinear Intelligent Systems Research Group
Faculty of Informatics & Communication
E-mail : j.bell at cqu.edu.au
Phone : 07 4930 9229
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
-----Original Message-----
Sent: Wednesday, 23 February 2005 12:01
To: Jason Bell; ag-tech at mcs.anl.gov; accessgrid-l at clix.aarnet.edu.au
Subject: Re: [AG-TECH] Video freezing on the iSight
Jason
We were having the same problem when running the beta version.
Sometimes the video would freeze in the vic window but then I'd go
over to another machine running ag and that machine was still
receiving video from the other.  That was really wierd. Since
installing the release version I have not seen the freezing video. I
noticed that it seemed to freeze most when nothing was happening.
Like I would leave my cubicle with the camera running and return in
10 minutes and the video would have froze. When there was action, the
video did not freeze as much.
Sorry I couldn't be of more help.
We are running mac osx 10.3.8 on  powerpc G4 laptops.
Paul
At 10:45 AM +1000 2/23/05, Jason Bell wrote:
>G'day All
>I was just wondering if any of you have had similar difficulties,
where,
>when running the AG software on OS X 10.3, the video feed from the
>iSight using a video producer freezes.
>The video works fine for 5-10 minutes, then for some reason the video
>stops sending any video updates.  I am hoping that someone else may
have
>experienced a similar problem and knew of a fix.
>Thanks for your time,
>Jason.
>Jason Bell, B.I.T.
>Network Engineer
