[AG-TECH] Video freezing on the iSight
    Eric Olson
    eolson at mcs.anl.gov
    Wed Feb 23 12:47:35 CST 2005
Hi Jason,
I haven't seen that here yet, but we don't have many machines for testing.
You could try reducing the cpu load by changing the VideoProducerService
(or VideoService) configuration and reducing the framerate and/or
bandwidth.
For others reading this who haven't done this before:
To configure a service, select Preferences->Manage My Node..., select
the service, then right-click (control-click on the mac) and pick
"Configure...".  Change the setting, close the configuration dialog, then
disable and enable the service to see the effects.  If it does fix the
problem, make sure to save the configuration you want to keep.
Unfortunately, the quality setting doesn't work yet, but you could test
it by manually adjusting the setting in vic -- although the effect would
be temporary.
Let us know if you find something that helps.
Eric
On Wed, 23 Feb 2005, Jason Bell wrote:
> G'day Paul
> Thanks for your feedback.
> Basically when my video freezes, it does so on the other machines in the
> same venues as well.
> The only thing they I can se that might be affecting it is that I am
> running this on a low-end iMac and at times it is running at 0%
> idle.....
> Other than that, I have no idea what else could be causing it.
> Thanks,
> Jason.
> Jason Bell, B.I.T.
> B. Info. Tech. (Honours) Student
> Network Engineer
> Information Technology Division
> Central Queensland University
> High Performance Computing Support Officer
> Research Assistant to the Nonlinear Intelligent Systems Research Group
> Faculty of Informatics & Communication
> E-mail : j.bell at cqu.edu.au
> Phone : 07 4930 9229
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
> -----Original Message-----
> From: Paul Mercer [mailto:mercer at arsc.edu]
> Sent: Wednesday, 23 February 2005 12:01
> To: Jason Bell; ag-tech at mcs.anl.gov; accessgrid-l at clix.aarnet.edu.au
> Subject: Re: [AG-TECH] Video freezing on the iSight
> Jason
> We were having the same problem when running the beta version.
> Sometimes the video would freeze in the vic window but then I'd go
> over to another machine running ag and that machine was still
> receiving video from the other.  That was really wierd. Since
> installing the release version I have not seen the freezing video. I
> noticed that it seemed to freeze most when nothing was happening.
> Like I would leave my cubicle with the camera running and return in
> 10 minutes and the video would have froze. When there was action, the
> video did not freeze as much.
> Sorry I couldn't be of more help.
> We are running mac osx 10.3.8 on  powerpc G4 laptops.
> Paul
> At 10:45 AM +1000 2/23/05, Jason Bell wrote:
> >G'day All
> >I was just wondering if any of you have had similar difficulties,
> where,
> >when running the AG software on OS X 10.3, the video feed from the
> >iSight using a video producer freezes.
> >The video works fine for 5-10 minutes, then for some reason the video
> >stops sending any video updates.  I am hoping that someone else may
> have
> >experienced a similar problem and knew of a fix.
> >Thanks for your time,
> >Jason.
> >Jason Bell, B.I.T.
> >Network Engineer
