[AG-TECH] Mac OSX AGTk 2.3 with Media Tools Release
    David McNabb
    mcnabb at umd.edu
    Mon Feb 21 07:43:02 CST 2005
Eric et al,
Is anyone working on expanding the OSX client to be able to select from
more audio sources?  In particular, can it (or will it be able to) take audio
from a USB source such as iMic?  If this were working, one could use any
mic-level or line-level source.  I haven't actually tried this yet but will do
so later today or tomorrow.
   --David McNabb
David McNabb
Project Lead, UMAGI
UM Access Grid Initiative
Office of Information Technology
University of Maryland
College Park, MD, USA
mcnabb at umd.edu
---- Original message ----
>Date: Tue, 8 Feb 2005 11:46:46 -0600 (CST)
>From: Eric Olson <eolson at mcs.anl.gov>
>Subject: Re: [AG-TECH] Mac OSX AGTk 2.3 with Media Tools Release
>To: Marius Schamschula <marius at physics.aamu.edu>
>Cc: AG Tech <ag-tech at mcs.anl.gov>
>Hi Marius,
>> Do you have any ideas on what microphones will work with a G5? I was
>> hoping to use the built-in microphone in my iSight.
>Maybe someone on the list with more audio expertise could give a better
>answer.  I expect anything that can give a line-level signal would work.
>We were able to test successfully with the line-in from another computer,
>and I also expect microphones that require phantom power to work (the
>additional phantom power supply would also be required), although those
>may be more expensive.
>> In the meantime (until I order an iSight for campus - i.e. it works)
>> I'm using an older iBot Firewire camera.
>I tracked down an iBot around here, and it does work (i don't know if you
>meant you had it working with the AG already).  So if you're happy with
>your iBot, buying an iSight won't make much difference.  I wasn't
>able to get USB cameras to work on the mac here, but perhaps firewire
>cameras or certain models are more likely to work.  I'll make a note on
>the download page that other cameras may work.
>> On an other front: My machine is multihomed. The AG software picks out
>> the wrong subnet (the one that is unicast rather than multicast). How
>> do i tell the AG software which to use?
>For the communication between AG toolkit components, setting the
>environment variable GLOBUS_HOSTNAME to an ip address tells the toolkit
>which host or ip to use. -- But that doesn't affect the audio or video
>services, which is what you care about.  I'm not aware of a way to set
>this for the media tools, but you may have some luck looking the routing
>table metrics on your machine -- there are others on this mailing list
>that are more knowledgeable about this and could give you a better
>answer.
>Eric
>> On Feb 7, 2005, at 4:27 PM, Eric Olson wrote:
>> >   On a G5 Power Mac, a powered microphone is required to send audio --
>> > the
>> >   line-in port does not work with standard computer microphones.
>> Marius
>> Marius Schamschula, Ph.D. - Optical Physicist, Mac and Network
>> Coordinator
>> 		   	 Alabama A & M University, Department of Physics
>> 			 	 The Center for Applied Optical Sciences
>> 	   The Center for Hydrology Soil Climatology and Remote Sensing
>> 		 http://www.caos.aamu.edu/ - http://www.hscars.aamu.edu/
>> 					   http://www.physics.aamu.edu/
