[AG-TECH] "waiting for video" with unicast
    Michael Gates
    mgates at sdsc.edu
    Wed Feb 16 12:51:14 CST 2005
Ah... sorry, the increase in process priority only helps with the yellow
blip thing... doesn't help with receiving video.
-M
Michael Gates
VTC Services
mgates at sdsc dot edu
858.534.5188
SDSC Main bld. Room 109
-----Original Message-----
From: Monika Rabarison [mailto:monika.k.rabarison at ccaix.jsums.edu]
Sent: Wednesday, February 16, 2005 10:14 AM
To: Michael Gates
Cc: ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] "waiting for video" with unicast
Mike,
thanks for your reply. On previous tests I used VideoService
on the Personal Node. I tested using VideoConsumerService and
VideoProducerService. I'm getting my local video stream on the Video
Producer but still just "waiting for video" on Video Consumer.
Increasing
the priority for the Consumer process did not help either.
Thanks again,
Monika
On Wed, 16 Feb 2005, Michael Gates wrote:
> I have seen this problem with unicast bridges as well.  Using a single
> machine node, the consumer VIC session receives no video, while a
random
> producer VIC does.  The other two producer VICs do not have the
incoming
> streams.  We usually have to un-mute all the incoming video streams on
> the producer VIC session to view other sites' video.
> This usually causes the outgoing stream from that VIC session to have
> frequent yellow blips.  Increasing the priority of the vic process
> helps, but does not completely cure it.
> I've always wondered why Unicast behaved differently in the media
tools
> than Multicast...
> -Mike
> Michael Gates
> VTC Services
> 858.534.5188
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
> Behalf Of Monika Rabarison
> Sent: Wednesday, February 16, 2005 9:14 AM
> To: Osland, CD (Chris)
> Cc: ag-tech at mcs.anl.gov; Hill, NM (Nick)
> On Wed, 16 Feb 2005, Osland, CD (Chris) wrote:
> > We found a similar problem, but then found that the incoming
> > video was attached to a randomly chosen 'outgoing' vic; between
> > all the vic's that were started, we could pick up
> Chris,
> what do you mean by *pick up*?
> thanks,
> Monika
>  all incoming
> > and outgoing streams.  If I've got this wrong, Nick Hill should
> > be able to correct me.
> > Inelegant, but it works!
> > Cheers
> > Chris
> > ____________________________________________________________________
> > Chris Osland                         Office tel: +44 (0) 1235 446565
> > Digital Media and Access Grid      Medialab tel: +44 (0) 1235 446459
> > BIT Department             Access Grid room tel: +44 (0) 1235 445666
> > e-mail:   C.D.Osland at rl.ac.uk               Fax: +44 (0) 1235 445597
> > CCLRC Rutherford Appleton Laboratory (Bldg. R18)
> > Chilton, DIDCOT, Oxon OX11 0QX, UK
> > [The contents of this email are confidential and are for the use of
> > the intended recipient only.  If you are not the intended recipient
> > do not take any action on it or show it to anyone else,
> > but return this email to the sender and delete your copy of it.]
[mailto:owner-ag-tech at mcs.anl.gov]On
> > > Sent: 16 February 2005 15:22
> > > To: ag-tech at mcs.anl.gov
> > > Subject: [AG-TECH] "waiting for video" with unicast
> > > Hi All,
> > > Could someone help with the following issue?
> > > Multicast is working fine. The problem is when switching to
> > > unicast using
> > > any bridge. I have tested with a Room Node and a Personal Node
(XP).
> > > No problem with rat. On the Room Node, vic is "waiting for
> > > video" on the Display machine (XP) and shows only the local video
> > > streams on the Video Capture machine(FC2). On the Personal
> > > Node, vic shows
> > > only the local video stream. No video transmission or
> > > reception between
> > > the Room Node and the Personal Node.
> > > When I run vic manually, I'm having the same problem.
> > > A remote site using unicast confirmed receiving audio and video
> > > from us though.
> > > You may wonder why I need to switch to unicast if multicast
> > > is working.
> > > We have sessions with a site that has to use unicast due to
> multicast
> > > issues. For some reason, when I use multicast,the audio from
> > > that site is
> > > breaking out.
> > > Any help would be most appreciated.
> > > Monika
