[AG-TECH] "waiting for video" with unicast
    Thomas D. Uram
    turam at mcs.anl.gov
    Thu Feb 17 15:09:45 CST 2005
This part of the problem is related to the bridging software.  It distinguishes between
clients based on IP but not port, so it sends data to only one vic instance per machine.
On a single machine node, the workaround is to use a VideoService instead of both a
VideoProducer and VideoConsumer (which should be done on a single machine node anyway).
If you have multiple cameras, a producer started for each one can send data to the bridge,
and it will be distributed correctly.
Tom
Monika Rabarison wrote:
> Mike,
> thanks for your reply. On previous tests I used VideoService
> on the Personal Node. I tested using VideoConsumerService and
> VideoProducerService. I'm getting my local video stream on the Video
> Producer but still just "waiting for video" on Video Consumer. Increasing
> the priority for the Consumer process did not help either.
> Thanks again,
> Monika
> On Wed, 16 Feb 2005, Michael Gates wrote:
>>I have seen this problem with unicast bridges as well.  Using a single
>>machine node, the consumer VIC session receives no video, while a random
>>producer VIC does.  The other two producer VICs do not have the incoming
>>streams.  We usually have to un-mute all the incoming video streams on
>>the producer VIC session to view other sites' video.
>>This usually causes the outgoing stream from that VIC session to have
>>frequent yellow blips.  Increasing the priority of the vic process
>>helps, but does not completely cure it.
>>I've always wondered why Unicast behaved differently in the media tools
>>than Multicast...
>>-Mike
>>Michael Gates
>>VTC Services
>>mgates at sdsc dot edu
>>858.534.5188
>>SDSC Main bld. Room 109
>>-----Original Message-----
>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
>>Behalf Of Monika Rabarison
>>Sent: Wednesday, February 16, 2005 9:14 AM
>>To: Osland, CD (Chris)
>>Cc: ag-tech at mcs.anl.gov; Hill, NM (Nick)
>>Subject: RE: [AG-TECH] "waiting for video" with unicast
>>On Wed, 16 Feb 2005, Osland, CD (Chris) wrote:
>>>We found a similar problem, but then found that the incoming
>>>video was attached to a randomly chosen 'outgoing' vic; between
>>>all the vic's that were started, we could pick up
>>Chris,
>>what do you mean by *pick up*?
>>thanks,
>>Monika
>> all incoming
>>>and outgoing streams.  If I've got this wrong, Nick Hill should
>>>be able to correct me.
>>>Inelegant, but it works!
>>>Cheers
>>>Chris
>>>____________________________________________________________________
>>>Chris Osland                         Office tel: +44 (0) 1235 446565
>>>Digital Media and Access Grid      Medialab tel: +44 (0) 1235 446459
>>>BIT Department             Access Grid room tel: +44 (0) 1235 445666
>>>e-mail:   C.D.Osland at rl.ac.uk               Fax: +44 (0) 1235 445597
>>>CCLRC Rutherford Appleton Laboratory (Bldg. R18)
>>>Chilton, DIDCOT, Oxon OX11 0QX, UK
>>>[The contents of this email are confidential and are for the use of
>>>the intended recipient only.  If you are not the intended recipient
>>>do not take any action on it or show it to anyone else,
>>>but return this email to the sender and delete your copy of it.]
>>>>From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
>>>>Sent: 16 February 2005 15:22
>>>>To: ag-tech at mcs.anl.gov
>>>>Subject: [AG-TECH] "waiting for video" with unicast
>>>>Hi All,
>>>>Could someone help with the following issue?
>>>>Multicast is working fine. The problem is when switching to
>>>>unicast using
>>>>any bridge. I have tested with a Room Node and a Personal Node (XP).
>>>>No problem with rat. On the Room Node, vic is "waiting for
>>>>video" on the Display machine (XP) and shows only the local video
>>>>streams on the Video Capture machine(FC2). On the Personal
>>>>Node, vic shows
>>>>only the local video stream. No video transmission or
>>>>reception between
>>>>the Room Node and the Personal Node.
>>>>When I run vic manually, I'm having the same problem.
>>>>A remote site using unicast confirmed receiving audio and video
>>>>from us though.
>>>>You may wonder why I need to switch to unicast if multicast
>>>>is working.
>>>>We have sessions with a site that has to use unicast due to
>>multicast
>>>>issues. For some reason, when I use multicast,the audio from
>>>>that site is
>>>>breaking out.
>>>>Any help would be most appreciated.
>>>>Monika
