[AG-TECH] "waiting for video" with unicast
Monika Rabarison
monika.k.rabarison at ccaix.jsums.edu
Wed Feb 16 11:13:56 CST 2005
On Wed, 16 Feb 2005, Osland, CD (Chris) wrote:
> We found a similar problem, but then found that the incoming
> video was attached to a randomly chosen 'outgoing' vic; between
> all the vic's that were started, we could pick up
Chris,
what do you mean by *pick up*?
thanks,
Monika
all incoming
> and outgoing streams. If I've got this wrong, Nick Hill should
> be able to correct me.
> Inelegant, but it works!
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CCLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of
> the intended recipient only. If you are not the intended recipient
> do not take any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > -----Original Message-----
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Behalf Of Monika Rabarison
> > Sent: 16 February 2005 15:22
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] "waiting for video" with unicast
> > Hi All,
> > Could someone help with the following issue?
> > Multicast is working fine. The problem is when switching to
> > unicast using
> > any bridge. I have tested with a Room Node and a Personal Node (XP).
> > No problem with rat. On the Room Node, vic is "waiting for
> > video" on the Display machine (XP) and shows only the local video
> > streams on the Video Capture machine(FC2). On the Personal
> > Node, vic shows
> > only the local video stream. No video transmission or
> > reception between
> > the Room Node and the Personal Node.
> > When I run vic manually, I'm having the same problem.
> > A remote site using unicast confirmed receiving audio and video
> > from us though.
> > You may wonder why I need to switch to unicast if multicast
> > is working.
> > We have sessions with a site that has to use unicast due to multicast
> > issues. For some reason, when I use multicast,the audio from
> > that site is
> > breaking out.
> > Any help would be most appreciated.
> > Monika
