[AG-TECH] "waiting for video" with unicast
Michael Gates
mgates at sdsc.edu
Wed Feb 16 11:32:33 CST 2005
I have seen this problem with unicast bridges as well. Using a single
machine node, the consumer VIC session receives no video, while a random
producer VIC does. The other two producer VICs do not have the incoming
streams. We usually have to un-mute all the incoming video streams on
the producer VIC session to view other sites' video.
This usually causes the outgoing stream from that VIC session to have
frequent yellow blips. Increasing the priority of the vic process
helps, but does not completely cure it.
I've always wondered why Unicast behaved differently in the media tools
than Multicast...
-Mike
Michael Gates
VTC Services
mgates at sdsc dot edu
858.534.5188
SDSC Main bld. Room 109
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Monika Rabarison
Sent: Wednesday, February 16, 2005 9:14 AM
To: Osland, CD (Chris)
Cc: ag-tech at mcs.anl.gov; Hill, NM (Nick)
Subject: RE: [AG-TECH] "waiting for video" with unicast
On Wed, 16 Feb 2005, Osland, CD (Chris) wrote:
> We found a similar problem, but then found that the incoming
> video was attached to a randomly chosen 'outgoing' vic; between
> all the vic's that were started, we could pick up
Chris,
what do you mean by *pick up*?
thanks,
Monika
all incoming
> and outgoing streams. If I've got this wrong, Nick Hill should
> be able to correct me.
> Inelegant, but it works!
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
> BIT Department Access Grid room tel: +44 (0) 1235 445666
> e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
> CCLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and are for the use of
> the intended recipient only. If you are not the intended recipient
> do not take any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > Sent: 16 February 2005 15:22
> > To: ag-tech at mcs.anl.gov
> > Subject: [AG-TECH] "waiting for video" with unicast
> > Hi All,
> > Could someone help with the following issue?
> > Multicast is working fine. The problem is when switching to
> > unicast using
> > any bridge. I have tested with a Room Node and a Personal Node (XP).
> > No problem with rat. On the Room Node, vic is "waiting for
> > video" on the Display machine (XP) and shows only the local video
> > streams on the Video Capture machine(FC2). On the Personal
> > Node, vic shows
> > only the local video stream. No video transmission or
> > reception between
> > the Room Node and the Personal Node.
> > When I run vic manually, I'm having the same problem.
> > A remote site using unicast confirmed receiving audio and video
> > from us though.
> > You may wonder why I need to switch to unicast if multicast
> > is working.
> > We have sessions with a site that has to use unicast due to
multicast
> > issues. For some reason, when I use multicast,the audio from
> > that site is
> > breaking out.
> > Any help would be most appreciated.
> > Monika
