[AG-TECH] "waiting for video" with unicast
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Wed Feb 16 10:15:56 CST 2005
We found a similar problem, but then found that the incoming
video was attached to a randomly chosen 'outgoing' vic; between
all the vic's that were started, we could pick up all incoming
and outgoing streams. If I've got this wrong, Nick Hill should
be able to correct me.
Inelegant, but it works!
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CCLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and are for the use of
the intended recipient only. If you are not the intended recipient
do not take any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Monika Rabarison
> Sent: 16 February 2005 15:22
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] "waiting for video" with unicast
> Hi All,
> Could someone help with the following issue?
> Multicast is working fine. The problem is when switching to
> unicast using
> any bridge. I have tested with a Room Node and a Personal Node (XP).
> No problem with rat. On the Room Node, vic is "waiting for
> video" on the Display machine (XP) and shows only the local video
> streams on the Video Capture machine(FC2). On the Personal
> Node, vic shows
> only the local video stream. No video transmission or
> reception between
> the Room Node and the Personal Node.
> When I run vic manually, I'm having the same problem.
> A remote site using unicast confirmed receiving audio and video
> from us though.
> You may wonder why I need to switch to unicast if multicast
> is working.
> We have sessions with a site that has to use unicast due to multicast
> issues. For some reason, when I use multicast,the audio from
> that site is
> breaking out.
> Any help would be most appreciated.
> Monika
