[AG-TECH] Can't connect to a venue
Thomas D. Uram
turam at mcs.anl.gov
Wed Feb 9 11:48:59 CST 2005
This problem is occurring on recent Thinkpads. IBM's OEM XP installation includes the IBM
tools, which rely on python22, bits of which appear in the user's environment. The
problem, and a fix, are in bugzilla:
http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208
The only change that is really required is to unset the environment variable
PYTHONCASEOK in the system settings. Note that it is not sufficient to set it
to zero; it must be _unset_.
I'm not sure of the effect of this change on the IBM tools.
Tom
Michael Miller wrote:
> I have a user who is having trouble with AG 2.3 on their laptop. Here's
> what shows up in the VenueClient.log:
> 02/09/05 11:34:15 1756 DataStore datastore.py:273 DEBUG Reading
> persisted data from: C:\Documents and Settings\Celso\Application
> Data\AccessGrid\Config\personalDataStore\DataStore.dat
> 02/09/05 11:34:15 1756 VenueClient venueclient.py:215 DEBUG
> __createPersonalDataStore: Load personal data from file
> 02/09/05 11:34:15 1756 VenueClientController
> venueclientcontroller.py:1340 DEBUG There is no personal venues file to
> load.
> 02/09/05 11:34:21 1756 VenueClient venueclient.py:765 DEBUG
> EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> 02/09/05 11:34:21 1756 CertificateManager certificatemanager.py:621
> DEBUG HaveValidProxy: found proxy ident /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.uiuc.edu/CN=Celso Mendes/CN=proxy
> 02/09/05 11:34:21 1756 VenueClient venueclient.py:790 INFO
> EnterVenue: Error getting node capabilities
> 02/09/05 11:34:21 1756 VenueClient venueclient.py:686 DEBUG
> EnterVenue: Invoke venue enter
> 02/09/05 11:34:21 1756 VenueClient venueclient.py:836 ERROR
> EnterVenue: failed
> Traceback (most recent call last):
> File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
> 794, in EnterVenue
> self.__EnterVenue(URL)
> 687, in __EnterVenue
> (venueState, self.privateId, self.streamDescList ) =
> self.__venueProxy.Enter( self.profile )
> File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\AccessGrid\Venue.py",
> line 3096, in Enter
> File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\SOAPpy\Client.py",
> line 453, in __call__
> File
> line 475, in __r_call
> File
> line 338, in __call
> File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\SOAPpy\SOAPBuilder.py",
> line 620, in buildSOAP
> File
> line 118, in build
> File
> line 204, in genns
> NameError: global name 'TupleType' is not defined
> 02/09/05 11:34:21 1756 VenueClientUI venueclientui.py:2053 DEBUG
> bin.VenueClient::EnterVenue: Enter venue with url:
> 02/09/05 11:34:21 1756 VenueClientUI venueclientui.py:2066 DEBUG
> warningString:
> Can anyone tell me what's going on here?
> Thanx,
> Michael Miller
> System Engineer
> Visualization Technology Support
> Computing and Data Management
> National Center for Supercomputing Applications
> University of Illinois - UC
> 217-649-0747
> "If you're clear in your vision and trust the people in your team with
> clear objectives, they will invariably do their best to achieve
> everything desired, and usually deliver everything you could have hoped
> for and even more." -Paul Debevec
