[AG-TECH] Can't connect to a venue
Andrew Patrick
andrew.patrick at nrc-cnrc.gc.ca
Wed Feb 9 12:07:51 CST 2005
Yes, I am living with this problem with a Thinkpad.
The other change that I make in the environment is to remove python22 in the path and replace it with python23.
The other thing that I find is that if you use one of the special Thinkpad applications, such as Access IBM and the "blue button", then all the Python22 environment variables can get inserted back into the environment.
Thomas D. Uram wrote:
> This problem is occurring on recent Thinkpads. IBM's OEM XP
> installation includes the IBM
> tools, which rely on python22, bits of which appear in the user's
> environment. The
> problem, and a fix, are in bugzilla:
> http://bugzilla.mcs.anl.gov/AccessGrid/show_bug.cgi?id=1208
> The only change that is really required is to unset the environment
> variable
> PYTHONCASEOK in the system settings. Note that it is not sufficient to
> set it
> to zero; it must be _unset_.
> I'm not sure of the effect of this change on the IBM tools.
> Tom
> Michael Miller wrote:
> > I have a user who is having trouble with AG 2.3 on their laptop. Here's
> > what shows up in the VenueClient.log:
> > 02/09/05 11:34:15 1756 DataStore datastore.py:273 DEBUG Reading
> > persisted data from: C:\Documents and Settings\Celso\Application
> > Data\AccessGrid\Config\personalDataStore\DataStore.dat
> > 02/09/05 11:34:15 1756 VenueClient venueclient.py:215 DEBUG
> > __createPersonalDataStore: Load personal data from file
> > 02/09/05 11:34:15 1756 VenueClientController
> > venueclientcontroller.py:1340 DEBUG There is no personal venues file to
> > load.
> > 02/09/05 11:34:21 1756 VenueClient venueclient.py:765 DEBUG
> > EnterVenue; url=https://vv2.mcs.anl.gov:9000/Venues/default
> > 02/09/05 11:34:21 1756 CertificateManager certificatemanager.py:621
> > DEBUG HaveValidProxy: found proxy ident /O=Access
> > Grid/OU=agdev-ca.mcs.anl.gov/OU=cs.uiuc.edu/CN=Celso Mendes/CN=proxy
> > 02/09/05 11:34:21 1756 VenueClient venueclient.py:790 INFO
> > EnterVenue: Error getting node capabilities
> > 02/09/05 11:34:21 1756 VenueClient venueclient.py:686 DEBUG
> > EnterVenue: Invoke venue enter
> > 02/09/05 11:34:21 1756 VenueClient venueclient.py:836 ERROR
> > EnterVenue: failed
> > Traceback (most recent call last):
> > File "C:\Python23\Lib\site-packages\AccessGrid\VenueClient.py", line
> > 794, in EnterVenue
> > self.__EnterVenue(URL)
> > 687, in __EnterVenue
> > (venueState, self.privateId, self.streamDescList ) =
> > self.__venueProxy.Enter( self.profile )
> > File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\AccessGrid\Venue.py",
> > line 3096, in Enter
> > File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\SOAPpy\Client.py",
> > line 453, in __call__
> > File
> > line 475, in __r_call
> > File
> > line 338, in __call
> > File
> "C:\software\AccessGrid\build\dist-20040601_225453\Lib\site-packages\SOAPpy\SOAPBuilder.py",
> > line 620, in buildSOAP
> > File
> > line 118, in build
> > File
> > line 204, in genns
> > NameError: global name 'TupleType' is not defined
> > 02/09/05 11:34:21 1756 VenueClientUI venueclientui.py:2053 DEBUG
> > bin.VenueClient::EnterVenue: Enter venue with url:
> > 02/09/05 11:34:21 1756 VenueClientUI venueclientui.py:2066 DEBUG
> > warningString:
> > Can anyone tell me what's going on here?
> > Thanx,
> > Michael Miller
> > System Engineer
> > Visualization Technology Support
> > Computing and Data Management
> > National Center for Supercomputing Applications
> > University of Illinois - UC
> > 217-649-0747
> > "If you're clear in your vision and trust the people in your team with
> > clear objectives, they will invariably do their best to achieve
> > everything desired, and usually deliver everything you could have hoped
> > for and even more." -Paul Debevec
Andrew Patrick, Ph.D.
Senior Scientist
Information Security Group, Institute for Information Technology
National Research Council (NRC), Ottawa, Canada
E-mail: Andrew.Patrick at nrc-cnrc.gc.ca
WWW - NRC: http://iit-iti.nrc-cnrc.gc.ca
WWW - Personal: http://www.andrewpatrick.ca
Phone: (613) 991-3374 Fax: (613) 952-7151 Cell/SMS: (613) 277-9211
