[AG-TECH] Argonne Unicast Bridge and NCSA Scheduler
    Michael Miller
    myk at ncsa.uiuc.edu
    Fri Feb  4 12:52:19 CST 2005
Al,
Yes, when you select Use Unicast from the Preferences menu in you Venue
Client, you will see a bridge listed venuesbridge/NCSA.  This bridge is
provided by the machine running the NCSA AG 2 Venues Server.
Please let me know if you have further questions.
Michael Miller
NCSA
At 10:47 AM 2/4/2005, Alan Kraft wrote:
>Michael -
>Do I only need to go to the unicast menu item and click on it and then
>select the bridge that is on the list to start a unicast session?
>Al Kraft
> > Ian,
> > All venues on the NCSA AG 2 Venues Server
> > https://venues.ncsa.uiuc.edu:9000/Venues/default are bridged.  Are you
> able
> > to connect using the NCSA bridges?  If not, please let me know and I can
> > assist you in finding the problem.
> > Michael Miller
> > NCSA
> > At 05:36 PM 2/3/2005, you wrote:
> > >Hello, we (PNNL) have finally got our system upgraded and operational
> > >using AG2. We can connect via unicast to the Argonne bridge and can
> access
> > >the original rooms (e.g. Big Horn, Full Sail, etc.). Any meetings we will
> > >participate in will need to be in one of these seven rooms. However, on
> > >the NCSA scheduler, those rooms are listed in red and are labeled as
> being
> > >"inactive."
> > >How do we go about using the NCSA scheduler to use one of these rooms
> in a
> > >meeting?
> > >Thanks!
> > >~ian
> > >Ian Roberts <Interaction Designer> Rich Interaction Environments, Pacific
> > >Northwest National Laboratory
> > Thanx,
> > Michael Miller
> > System Engineer
> > Visualization Technology Support
> > Computing and Data Management
> > National Center for Supercomputing Applications
> > University of Illinois - UC
> > 217-649-0747
> > "If you're clear in your vision and trust the people in your team with
> > clear objectives, they will invariably do their best to achieve everything
> > desired, and usually deliver everything you could have hoped for and even
> > more." -Paul Debevec
Thanx,
Michael Miller
System Engineer
217-649-0747
